Old Jan 22, 2010, 10:13 AM
Talontsi96 is offline
Find More Posts by Talontsi96
Talontsi96's Avatar
Edmonton, Alberta, Canada
Joined Jun 2004
Never mind....
Talontsi96 is offline Find More Posts by Talontsi96
Old Jan 22, 2010, 12:12 PM
bajas is offline
Find More Posts by bajas
making big holes in the sky..
Scandinavia
Joined Aug 2009
Originally Posted by signguy View Post
Here is an all carbon/aluminum framed tricopter. I used the same plans, just cut from different materials. The center frame is two sheets of .012 aluminum over a plastic core, the arms are HC 10mm carbon with dowels glued into the ends. I used a HK401b for the yaw, but it needs to be hooked to a channel for gain. I'll program one of the knobs on the Eurgle to take care of the gyro gain.
At about 1 min in the video, I show the hands off stability. This is the first flight, using settings from my other copter.
http://www.vimeo.com/8895842
Looks like a Dream....
How do you attach the gyros??? Do you use some type of shock absorbing tape or just glued right on??
bajas is offline Find More Posts by bajas
Old Jan 22, 2010, 12:15 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
WOW, only thing that is needed is a GPS hold system.
Good Job Bob D, Excellent!!!!
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jan 22, 2010, 12:19 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
I use double sided foam tape. Most gyros come with the tape.
signguy is offline Find More Posts by signguy
Old Jan 22, 2010, 12:26 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
great job Bob!!! and what a great looking tri - Thanks for the weight info - I am shooting for 25oz on my next one but having a hard time getting there - Well Done!
cdi3d is offline Find More Posts by cdi3d
Old Jan 22, 2010, 12:39 PM
AC5FF is offline
Find More Posts by AC5FF
Where'd The Wise Men Go?!?
AC5FF's Avatar
United States, NE, Bellevue
Joined Sep 2007
SUCCESS
Well, sort of.. LOL. Powered up my Tri just a few minutes ago. Everything powers up and is working good. Either needs a LOT of trimming or ??? I couldn't get it to stay anywhere near stable. Most of the test all three legs remained on the ground; occasionally one or two would lift off - but with it constantly wanting to drift and spin I didn't want to give it much more throttle. At one point I thought I was getting the trim close and actually lifted off the ground - maybe 6" - but it quickly banked and wanted to take off sideways on me.
I think I know part of my problem is in my Tri's arms. I built these out of 1/4" aluminum U channel. Looks and works great but I have noticed that I get a lot of wobble at the motors. I don't think this Uchannel is strong enough. A quick fix for this is some additional Uchannel I have that snugly fits over the top. That will double the walls as well as enclose the U to make it a box. Should strengthen it up quite a bit.
I need to get the battery back home and check it though. I only messed around w/this for 5 min or so, but I no longer have enough power to lift a single arm. I can max out my throttle and not get enough power to the motors to do anything. Battery should not have drained THAT fast!!! As it sits now, I am just under 2.5lbs AUW.
But today's success gave me some needed motivation to go on w/this !!!
AC5FF is offline Find More Posts by AC5FF
Old Jan 22, 2010, 12:52 PM
Joined Aug 2009
Congratulation!!!
Old Jan 22, 2010, 01:13 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
Good job AC5FF I think you may be right about the arms - To much vibrations and ossilation can also mess with the gyros and your stability - Firm them up and give it another go -
Old Jan 22, 2010, 01:25 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
Good job guys!! It amazes me that there are tricopters ( tricoptie?) built from this thread all over the world! I've seen post from Greece France England Canada Australia Scandinavia Spain Israel and all over the USA. Hope I didn't miss any countries. This is very cool! Chime in with your location when you get flying.
And once more, I bow down to the real tricopter master Sebastian AKA bas10an
here on the groups, Also Dave Rains ( don't know about the spelling) AKA lemmiwinks, where I first saw a working tricopter on RC Groups. This is a fantastic place to sit and watch technology go wild!
Thanks Guys
Bob D signguy
Old Jan 22, 2010, 01:45 PM
CoastalTom is offline
Find More Posts by CoastalTom
United States, AL, Foley
Joined Nov 2005
Great flight Bob! What do you think makes that tri any more stable than your others?
Hang in there with your tri AC5FF. They all have their own personalities and you'll get yours figured out shortly. It feels good fire it up the first time huh?
CoastalTom is offline Find More Posts by CoastalTom
Old Jan 22, 2010, 01:54 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
Hi Tom
I don't think its any more stable than the other dt750 copter, I was lucky to have near windless weather to show how stable they can be. I still like the wood copters the best. Nothing makes me feel better than being able to fix a totaled tricopter with a table saw and ten minuets!
Bob D
Old Jan 22, 2010, 02:03 PM
rjarois is offline
Find More Posts by rjarois
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
signguy, your new build looks awesome...good job man..randy.
rjarois is offline Find More Posts by rjarois
Old Jan 22, 2010, 02:08 PM
Joined Nov 2005
I hear ya Bob! Mine is all wood as per your specs. It's nice to have a hobby section at Lowes.
Tom
Old Jan 22, 2010, 02:45 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Well said Bob. I think I have read through this thread about a dozen times, and still reading though it. I am in Australia and in the middle of my build.
I have a question for you guys...
I fly Mode2 and would like to know what where you guys put the "Yaw" stick? Is it the typical rudder channel on the left stick, keeping Ail and Ele on the right stick?
Cheers
-J
The_Mongrel is offline Find More Posts by The_Mongrel
Old Jan 22, 2010, 02:50 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
Cheers
-J
Yup mode 2 here too. Rudder (Yaw) on the left roll and pitch on the right. Wish I still had my EK logictrol single stick radio. I should build one out of the eurgle!
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
