Old Dec 21, 2009, 11:08 AM
rjarois is offline
Find More Posts by rjarois
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
another tri-copter in the air...
i could not take waitin any longer....i dug around the box oh junk and found 3- 10in dia props. the two orange ones had a 1/8dia center hole, so i crammed a drill thru them, wile sloppy i stuck them on. also they have a 4.7 pitch.....the odd prop is a 10in dia but a 3.8 pitch. all i wanted to do was check the electronics and gyro and control movements. so i didnt bother to balance anything. the orange center holes were so sloppy it would of been a waste of time anyhow. please excuse the bad video as i had the wrong setting. after i was done monkeying around, i went out front to check my mail....as i did i tripped over the box of props that tower hobbies sent....go figure, lols. i will get the right props on the tri-copter and balance them good. i will get the real maiden flight in the back yard. this time i will set the camera good, lols...... signguy, we have another tri in the air, if only a 1 sec 1in altitude flight, lols.again great build thread you made, thanks man...randy.
http://www.youtube.com/watch?v=a6cEpSbsPF4
rjarois is offline Find More Posts by rjarois
Old Dec 21, 2009, 11:59 AM
CoastalTom is offline
Find More Posts by CoastalTom
United States, AL, Foley
Joined Nov 2005
Way to go Randy!
CoastalTom is offline Find More Posts by CoastalTom
Old Dec 21, 2009, 12:01 PM
Lomcevac is offline
Find More Posts by Lomcevac
Worn-out the seat of my pants
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
A very short video of the second flight, in the daylight this time!
Tricopter (0 min 32 sec)
Lomcevac is offline Find More Posts by Lomcevac
Old Dec 21, 2009, 12:51 PM
rjarois is offline
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
lomcevac....way to go.. thanks to signguy i get the feeling we will be seeing more and more tri-copters...good job. randy.
Old Dec 21, 2009, 01:49 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
http://www.vimeo.com/8314088
Love the video Ad...
The video with the rear mounted camera wing is great too!! Love the sound effects. I also have a wing w/ a front mounted cam, and a large airbrake too! Looks like great minds think alike! How do you like the rear mounted cam? I imagine it is as easy to shoot as the front mount, but better protected.
Bob D
signguy is offline Find More Posts by signguy
Old Dec 21, 2009, 01:50 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
That thing will be flyin' round the backyard soon Randy!!
Old Dec 21, 2009, 03:49 PM
momozzzz is offline
Find More Posts by momozzzz
Grenoble-France
Joined Sep 2007
Hi to all tricop-pilots,
Did the 2nd test-fly with freezing conditions. The esc doesn't like cold weather (-5c) one of them refuse to arm until a friend cover it with his hand to warm it up . Need also more foam to set my camera, cause too much vibrations.
rjarois: on my tx (multiplex royal evo) if i do not change the pitch-curve (initial points: -100, -50, 0, 50, 100) the motors start only at near mid-stick-travel (-20), this hapens even with "esc calibration". So changed the curve to (-20...100), then motors start from the bottom. Notice nothing negative to that.
sorry for my english
snow day Tricopter test (2 min 10 sec)
momozzzz is offline Find More Posts by momozzzz
Old Dec 21, 2009, 05:39 PM
Dave Barrow is offline
Find More Posts by Dave Barrow
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
momozzzz, great video.
Dave Barrow is offline Find More Posts by Dave Barrow
Old Dec 21, 2009, 08:24 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Great video - Momozzzz you must have some past heli experience - Nice Job! I am getting tired of flying indoors so I may go outside once my new props get here - I found some 12x4.7 that should work great - I hope - I am also going to try one counter rotating to see if I can get a more level hover - We'll see - I did do some interior vibration test tonight and was really happy with the low vibes I was getting - I am still getting some wag in the tail with the telebee gyro on the tail set to 80% if I go higher it really wags - Anyone else seeing this on the tail?
cdi3d is offline Find More Posts by cdi3d
Old Dec 21, 2009, 08:48 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
Cooool video Momozzzz. Its also cool here, just got 20 inches of snow, I'll get some pics as soon as the wind slows to below 30MPH.
Bob D
Old Dec 22, 2009, 12:50 AM
X-Ilmar is offline
Find More Posts by X-Ilmar
X-Ilmar's Avatar
Estonia
Joined Sep 2005
Hei!
Here is my version... Was it my weakness, but don't beat me, I ordered TowerPro combo for motor,ESC,prop...
Thats not problem right now, but I have problem with one gyro. (Telebee Piezo Head Lock & Standard Gyro)
I first tested with servo. Other two works ok.
When gain wire is open, I understand, it goes HH mode and when I move TX stick the servo moves. Then I can use gain pot and when I rotate the gyro, sevo acts.
When gain wire is connected, when I move TX stick servo not moveing.
I used same gain setpoint as other two gyros. It was in throttle ch. and throttle curve was 20% all.
Something started to work, at 8% but my TX run out battery...
Edit:
PS. can I use EK2-0704 Helicopter Standard Gyro for one gyro, other will be Telebee? or all must be same?
Sorry my english,
-Ilmar-
X-Ilmar is offline Find More Posts by X-Ilmar
Old Dec 22, 2009, 08:33 AM
Joined Nov 2005
video
Lower Alabama TriCopter 12-21-09 (4 min 8 sec)
Here's another test flight from yesterday. Had Sony P&S on board for still pics and velcroed my key-fob cam to my baseball cap to get ground to air. I flew too high for my cap a couple of times and cut those scenes out. I need to aim better. Oh, and my neighbor had a leaf blower going so that's the sound you hear at the beginning.
I also bumped my DR lower and Expo lower for better stability.
Tom(A)
Old Dec 22, 2009, 09:02 AM
rjarois is offline
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
nice tom....your tri-copter looks real stable...you flying yaw in rate or heading mode?
Old Dec 22, 2009, 09:52 AM
Joined Nov 2005
Yaw is in rate mode as that's all the little pg-03 has.
Old Dec 22, 2009, 09:57 AM
rjarois is offline
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
thx tom. looks real nice...
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
