Old Nov 17, 2009, 01:50 PM
bass3587 is offline
Find More Posts by bass3587
bass3587's Avatar
Arlington,Texas
Joined Jan 2005
Ok here is another question. As far as the yaw mechanism, I noticed that you are using a full size servo. If there any particular reason why a smaller servo or digital, metal gear servo couldn't be used?
bass3587 is offline Find More Posts by bass3587
Old Nov 17, 2009, 02:51 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
I had trouble with some ht mg servos not wanting to run through the gyro - I got some weird movement in the servo that run fine through the rx - I know Bob has used them on his smaller tricopters - I am using a full size just becasue that is what I had on hand - Mike
cdi3d is offline Find More Posts by cdi3d
Old Nov 17, 2009, 02:52 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Nevermind - I thought you were talking about your tricopter - I have been using a quadcopter in Reflex
Old Nov 17, 2009, 02:56 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by zirt57 View Post
Oh, I've also started practicing with a Realflight. I downloaded a copy of a Y-UFO. I hope my Tricopter flies easier than the Y-UFO. It wants to tip over very easily.
- Jeff
Please, will you post the link?
thank you.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Nov 17, 2009, 03:07 PM
Joined Aug 2009
I did a search and located this Y-UFO: http://www.knifeedge.com/forums/down...o=file&id=9740
Old Nov 17, 2009, 03:14 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
For the dt 750's a smaller servo is overworked. Its not he gears that are the problem, it is power. Hold a dt750 while running and try to turn it. There are lots of gyroscopic forces to overcome. I do use a hextronic 9 gram metal gear for the smaller copter, and MIGHT get away with it on the DT 750 copter, but its not worth the 1-2 oz saving.
Plus, I'm cheap, and had the full size servo already
Bob D
signguy is offline Find More Posts by signguy
Old Nov 17, 2009, 05:27 PM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
Yep, that's the one I'm practicing with. Damn hard too.
- Jeff
Zirt57 is offline Find More Posts by Zirt57
Old Nov 17, 2009, 06:10 PM
Joined Aug 2009
- Jeff
Well, I believe it is better for it to be harder than easier and have a great surprise on the maiden flight.
Old Nov 17, 2009, 07:55 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Hey guys - I just finished building a hover trainer to help me to trim my tricopter indoors - Just ran a piece of monofilament through a hole in the cg - Helps save me a few props while messing around inside - Works great as a training aid also - Just attach it to the floor and ceiling - KISS method - Rather fly the real thing verse a simulator -
Hover Training Tool- (0 min 54 sec)
Old Nov 17, 2009, 08:45 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
Originally Posted by cdi3d View Post
Hey guys - I just finished building a hover trainer to help me to trim my tricopter indoors - Just ran a piece of monofilament through a hole in the cg - Helps save me a few props while messing around inside - Works great as a training aid also - Just attach it to the floor and ceiling - KISS method - Rather fly the real thing verse a simulator - http://www.vimeo.com/7675445
Looking good Mike!
I like the lights. Had them on the old copter, just haven't got around to putting them on the new one.
Bob D
Old Nov 17, 2009, 09:11 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Thanks Bob - I am going to go pick up some new props tomorrow - I have been running APC 11x4.7 but I think they are to heavy for good response and might be part of my cause for power fluctuations and lose of altitude - I am going to try some 12x6 and 11x4.7 gws and see how they do - The trainer really helps save those props -
Old Nov 17, 2009, 09:20 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
Hi Mike
Be careful drilling those 11X4.7 props for the 4mm shaft. I had two props come apart in flight. I think it was due to the bit grabbing the plastic and pulling through before the bit had a chance to cut. I drilled the rest on the drill press with progressivly larger bits, and haven't lost a prop again.
Bob D
Old Nov 17, 2009, 09:37 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
That's a hell of an idea. Thanks. Once I get up and running (order is still processing ) I'll have to set that up. Thanks again for a great idea.
- Jeff
Old Nov 17, 2009, 10:26 PM
Dave Barrow is offline
Find More Posts by Dave Barrow
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
Yeah, my HK order shows shipped.
signguy, can you give me the dia. of the 750 motor mount base please? I have the body and arms cut and bolted together, I can start making the yaw mount and mount discs for the other two motors. I'll post pics tomorrow, been working overtime every day so I don't have a lot of build time in the evenings. I should be able to get more done this weekend.
Dave
Dave Barrow is offline Find More Posts by Dave Barrow
Old Nov 17, 2009, 10:36 PM
Joined Aug 2009
- Jeff
I just tried the --UFO2 and for me, it is keeping the origination correct. The only reference is the yellow fin.
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
