Old Sep 16, 2010, 08:03 AM
tashley is offline
Find More Posts by tashley
Aerial Images of Texas
tashley's Avatar
The Texas Gulf Coast where hurricanes come to play
Joined Aug 2003
Originally Posted by SkyEyes View Post
Booooo! lol. Surely your not admitting defeat?
I actually believe that we are over complicating the equation. Forget frames, motors, electronics, etc etc. Just draw a standard T shape (with the Bottom arm longer or the same as the horizontal arm) and with a bit of (mathematics/angles) calculation, on that shape alone, we can come up with a centre, where all the "triangles meet".
I'll look into it further (although we are assuming that all 3 Motors are identical - but there is the extra weight of a Yaw Servo at the back too... DOH!)...
Balance is balance. Build your T with whatever equipment/gear you choose and If you make all arms the same length put a mark 20% back from the front of the T and move gear around till you achieve center of gravity nirvana. If you choose to make your tail arm longer for whatever reason you will need to move the cg rearward as the kaptein did on his T design.
tashley is offline Find More Posts by tashley
Old Sep 16, 2010, 08:06 AM
Xptical is offline
Find More Posts by Xptical
Your user title is suggestive,
Xptical's Avatar
United States, GA, Carrollton
Joined Apr 2006
Originally Posted by tashley View Post
Under debate at present.
Yes, throttle channel for lift motors and gear channel for yaw.
Select your escs first and then follow their instructions.
*Tip* Pick programmable escs and buy a program card.
Turn delays off. Counter clockwise.
Yes
Small and light is better for aerobatics. Around 12" arms.
Read.
I'll be using CCPM. So I don't think the throttle channel needs to be tied to the ESCs. As I advance the throttle stick, the "pitch" channel should advance from 0% through the curve to 100%. I plan on flattening the curve around mid stick for a stable hover.
If that isn't the case, please let me know.
I'm hoping my 11X will allow for multiple gyro gains in heli mode. I hope to be able to tie the two front gyros to one gain channel, the tail motor gyro to another, and the tail servo gyro to a third gain channel.
The reasoning is that I can balance the "twitch" or "hunting" on each gyro separately.
Xptical is offline Find More Posts by Xptical
Old Sep 16, 2010, 08:07 AM
SkyEyes is offline
Find More Posts by SkyEyes
Multi Rotors Rule ! ;-)
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
I do understand what you are saying, and appreciate your feedback.
Do you think that having a longer rear arm on a "T", will make for a generally more stable Tri, as the 'triangle' between the 3 motors is that much bigger?
SkyEyes is offline Find More Posts by SkyEyes
Old Sep 16, 2010, 08:09 AM
CoastalTom is offline
Find More Posts by CoastalTom
United States, AL, Foley
Joined Nov 2005
[QUOTE=Reflex1;16062760]Stage Two. Propeller Balancing
Good info Paul. You are peaking my interest in dusting off my Tri and making it fly better.
CoastalTom is offline Find More Posts by CoastalTom
Old Sep 16, 2010, 08:15 AM
tashley is offline
tashley's Avatar
Joined Aug 2003
Yes I do, if I were building a T Tri I would make the rear arm longer than 50% of the front arm for reasons of stability. That would also make it easier balance wise to fit equipment. In other words you could hang ap gear out front and still achieve balance.
Old Sep 16, 2010, 08:19 AM
tashley is offline
tashley's Avatar
Joined Aug 2003
"I'll be using CCPM. So I don't think the throttle channel needs to be tied to the ESCs. As I advance the throttle stick, the "pitch" channel should advance from 0% through the curve to 100%. I plan on flattening the curve around mid stick for a stable hover."
You asked where the gyro gain wires should be on the rx and I posted the throttle channel.
Old Sep 16, 2010, 08:35 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Originally Posted by Xptical View Post
I am slowly making my way through the 600-odd-pages of this thread. As of now, if the guidance isn't in the first (original) build documents, I haven't really seen it.
Also read 'backwards' from the end and you will see some of the recent developments of this thread, as well as alternatives or (minor) improvements to the original setup design. This helped me a lot to catch-up without reading every post.
Also what helps me on long threads is to look only through the picture gallery. There are much less pics than posts (though many pics as well!) but if you run across pics or diagrams that seem interesting/relevant to you just open a new tab and open that particular post to read what is going on.
Hope that helps, above and beyond the obvious 'use search button' methods...
Derek_S is offline Find More Posts by Derek_S
Old Sep 16, 2010, 08:47 AM
SkyEyes is offline
SkyEyes's Avatar
United Kingdom
Joined Jul 2010
Thanks for that. Well on my Quadrocopter, motor shaft to motor shaft is 20.5". Therefore the front Arm could be similar here on the Tri, for 20.5" motor spacing.
With a 25 - 30 inch rear arm? Greater stability than making all 3 motors 20" apart? Then also as you say, more space to play with/CofG.
Old Sep 16, 2010, 09:16 AM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
My T Kopter has a longer rear boom, I will no doubt be playing with C.G. when I get it ready for flight. If the maiden is successful you can follow along
http://www.rcgroups.com/forums/showthread.php?t=1305025
power is offline Find More Posts by power
Old Sep 16, 2010, 10:02 AM
tashley is offline
tashley's Avatar
Joined Aug 2003
Very nice work Mike, impeccable as always.
spotterone is offline
Find More Posts by spotterone
Can you DS it??
spotterone's Avatar
Australia, NSW, Berowra
Joined Aug 2008
anybody tried using the Turnigy Sentry 25a ESC's? I've got the Turnigy Plush 30a ESC's on backorder and the sentry's have come into stock.
I've got no idea what to do with the balancing plug - I'm guessing you don't have to use it if you don't want to.
Oh, the motors are the 2830/14 750kv ones from RCTimer, and I'll be using the recommended props.
spotterone is offline Find More Posts by spotterone
Old Sep 16, 2010, 10:19 AM
Xptical is offline
Xptical's Avatar
Joined Apr 2006
So, you use the throttle channel to provide 0~49% for NORM and 51~100% for Heading Hold?
That's pretty clever. Especially since the throttle channel isn't used anyway. Then you can use the GAIN channel for the rudder gyro gain.
Old Sep 16, 2010, 10:35 AM
tashley is offline
tashley's Avatar
Joined Aug 2003
Set a linear throttle curve at around 30-40%across the board as a starting point. If that's too sensitive go to a bigger number. I have found that 20% makes mine behave like a spaz.
Gear channel for yaw gain.
Old Sep 16, 2010, 10:51 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
No idea on the ESCs (the RCtimer 30A ones are working for me so far) but the balance plug is really only useful if you want to power a secondary system with the main battery. I.e. I use the balance plug to power my pretty LEDs on my tri, and the FPV gear as well. It can also be used to power the low-voltage alarm if you use one, instead of tapping the main wires.
Old Sep 16, 2010, 11:03 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
T COPTER
Intersting build by MR Gress
No rear motor
http://www.rcgroups.com/forums/showt...ighlight=gress
Upup is offline Find More Posts by Upup
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
