Old Feb 21, 2010, 06:20 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Originally Posted by Trnquill View Post
Did my tricopter maiden today. It has HK401 gyros and 750 motors. Managed to do two batteries in lovely -17 °C & 10m/s winter weather.
I could not get it to fly correctly. The motors were pulsating all the time. First I had the gyro delays at max, but after first battery I pulled them back to 50% (potentiometer at half way). This helped a little. The gyros were in digital mode.
It was far from stable. I would say way more unstable than a 450 heli! I did play with gyro gains and ended up somewhere around 20% on the radio (that's 60% gain in rate mode). I bumped up expo all the time and went as high as 50%. This was a bit too much so I'll try around 40% next time. I also have to move the battery somewhere else. The tri is very nose heavy if I mount the battery inside my frame like it is now, as far back it goes before hitting wires & ESCs & what not inside the frame. I think I'll just hang it under the frame so I can adjust the position more easily.
I had to stop when one of the motors froze up. We have thick (15-30cm) coat of light snow here at Finland and the tri spent quite long periods of time flying inside a cloud of snow. Too bad I don't have a video... My camcorder decided to forget how to make a proper exposure showing just plain white screen...
Any ideas on why the motors were pulsating, though?
Dont run the Gyros in Digital mode. There is no need. I have mine in standard and my Tri is VERY stable. A lot of others don't run Digital mode either.
With the Gain on the Gyro - I don't use the pot on the gyro itself. If you are using gain on the radio, the pot will do nothing anyway.
The_Mongrel is offline Find More Posts by The_Mongrel
Old Feb 21, 2010, 08:07 AM
Trnquill is offline
Find More Posts by Trnquill
Joined Jun 2009
Someone in this thread said HK401's do better in digital mode. But I'll try in analog!
The HK401's do not have a gain pot on them. They have delay and limit. I had the delay all the way up at first, then I dropped it to 50%. I'll try 0% in a minute and see what that does. The limit is at 100% and I guess that's the way it should be.
Trnquill is offline Find More Posts by Trnquill
Old Feb 21, 2010, 08:35 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I can run quite a bit more gain if I use the digital mode (about 5%). That will depend on the ESC motor and prop. The only problems I have heard about is using the digital mode with some HK brand ESC’s. I use Turnigy ESC’s and they have always worked perfectly in the digital mode.
I always run the delay at 0. I tried other settings but did not see any difference.
I have also found that frame stiffness makes a difference in the max gain you can run. Stiffer booms and a more rigid frame allow more gain and better stability.
RC Man is offline Find More Posts by RC Man
Old Feb 21, 2010, 10:21 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
My present understanding is, when the Gyro is in Digital Mode, you need to set the Delay to zero.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Feb 21, 2010, 11:06 AM
bofred is offline
Find More Posts by bofred
Kungshatt
Joined Mar 2008
Moi, I too have tried to fly in the cold. Today it was -12C but I decided not to fly because I cant trust the gyro beneath -5C (according to the spec.). But over -5C it flies great. Maybe the gyro can make that stange motor behaviour??
I also isolated the battery pack to gain more power. Without the isolation the flight time vere about 4min...
I long for the summer!!!
bofred is offline Find More Posts by bofred
Old Feb 21, 2010, 11:45 AM
Talontsi96 is offline
Find More Posts by Talontsi96
Talontsi96's Avatar
Edmonton, Alberta, Canada
Joined Jun 2004
I flew in temperatures lower than -5C and the Gyros worked OK. I would not worry about flying in lower temperatures as long as you let the Tri sit outside for a few minutes before the flight so that the gyros can adjust to the flight temperature.
Talontsi96 is offline Find More Posts by Talontsi96
Old Feb 21, 2010, 01:12 PM
Trnquill is offline
Joined Jun 2009
Hej, I adjusted my CoG (which was way off), reduced the gyro delay and switched them to analog. And lo and behold, it flew just great! Not much pulsing anymore and very controllable flight. Instead of uncontrollable 10 second hops I was able to fly circles and eights five minutes (full battery) without a slightest problem.
Five minute flight in -16C equals 1500mAh of juice drawn from the batteries. This is 50% of my 3000mAh Turnigy pack so I can push two more minutes of flying fun! I walked to my flying spot (about 5 minute walk) and had no problems with the HK401 gyros.
I still need to adjust tail gain & delay to make it behave more accurately. It's OK at the moment but could be way more solid.
I added a few pics of the completed system at the end of the series: http://fotoni.org/ilmasta/tricopter/
reverendrichie: I'm not sure if gyro mode (digital or analog) has anything to do with delay. After all, delay is there to compensate response time of the tail driving system (servo, linkages, etc.). When using digital servos the delay needs to be turned all the way down, that's for sure!
Old Feb 21, 2010, 01:13 PM
bofred is offline
Kungshatt
Joined Mar 2008
That is good news!! Often when the sun is shining the temperature drops down under -10C and it would be great to have some shiny snow photos from the air :-)
Old Feb 21, 2010, 01:29 PM
bofred is offline
Kungshatt
Joined Mar 2008
Terve, That is a really nice build!!
Maybe I was too afraid to fly in cold weather. Next sunny day I will make a test. I dont want to drop it because we have so much snow so it would be hard to find it ;-)
Soon hobbycity will ship me a 4Ah battery and then I can fly until my hands fall of...
I have a build log of my build here: http://www.rcgroups.com/forums/member.php?u=200107
Old Feb 21, 2010, 02:44 PM
bajas is offline
Find More Posts by bajas
making big holes in the sky..
Scandinavia
Joined Aug 2009
Glad to hear good news from the land of the thousand lakes....
And I must say that you bulind looks nice...almost sexy
I run my gyros for the ESCs on digital with 0 delay and in analog for the rudder-servo with 50% delay and about 60% gain in both rated and HH mode.
I have it an channel 8 on the RX so i can switch from rated to HH..
bajas is offline Find More Posts by bajas
Old Feb 21, 2010, 03:25 PM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
I have a question. What size is the shaft of the 750 motors! On the Hobby King page it says 4M. What does that mean? It doesn't say 4mm, it says 4M. I cannot believe the shafts on those little motors are 4mm. Could someone let me know. I would like to buy some prop savers. Thanks guys!
Carl
quailbird is offline Find More Posts by quailbird
Old Feb 21, 2010, 03:34 PM
tbee is offline
Find More Posts by tbee
tbee's Avatar
San Jose CA.
Joined Jun 2006
Hi Carl,
The shaft of the 750 is indeed 4mm.
Tbee
tbee is offline Find More Posts by tbee
Old Feb 21, 2010, 03:49 PM
quailbird's Avatar
Joined Nov 2003
Wow! Thanks! I would not have guessed that in a million years! The pictures makes it look like shafts on a BP21. I do appreciate the comeback.
Old Feb 21, 2010, 04:08 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Wait till you get those DT750's Quail. They are much larger than you think! The 4mm nuts for the shaft ( there are none in the dt750 boxes) are available at lowes and home depot. I just use std nuts, but you could use nylock nuts too. You will have to drill out the props a bit.
See Ya
Bob D
signguy is offline Find More Posts by signguy
Old Feb 21, 2010, 04:24 PM
kristjane is offline
Find More Posts by kristjane
Have a nice day! Kristjan
kristjane's Avatar
Slovenia, Novo mesto, Šentjernej
Joined Jan 2006
Today I had first crash.
tricopter 3rd flight (4 min 8 sec)
kristjane is offline Find More Posts by kristjane
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
