Old Nov 15, 2009, 12:31 AM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Bob - I will post my dx7 setting asap. I have been playing around with a crashable frame. That easily interchanges with my g10 model. I am tired of babysitting that thing any just need to fly.
cdi3d is offline Find More Posts by cdi3d
Old Nov 15, 2009, 07:00 AM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Bob,
thanks for starting this thread, a pile of condensed info in one spot
power is offline Find More Posts by power
Old Nov 15, 2009, 10:13 AM
Bob Chiang is offline
Find More Posts by Bob Chiang
Ithaca, NY USA
Joined Oct 2000
Here is a link with information to set up a Spektrum DX6i for a standard helicopter.
http://www.heliguy.com/Forum/viewtopic,p,163582.html
-Bob
Bob Chiang is offline Find More Posts by Bob Chiang
Old Nov 15, 2009, 10:19 AM
Dave Barrow is online now
Find More Posts by Dave Barrow
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
signguy, thanks for taking the time and effort to make this thread. I'm sure there will be a lot of Tricopters buzzing around by the first of the year (or at least by Spring) because of it. It is people like you that help make RC such a great hobby.
Dave
Dave Barrow is online now Find More Posts by Dave Barrow
Old Nov 15, 2009, 10:30 AM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
The only real difference with the dx7 TX is that the expo values are positive to make things less sensitive around mid stick - I am using all of Bob's settings except for making the expo positive where he has negative - Great thead Bob -
Old Nov 15, 2009, 10:43 AM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Puttin' on the camera
I like to have my camera well protected. Its not an expensive camera, but it is when you consider my budget.
The camera holder itself is the same used on my planes. It is a cylinder of foam ( dow blue insulation ) with a negative space for the camera, and a servo burried inside.
The mount to hold it to the copter is just a piece of foam ( stiff furniture cushion) rubber banded to the tri. The camera is then banded to the foam. This is a great mount to limit vibration from getting to the camera. It also [places the cam on top, protecting it even better.
I am also including some pictures of the landing gear mount. This bolts to the tri, using the same bolts that mount the arms. It is just carbon tube, and aluminum arrow glued together with gorilla glue ( I should have used JB weld)
This mount allows you to take straight down video, witch looks cool when climbing straight up!
When the cam is in the top mount, the battery is moved to the center top between the electronics. When the cam is on the LG mount, the battery stays in the front position.
The tri's will fly tail heavy, or nose heavy, but they fly best balanced directly in the center.
signguy is offline Find More Posts by signguy
Old Nov 15, 2009, 12:45 PM
Zirt57 is offline
Find More Posts by Zirt57
Zirt57's Avatar
Canada, ON, Cambridge
Joined Jan 2007
Well, my parts are ordered. Now to just start building the frame while I wait for the parts to arrive.
- Jeff
Zirt57 is offline Find More Posts by Zirt57
Old Nov 15, 2009, 01:01 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
- Jeff
Don't start too early, it shouldn't take too long!
Bob D
Old Nov 15, 2009, 01:53 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
Well I just did a quick inventory of what I have in my scraps bin. Loo and behold I've got some 5/8" square dowels. These should work for the arms. Lots of plywood for the frame so I guess the hard work will be the yaw pivot. I'll post pictures as I go along. I've also got an Askman TREX 450 landing gear/camera mount that I've never used. (Until now! ) I should be able to use this.
I also have a Futaba GY401 gyro. Do you think I use that for the yaw gyro?
- Jeff
Old Nov 15, 2009, 01:56 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
Bob D
Yes but it is Sunday. My building day! During the week I don't get lots of time in the shop. Not with the kids karate etc.
- Jeff
Old Nov 15, 2009, 02:06 PM
power is offline
power's Avatar
Joined Apr 2003
After reading through the Tricopter threads and looking at all the cool frames. I burned the midnight oil last night and designed my own folding frame. It utilizes aluminum 3/8 X 1/2 "U" channel from menards for the arms and a laminated ply center. I have all the parts ready for assembly. I will post some pics later.
This stuff is cool
Old Nov 15, 2009, 02:20 PM
Lomcevac is offline
Find More Posts by Lomcevac
Worn-out the seat of my pants
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
Damnit, damnit Bob!!! I was saving for an OSD
Hobby City here I come. Got some ply and spruce somewhere...
Lomcevac is offline Find More Posts by Lomcevac
Old Nov 15, 2009, 03:46 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
You don't need no stinkin' OSD !!
You will have a blast!
I just came in from flying, I did a little "vertibird" flying. I made a "capsule" from foam, with a 7-8" loop on top. A hook on the copter to pick it up. Its not easy! took lots of tries. I cut up the video, but its still long. I'll post it as soon as it converts in WMM, and is up on vimeo.
Tricopter, its not just for picture takin'!
Bob D
Old Nov 15, 2009, 03:51 PM
Zirt57 is offline
Zirt57's Avatar
Joined Jan 2007
I've built the frame and added the arms. See pictures below. Next to build the motor mounts and pivot.
- Jeff
Old Nov 15, 2009, 04:09 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
- Jeff
That was quick! Looks just like mine
Now the long wait for equipment..........
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
