United States, NY, Shelter Island
Joined May 2011
My talon weighs 850g w/o battery with 30A esc and NTM28-26 1000kv motors. 9x5x3 on 3S if anemic and on 4S its great. Thanks for sharing that insight. H |
Same tricopter. Arms about 360mm. One vid with 10 x 4.7 the other 11 x 4.7
United States, MD, Ellicott City
Joined Feb 2010
Tricopter Masters Thesis
I just finished my masters thesis on a tricopter and figured the vibrational analysis my be of interest to some of you. Here is a small bit of it with the pictures and graphs on a PDF:
A test frame was constructed to dynamically isolate a motor. A vibration measuring device measured installed at the base of the motor measured vibrations through the whole throttle range. The vibration measuring device was made for an analog 3 channel data logger and a 3 axis accelerometer, both powered by a mini LiPo. Information was uploaded from the data logger to a computer for data analysis. The data provided was in “G’s,” which corresponds to one acceleration of gravity or 32.2 ft/s^2. By multiplying the mass of the motor by the accelerations, force is obtained. Since the mass of the logger was equal to the mass of the motors propeller adapter, the test was conducted without the propeller adapter without a need for correction of the mass of the measuring device in the analysis. To ensure the motor was properly dynamically isolate in the test frame, a second vibration measuring device was used to observe that no vibrations from the motor was dissipated through the frame. The second vibration measuring device was an iphone 4 which contains a three axis gyro and accelerometer and with a vibration application that can measure, display, and log vibrations the phone experiences. A second data logger was used in the ESC to record voltage, RPM’s, and throttle as the motor was run without a propeller through a range of throttle positions. Figure 14 shows the test frame used and the data logger. Four motors were tested as described in the above method. The resultant accelerations from the X, Y, and Z axis of were combined and plotted against the % throttle which produced the graph in Figure 15. The graph in Figure 15 shows the results plotted with a moving average trend line. The graph shows that the highest vibration spikes occurred at the 57% and 80-100% throttle positions. This information is useful to determine the proper throttle ranges to operating in a hover condition which may require minimized vibrations and to ensure that the RPM’s related to the throttle position do not coincide with the natural frequency of the candidate materials to be used for the rotor arms. Since the test was conducted with no propeller, ie a no load condition, the RPMs were used to correctly identify the occurrence of the vibration spikes. Different propellers on the motor will increase the loading while decreasing the RPMs. For example the no load max RPMs were approximately 12000 RPMs, while loaded the max was 8350 RPMs both corresponding to 100% throttle. Since the propellers are dynamically balanced, it is assumed little to no vibrations were caused by the propellers, the vibration spikes observed in the no load condition would occur at the same RPMs when loaded. The relationship between motor voltage and RPMs is linear. With the operator transmitter having the ability to use programmable curves, the throttle programming normally used in RC helicopter applications was used as shown in Figure 16. From Figures 15 and 16 it is determined that motor vibration spikes occur at 11200 RPMs and 12000 RPMs and above. These values of RPMs are outside the operating range or flight envelope of the loaded motor profile. Any vibration spikes observed on the frame will be a factor of the natural frequency and the length of the rotor arms for each of the candidate materials. The natural frequency is a function of the rotor arm length and material properties of each of the candidate materials. To model the rotor arm analytically a vibration beam analysis was completed. The dimensions of the rotor arm were best modeled as a cantilever beam fixed on one end and the other free, as seen in Figure 17. The mass of the motor was neglected since it provides an upward force from the propellers. Torque was also neglected since it is considered to be small when compared to the thrust. Figure 18 shows the area of constraint of the flight envelope, which is the operating RPM range of the loaded motor turning a 10 X 8 propeller. In this box it is undesirable to have the natural frequency of the material selected for the rotor arm to occur, which will cause excessive vibrations in flight. The rotor arm length was limited to 1 meter based on the availability of the material. The graph indicates that the favorable length and material for the rotor arm was 0.45 meters and carbon fiber. Aluminum was also acceptable for a length of .38 meters and wood .26 meters. At the lower end of the flight envelope the values were ignored since the corresponding lengths required would make the rotor arms easier to break. The results of the analysis was tested by taking vibration measurements of a 0.45 meter length beam on its fixed end while running the motor, loaded with a propeller, at various throttle positions on the free end. The data from this experiment was used on conjunction with the data in Figure 15 to develop a vibration transmissibility profile for each of the candidate materials. A ratio was taken of the accelerations observed on the clamp end over the accelerations from the motor. A ratio less than one indicated that the material was absorbing the vibrations from the motor, where as a ratio greater than one indicated that the vibrations from the motor were being amplified by the material. The results of this test are on the graph in Figure 19. With the propeller being dynamically balance and beam properly clamped down, no extra vibrations appeared to come from the propeller except when running near 100% throttle and when excess vibrations were detected in the beam, in which the propeller seemed to amplify the effect. This was due to propeller blade flections from maximum loading on the blades while being hold stationary. A moving average curve was placed on the carbon fiber profile to better highlight the results. As predicted from the beam analysis of the given length of 0.45 meters, the carbon fiber rotor arm was the best material. At a throttle range greater then 85% the carbon fiber began vibrating more to possible flections in the propeller blade as more thrust was produced. The vibrations can also correspond to the upper limits set in the beam analysis. The wood and aluminum rotor arms appeared to excessive vibrations through the throttle range greater than 60%. |
Joined Feb 2010
In short I measured the no load vibrations, figured out my loaded(with a prop) thrust curve, found my flight envelope, used beam theory to plot natural frequency vs rotor arm length for wood, AL, and CF, found my rotor arm length, and then tested it.
I used this for a tri on turnigy 1100 kv motor. |
very interesting and useful findings.... surprising even on the fact that wood didnt help reduce vibrations as well as carbon since the woods grains go in many different directions seems it would have helped reduce vibrations but you proved otherwise very interesting good work
i would like to see the isolation mount you made and used for this if youhave pictures
Joined Feb 2010
The mount is in the PDF, I made a square frame and used bugee cords to suspenend the motor in the middle of the frame. The cords would also disipate vibration transmission to the frame. The cords were attached to the screw loops on the motor mounting hardware. I tested the four motors and made an average fit on the graph. The three motors on the tri and one backup. I used a program on my iphone which converts it to a vibration meter and placed it on the frame to make sure the cords disipated the the vibs
Funnily enough I have arrived at arms of 0.46 metres for my tricopter through trial and error. I clamp my motors to the arms with a silicon isolator. That helped mitigate the resonance. Sparklet has been using lead on his craft to get the same effect for years ;-) I going to start on designing the wheel next lol Ian |
| Thread Tools | |
| Discussion Yet another tricopter build. !!Updated parts list!! | SebastianJ | Multirotor Talk | 2669 | Dec 30, 2011 05:48 PM |
| Discussion What to do? Failed tricopter build! | Razor_Racer | Coaxial Helicopters | 9 | Mar 07, 2011 09:20 AM |
| Discussion Tricopter Build | Razor_Racer | Coaxial Helicopters | 21 | Feb 20, 2010 08:24 PM |
| Build Log Tricopter build | SebastianJ | VTOLs | 1 | Dec 22, 2008 04:34 PM |
| Discussion Trying to build a mechanically actuated tricopter, Help! | stefalo | Coaxial Helicopters | 3 | Jan 09, 2008 04:10 PM |
