Old Nov 16, 2009, 10:23 AM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
This thread is great! Lots of info going to be in this one - I can;t wait to see all the tricopter video and AP shots coming this spring - Might need a tricopter AP meeting -
cdi3d is offline Find More Posts by cdi3d
Old Nov 16, 2009, 11:07 AM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Originally Posted by kestasxxx View Post
Hello, signguy.
Don't you think that using Flymentor 3D insted of your gyros would be better?
http://www.hobbyking.com/hobbycity/s...dProduct=10092
This thread was started to show how to build a tricopter that WILL work. . If you can get the flymentor to arm speed controls, it MIGHT work. Check the "yet another tricopter build" thread in the multi rotor forum. I think its been tried...
Bob D
signguy is offline Find More Posts by signguy
Old Nov 16, 2009, 11:23 AM
CAFplanekid is offline
Find More Posts by CAFplanekid
De-Brushed user
Midland, Tx / W. Lafayette, Ind.
Joined Dec 2002
Great thread, Signguy. I had not thought too much about bilding a tricoptor before, mainly because I had no gyros at all, but I just had to buy two new Futaba GY240s for a school project. They should work fine if I get another for a set of three and a fourth less expensive one for the yaw gyro, shouldn't they? Gyros are a new thing to me. Thanks,
Jonathan
CAFplanekid is offline Find More Posts by CAFplanekid
Old Nov 16, 2009, 11:37 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Bob D
Thank you for mentioning this Thread.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Nov 16, 2009, 01:33 PM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
Yes, thanks for mentioning that thread. I am reading through it right now. Lots to read...
- Jeff
Zirt57 is offline Find More Posts by Zirt57
Old Nov 16, 2009, 02:03 PM
Lomcevac is offline
Find More Posts by Lomcevac
Worn-out the seat of my pants
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
Don't think it's mentioned anywhere so what sort of flight endurance would you expect from this setup?
Lomcevac is offline Find More Posts by Lomcevac
Old Nov 16, 2009, 02:44 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
delete double post
Old Nov 16, 2009, 02:47 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
On the 2.2 ah turnigy battery I get 10 minuets without the camera, and 7 min with. It does not sound like a lot of time to take pictures, but you really only have to fly to a spot, stop for a few seconds, and fly back down. Most house pictures ( real estate types ) can be shot in less than a minuet.
I would think a 3000 mah batt would get you 12-15 min empty, and 10 min w/ camera.
Bob D
Old Nov 16, 2009, 02:49 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
Jonathan
I don't know if the GY240 gyros will work. I would set up a quick experiment. mount a motor on a stick ( like it would be on a tricopter ) then place the gyro on the throttle channel, and hook your speed control and motor to it. With the throttle down the speed control should arm. Then just raise the throttle a little and move the arm up and down. If it fights you, it should work ( notice the should )
I just looked up the cost on those, you can almost buy the three telebees for the cost of one more of the futaba gyros. The telebees WILL work, and you can use the futaba on the tail.
Some gyros just refuse to work with speed controls. And you MUST set the gyro to rate mode. If the gyro is only heading hold it WILL NOT work.
Bob D
Old Nov 16, 2009, 02:56 PM
Lomcevac is offline
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
Thanks Bob, that's better endurance than I expected. It's interesting to draw a comparison with a T-Rex 450 using the same packs. My T-rex only does about 6 mins. I guess the tricopter is more efficient as all thrust is lift (no tail rotor).
Ad
Old Nov 16, 2009, 03:28 PM
Joined Aug 2009
Ad
What is the weight of your T-rex in comparison to this tricopter?
Old Nov 16, 2009, 04:31 PM
Lomcevac is offline
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
My T-Rex is 600g or 20oz without battery. Just looking for Bobs tricopter weight, I'm sure he posted it.
Old Nov 16, 2009, 04:53 PM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
Came accross this very interesting TriCopter site yesterday: http://shrediquette.blogspot.com/
Arthur P. is offline Find More Posts by Arthur P.
Old Nov 16, 2009, 05:01 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
here are the weights
Tricopter alone 28oz or 812 gr
Tricopter w/ 2.2ah turnigy batt 34.5 oz 1000gr
I just came in from a test ( it is almost dark ) I flew with two 2" wide rolls of strapping tape attached to the bottom. The tape is 17.5oz or 507 gr for the two
Total weight with tape "payload" was 52 oz or 1508 gr
It flew around fine, the last time I tried this it flew poorly, but that was a much smaller frame size ( around 12" arms )
I don't think the flight time would be too long, maybe 4-5 min.....
Bob D
Old Nov 16, 2009, 05:08 PM
Lomcevac is offline
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
Cool so it basically flies at 200g heavier than my Trex but gets an extra 4 mins!
Incidentally I now have a T-rex 450 V2SE for sale if anyone's interested.
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 06:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 10:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 09:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 05:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 05:10 PM
