Old Nov 15, 2009, 11:10 AM
lilpip is offline
Find More Posts by lilpip
Joined Sep 2004
Question
gws edf 64
Hi all , could anyone tell me what is the max diameter of motor that will fit a GWS 64 EDF plz? Thank you.
lilpip is offline Find More Posts by lilpip
Old Nov 15, 2009, 12:30 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
24mm diameter fits perfectly in the motor tube of 64mm and 55mm GWS fans
Bare is offline Find More Posts by Bare
Old Nov 15, 2009, 05:11 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
Or a larger outrunner with the proper adapter.
kelberts is offline Find More Posts by kelberts
Old Nov 15, 2009, 05:29 PM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
The Don's Wicked is a reasonably priced outrunner that gives good performance in the EDF64 on 3s. One of the jets I have the motor in, that has an EDF64.
WTFLYR is offline Find More Posts by WTFLYR
Old Nov 15, 2009, 09:02 PM
Bare is offline
Canada
Joined Nov 2000
these:
http://www.hobbycity.com/hobbycity/s...2W%284300kv%29
are a very reasonable EDF unit for $20 !! Sure there are better motors but Not at anywhere near this price.
If you feel the lust for mo' power these motors are easily rewound.
Old Nov 16, 2009, 05:30 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Originally Posted by Bare View Post
these:
Just don't believe the specs. If you get one with the correct Kv motor then it will pull close to 30A and may produce over 600g thrust on 3S.
My test data
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Nov 20, 2009, 01:52 AM
liam2317 is offline
Find More Posts by liam2317
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
these:
I was considering using this EDF in my first EDF build. I'm planning on, at least starting a Mirage 2000 over Christmas break. As it's my first build with an EDF I have, what is probably a very basic question about it. It's got a pretty big lip around it's intake side, should I build the internal ducting of my jet to be the same size as the lip or can I cover it up/cut it off? What will it do to performance?
Thanks guys, and sorry for jacking your thread lilpip.
liam2317 is offline Find More Posts by liam2317
Old Nov 20, 2009, 02:48 AM
ozzi supercub is offline
Find More Posts by ozzi supercub
WiggleWiggleWiggle
ozzi supercub's Avatar
South Australia
these:
+1 for these fan/motors. I have 2 and you cant beat them for the power they put out for $20.
EDF work better with intake lips so if you can keep the lip you will get better performance.
ozzi supercub is offline Find More Posts by ozzi supercub
Old Nov 20, 2009, 11:37 AM
liam2317 is offline
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
I guess what I'm trying to say is; because the Mirage will have internal ducting, and it's own kinda intake lip around it's intakes, is it really necessary to have double intake lips, one on the plane's intakes and one on the EDF's intake?
Old Nov 27, 2009, 07:06 PM
liam2317 is offline
Unregistered User
liam2317's Avatar
Canada, BC, Surrey
Joined Apr 2007
Bump!
Old Nov 28, 2009, 12:57 AM
Joined Jan 2001
You only need one lip, at the plane's intake.
The main purpose of a lip is to maintain smooth airflow at low speed (when air is sucked in from the sides of the inlet as well as from the front). However the EDF64 still needs its lip to stay round, so don't cut it off unless you are sure that the duct will support the fan well enough to prevent distortion of the shroud.
Old Dec 07, 2009, 09:44 AM
epkoncept is offline
Find More Posts by epkoncept
San Diego Lindberg, California, United States
Joined Jan 2002
1 edf GWS F15 worked
Bruce:
your estimation you gave me was right on the money. I had a Hobby City 25 C 2200mAH 3S pack, CC PH45 controller, two servo(HS-82MG) set up, minimal paint and a single 64 mm EDF with a Century Helicopter 20mm "hummingbird" brushless motor. It ROG'd off my dolly on the first try with a head wind. 4 subsequent attempts failed. Handlaunched the next 5 flights. On the fifth flight the motor died and I dead sticked.Battery was barely warm, motor was hot, and plane flew ok. Slow but with probably enough speed to roll, but not loop. I didn't even try diving then a loop, it just didn't have the power.
When my more powerful motors arrive from HC, I will see if the single edf will loop or not.
EP
epkoncept is offline Find More Posts by epkoncept
Sold Two GWS EDF-64+gws BL motors 20mm 3900kv NIB darmar Aircraft - Electric - Jets (FS/W) 6 Feb 01, 2008 11:00 AM
For Sale Two GWS EDF-64+gws BL motors 20mm 3900kv NIB darmar Aircraft - Electric - Power Systems (FS/W) 0 Jan 03, 2008 09:32 AM
For Sale GWS edf-64+ GWS 25 amp esc + GWS 3900kv inrunner. 68Strat Aircraft - Electric - Power Systems (FS/W) 1 Mar 25, 2007 10:10 PM
Wattage F-86 with GWS EDF 64 AMTJIM Electric Ducted Fan Jet Talk 16 Mar 01, 2004 02:46 AM
GWS EDF-55's and EDF-64's are available Hawker Electric Ducted Fan Jet Talk 26 Oct 02, 2003 05:51 AM
