Old Jan 31, 2013, 03:41 PM
MadSciStuff is offline
Find More Posts by MadSciStuff
Joined Jan 2013
Servo tail jitter problem
Hi there! And hello! I'm new on the forums.
I've just assembled my tricopter last week and was starting to learn to fly. But since then it has developed a vibration in the tail that I have just this evening isolated to be related to the tail servo. I am aware of the jitter from an unfiltered servo and had set the servo filter setting on the KK2 to 30 as recommended. This issue seems to be unrelated and persisted when I upped that value to 40.
Then I tried disconnecting the servo, and hey presto! The vibration was gone. See the short vid below.
I'm using the BMS-385DMAX Digital Servo (Metal Gear) suggested in the original 2.5 build instructions. Any idea what it could be or what to try next? Thanks!
Tricopter tail jitter when servo connected (0 min 22 sec)
MadSciStuff is offline Find More Posts by MadSciStuff
Old Jan 31, 2013, 03:53 PM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
Originally Posted by sparklet View Post
The weathers not good, so it's time to make a new folding frame.
That way I will be ready for the long, hot summer I'm sure is coming.
Put it down as it was lunch time and...... looked at it properly for the first time since putting the bits together.
Wow ! I think I have built one of those ghost things that used to chase poor old Pacman around his maze.
Not only that but.... the tri seems to have too many legs
lol it does look like pacman ghost almost.........lookin good
abletowinginc is offline Find More Posts by abletowinginc
Old Jan 31, 2013, 03:56 PM
Joined Jun 2009
http://www.youtube.com/watch?v=W084GDEVXmg
honestly i dont see enough jittering to be concerned thats normal for the tail servo to wiggle its responding to the board detecting movement. you can try turning the gain down on the yaw see if that helps you but honestly mine moves and jitters or wiggles little movements.
Old Jan 31, 2013, 04:36 PM
Joined Jan 2013
Thank you. Your comment prompted me to test with the tricopter's hull clamped to my workbench to eliminate board movement and the tail arm didn't move at all this time. Chalk one up for newbie obsessing. The thing is that I only began to notice this recently -- probably because I started to get the hang of hovering (still no self levelling until I can upgrade the firmware) and began to look more closely at the copter.
What's the drawback of dialling down the yaw gain? More sluggish yaw response?
Old Feb 01, 2013, 07:02 AM
Joined Jun 2009
no sluggishness just the tail will start to drift not be as locked in.just adjust it until you get it solid but not jerky
Old Feb 02, 2013, 01:07 PM
blackwind_ro is offline
Find More Posts by blackwind_ro
Romania
Joined Jan 2013
Hello guys ,I'm new on rcgropus.Just finishing buildind a tricopter and i encounter a problem with esc calibration ""Throttle pass-through"" mesage on kk2 board.
Using a kk2 board 1,5 fw version , 20A esc flashed with simonk , 750kv motors.
I read kk2 manual and install everything in order and the same with esc calibration.My motors won`t start after arming the board.Any ideas?
Pics :
blackwind_ro is offline Find More Posts by blackwind_ro
Old Feb 03, 2013, 03:07 PM
EddieWeeks is online now
Find More Posts by EddieWeeks
EddieWeeks's Avatar
Baton Rouge, LA, USA
Joined Dec 2001
Tri-copter that is an airplane
Full VTOL with transition and back (1 min 26 sec)
EddieWeeks is online now Find More Posts by EddieWeeks
Old Feb 03, 2013, 05:45 PM
Joined Jun 2009
Pics :
i had same issue andhad to set the max throttle and minimum throttle one esc at a time for some reson. just unplugged all of them and plugged one ata time into reciever directly to set the throttle range then it solved the issue ur having
Old Feb 03, 2013, 05:47 PM
Joined Jun 2009
https://www.youtube.com/watch?v=qo7hvBXKqto
very cool.....interesting way to get around all the issues many have building a vtol.....different but works well
Old Feb 04, 2013, 08:40 AM
jhsa is offline
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Nice.. I would like to follow this project.. link?
Question, the tricopter motors don't stop after the transition?
jhsa is offline Find More Posts by jhsa
Old Feb 04, 2013, 12:56 PM
Joined Jun 2009
from what i seen they continued spinning....
Old Feb 05, 2013, 03:45 PM
EddieWeeks's Avatar
Joined Dec 2001
the tri-copter motors can be shut down in forward flight and all is well...
we did not allways shut them down...
The APM 2.5 disarms the copter after a short time... its not easy to hold full right rudder for 5 sec while flying that thing...
Build thread... ummm... that plane was built in 2-3 hours.. flown for the day.. then ended up and the top of a 40 foot tree stuck... we got it down but it died when it hit the ground..LOL...
Working on a new one with only 3 motors that all rotate 90 deg...
Old Feb 05, 2013, 10:02 PM
jhsa is offline
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Multiwwi can use a switch to arm/disarm the motors.. very nice project anyway. been thinking of something like this for a while.. actually, this was the reason I got into multirotors in first place..
Old Feb 15, 2013, 08:20 PM
jbalat is online now
Find More Posts by jbalat
Joined Feb 2011
Have we finally reached the end of this thread sign guy ?
jbalat is online now Find More Posts by jbalat
Old Feb 15, 2013, 08:33 PM
planerazy03 is offline
Find More Posts by planerazy03
Joined Jul 2011
I doubt it. Something new always comes about. That's the way of the thread.
planerazy03 is offline Find More Posts by planerazy03
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
