CA and zip ties is in no way adequate to secure the motor mount to the boom. These things take a pounding and CA is a brittle adhesive at best. I used kevlar tow binding and epoxy to secure the mount to the boom. This gives a secure and vibration resistant mount. http://www.rcgroups.com/forums/attac...mentid=2955763 John |
I used the 10mmX10mm square with a 8mm round CF Tube from HK...This stuff:
http://www.hobbyking.com/hobbycity/s...idProduct=9012 Thanks for the post on Jim's frame results...That's good news.... Looks like I put too much foam on the motor mounts....I also did not put the CF tube to the end of the motor mounts like you did. I put the CF tube to about the edge of the hole for the center of the motor... By doing this the motor mount is not reinforced to the edge and does bend quite a bit when the motor torques. Now how do I detach the motor mounts and landing gear from the CF tubes after they have been CA'd together. Any good tricks in separating parts that have been CA'd together? |
here is a quick vid showing the arming with the new eurgle radios
![]() But yes... I find it easier than the Blade. I was always very nervous trying to fly my Blade. |
| Thread Tools | |
| Discussion Yet another tricopter build. !!Updated parts list!! | SebastianJ | Multirotor Talk | 2669 | Dec 30, 2011 05:48 PM |
| Discussion What to do? Failed tricopter build! | Razor_Racer | Coaxial Helicopters | 9 | Mar 07, 2011 09:20 AM |
| Discussion Tricopter Build | Razor_Racer | Coaxial Helicopters | 21 | Feb 20, 2010 08:24 PM |
| Build Log Tricopter build | SebastianJ | VTOLs | 1 | Dec 22, 2008 04:34 PM |
| Discussion Trying to build a mechanically actuated tricopter, Help! | stefalo | Coaxial Helicopters | 3 | Jan 09, 2008 04:10 PM |
