Old May 01, 2003, 02:35 PM
tumbleweed is offline
Find More Posts by tumbleweed
Golden, Colorado
Joined Jan 2003
Can you break in a motor with an esc already attached?
I have a s400 with a Sigesc20 already soldered on...
I would like to break in the motor...
Should I remove the esc? ...or just connect a 1.5 v AA cell directly to the motor terminals, and don't worry about hurting the esc???
tumbleweed is offline Find More Posts by tumbleweed
Old May 01, 2003, 02:43 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
I'd play it safe and remove the ESC.
William A is offline Find More Posts by William A
Old May 01, 2003, 04:43 PM
mikey702 is offline
Find More Posts by mikey702
Las Vegas, Navada
Joined Apr 2003
if you ESC has a BEC it will not run because the voltage is to low
it wint hert the ESC but the motor wont run so you have to eather take the ESC off or find a way to by pass it ( maybe you can fit an aligader clip behind the ESC and conet the batterys right to the motor termanals
mikey702 is offline Find More Posts by mikey702
Old May 02, 2003, 01:43 AM
shaneyee is offline
Find More Posts by shaneyee
shaneyee's Avatar
Singapore
Joined Aug 2002
Couldnt you plug in the regular battery pack and use a receiver to control the ESC to run the motor at a slow speed? Just make sure it nothing gets too hot and set a timer up to remind you to turn it off.
Shane
shaneyee is offline Find More Posts by shaneyee
Old May 02, 2003, 08:04 AM
Golden, Colorado
Joined Jan 2003
Thanks Guys! I think Shane has the best answer for THIS problem...
I can break in the motor at low-voltage, just by using the ESC to lower the voltage for me... i.e., just throttle the TX to low speed, no prop, and let it run...
Now, why couldn't I think of that!?
Thanks again!
Tim
Question Can I re-break in an engine with a bad break-in? lectraplayer Engines 4 Jul 26, 2007 08:33 PM
WTB: Mega 16/15/3 Motor with an ESC KillerCut Aircraft - Electric - Airplanes (FS/W) 0 Dec 30, 2004 01:16 AM
Can I put a resistor in series with an actuator coil? Lynxman Scratchbuilt Indoor and Micro Models 1 Aug 21, 2004 01:14 PM
Break-in with an ESC pre-attached Viper Pilot Power Systems 3 Jul 05, 2003 05:51 PM
Break in motor after ESC attached? Dzlstunter Parkflyers 6 Jan 12, 2003 06:52 PM
