Old Jan 20, 2010, 08:26 PM
TigerPilot is offline
Find More Posts by TigerPilot
Joined Jan 2005
Originally Posted by CoastalTom View Post
Here's a couple of views from the other side to show the linkage. Typical heli type link of ball links and short threaded rod.
Man, you've cut the shaft so short! If you ever want to use a prop that is a bit thicker it will not fit.
TigerPilot is offline Find More Posts by TigerPilot
Old Jan 20, 2010, 08:43 PM
nocontrol1 is offline
Find More Posts by nocontrol1
Joined Mar 2007
Has anybody run into an issue with the motors having momentary increases in speed? I was running the tri on the bench tonight and each of the motors (not at the same time) will have a "bump" up in speed that lasts a little less than a second. I connected servos to the gyros instead of the ESC's and the servos would show a brief twitch. Any Ideas?
Rob D.
nocontrol1 is offline Find More Posts by nocontrol1
Old Jan 20, 2010, 08:52 PM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Rob D.
Yes I experienced that glitchiness sometimes too.
Since you swapped the ESCs for servos, it has to be the signals coming from the receiver and gyros that are not stable.
Ruled out the ESC and ruled out interference.
I thought that might be the BEC giving out too low a voltage, since I always get it at the end of a battery charge. I switched my BEC from 5V to 6V to power up my RX and seems like it is better.
http://www.rcgroups.com/forums/showp...postcount=1581
etman is offline Find More Posts by etman
Old Jan 20, 2010, 08:55 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Originally Posted by BatterysIncluded View Post
Which pin?
For servo connectors, there is either Brown/Red/Yellow or Black/Red/White.
Signal is yellow or white.
You only need to connect the yellow wires together in parallel.
It might look funny, but only 1 yellow wire goes into your RX. The other two wires(brown/red) are not needed.
I solder 3 pin headers onto a breadboard and this makes it easier to connect.
You can buy one of these and cut them into smaller pieces.
http://www.nkcelectronics.com/break-...header-ma.html
Old Jan 20, 2010, 09:00 PM
Joined Mar 2007
Sorry, didn't mention- this happens with a nicd pack or BEC into the rx. ESC's are out near the motors, gyros are on the center board.
Rob D.
Old Jan 20, 2010, 09:08 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Rob D.
Seems like interference is ruled out since your ESC and gyros are far away.
My guess is the nicad voltage drops a lot or the BEC voltage drops.
Could you measure the voltage to the RX?
Old Jan 20, 2010, 09:12 PM
BatterysIncluded is offline
Find More Posts by BatterysIncluded
BatterysIncluded's Avatar
Joined Feb 2007
Thanks etman! I figured the signal pin but just wanted to verify rather than fry. It all makes sense now.
-Gary
BatterysIncluded is offline Find More Posts by BatterysIncluded
Old Jan 20, 2010, 09:13 PM
Joined Mar 2007
I just put the loaded meter on the Nicd- 1 amp load leveled out at 4.84v. The esc leveled out at 4.96v with the 1 amp load.
Rob D.
Old Jan 20, 2010, 09:20 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Rob D.
Sorry I'm not too sure whether that is enough voltage. But I'll go with 6V instead of 5V. Especially if you're using a 2.4Ghz receiver.
I currently use this
http://www.hobbycity.com/hobbycity/s..._5.5~23v_Input
Maybe this will be better. It has "noise reduction".
http://www.hobbycity.com/hobbycity/s...oise_Reduction
Old Jan 20, 2010, 09:29 PM
Joined Mar 2007
Duh! That's the bec I have- the dual voltage one. I set it to the 6 volt and got 5.96 under load. The motors still bump up. Do you think this is a flyability issue?
Futaba 9c on 50 mhz, PCM rx.
Rob D.
Old Jan 20, 2010, 09:37 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Which pin?
Signal, opposite the negative.
signguy is offline Find More Posts by signguy
Old Jan 20, 2010, 09:45 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Talontsi96 - That is one sweet looking frame! - How was it to put together?
cdi3d is offline Find More Posts by cdi3d
Old Jan 20, 2010, 09:48 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Rob D.
Definitely it affects the flyability. I would want to solve this problem before I put an expensive camera on it.
Both of these BEC I listed are dual voltage 5V/6V. Both are twitchy?
Then we need to investigate further.
I'm going to try a separate RX 3S lipo battery connected to the first BEC and lets see how it goes. Right now I'm powering it via my main lipo battery. I'm on 72 mhz JR9303 / Hitec RX.
Old Jan 20, 2010, 11:38 PM
VinCopter is offline
Find More Posts by VinCopter
VinCopter's Avatar
Singapore
Joined Apr 2005
I like to thank signguy and many contributors for the fantastic build tread. Want to try AP, so decided to build one. Notice that the Telebee gyro has been replaced with Turnugy gyro with the same part number.
I would like to know are they the same? Has anyone tried this Turnigy gyro?
VinCopter is offline Find More Posts by VinCopter
Old Jan 21, 2010, 12:00 AM
signguy is offline
signguy's Avatar
Joined Dec 2004
I'm building one now with the turnigy gyros. They look exactly the same as the bees'. I'll probably get it in the air tomorrow, I hope!
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
