Old Mar 06, 2013, 09:48 AM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Thanks Ian
I didn't get the pm/email, something went wrong..... I'll check out the guide and follow the instructions once I get a board. A buddy of mine has been waiting 3 weeks for his RCTimer order... damn Chinese new year!
signguy is offline Find More Posts by signguy
Old Mar 06, 2013, 04:09 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
Originally Posted by signguy View Post
Thanks Ian
I bought a bt dongle from rctimer and after 3 months it never came. They were kind enough to send another but that never came either. Ended up getting one from GLB instead.
Im not sure if it got lost since maybe the packaging was too small or whether it was stolen when it got into our area
As a safegaurd I would make sure anything you order has tracking.
jbalat is offline Find More Posts by jbalat
Old Mar 06, 2013, 06:53 PM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
Mine took about ten days all up
BigJimNZ is offline Find More Posts by BigJimNZ
Old Mar 06, 2013, 06:54 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Thanks Ian
I resent that email with right address Bob
Old Mar 24, 2013, 01:02 PM
MadSciStuff is offline
Find More Posts by MadSciStuff
Joined Jan 2013
Post moved to another thread: http://www.rcgroups.com/forums/showp...postcount=1881
MadSciStuff is offline Find More Posts by MadSciStuff
Old Apr 15, 2013, 04:55 AM
MHefny is offline
Find More Posts by MHefny
MHefny
MHefny's Avatar
Egypt, Al Qahirah, Qism El-Nozha
Joined Sep 2011
Originally Posted by abletowinginc View Post
very interesting.states you can switch from x to plus config without reorientating board. wow how the hell he do that. and the ground station cool
Hey I just found your post by chance
Thank you for the nice feedback ..... I just want to let you know that KK2 supports sonar now.
Best Regards,
M. Hefny
MHefny is offline Find More Posts by MHefny
Old Apr 15, 2013, 02:57 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Best Regards,
M. Hefny
I'm going to have to get me one of those boards to play with Mohammad.
Ian
Old Apr 17, 2013, 06:26 AM
jbalat is offline
Joined Feb 2011
Hi Ian just wondering if you can tell me about that cheap osd unit from hobby king ? I wanted to set something up for my postpak christmas quad
Is it still worth getting ?
Old Apr 18, 2013, 04:50 AM
srepfler is offline
Find More Posts by srepfler
srepfler's Avatar
Croatia, Osijek-Baranja County, Valpovo
Joined Jul 2011
I have good result with x900 HK frame
x900 flight in friend backyard (7 min 14 sec)
but I borrow motors form quad, have some NTM motors with different kv,
can I use different kv motor for tail motor?
can I use different size prop for tail?
Does smaller prop on tail reduce tail servo work/tension?
srepfler is offline Find More Posts by srepfler
Old Apr 18, 2013, 02:03 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Which cheap OSD unit John ?
Old Apr 18, 2013, 02:46 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
http://youtu.be/5u9K-XTdkKU
Even KV motors and props all round is correct method
In level mode it will probably fly with different tail combination but it will just make the motor work more or less to maintain level flight.
In acro you will have to fight the tail
A bigger prop will load a servo more than a smaller one
Old Apr 18, 2013, 04:03 PM
srepfler is offline
srepfler's Avatar
Joined Jul 2011
Thanks.
Old Apr 19, 2013, 06:34 PM
jbalat is offline
Joined Feb 2011
Which OSD are you using now ? I have found a cheap remzibi on goodluckbuy
Old Apr 19, 2013, 08:40 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Because I'm flying with the APM 2.5 I use the minim osd which takes the telemetry data from the board and overlays that on the screen. Very nice osd with just about every bit of. Info you ever need on a screen and a crap load more that you just don't need.
Thing is, like the remzibi, that you need to give it data to print on the screen. My minim will not work unless its connected to something that will give it data to put on the screen.
The other one I have used is the G-osdII flashed with CL-OSD software which gives it a home arrow and some other stuff.
What board are you flying now John ?
Old Apr 20, 2013, 09:41 AM
jbalat is offline
Joined Feb 2011
I have the remzibi on the hquad with a crius multiwii board and gopro 2. I am using my original home made multiwii with nunchuck arduino board on the x525 no fpv or cam and I am putting together the post pak quad with an old hobby king kk board. If all goes well with that one I may get the horyzon v3 and the g-osdII or another remzibi.
Btw I just got myself an electric bike and hoping to make a zippy battery pack for it soon.
Thinking about a 3d printer since prices have come down a bit. A few to choose from so need to do some research first.
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
