Old Nov 29, 2012, 10:52 AM
Jorgemaria is offline
Find More Posts by Jorgemaria
United States, DC, D.C.
Joined Dec 2008
New tail system from hobbyking
http://www.hobbyking.com/hobbyking/s...Mount_Set.html
What do you think about it?
Jorgemaria is offline Find More Posts by Jorgemaria
Old Nov 29, 2012, 11:47 AM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
its great plug in tail if you use carbon fiber tubes to make tri
abletowinginc is offline Find More Posts by abletowinginc
Old Nov 29, 2012, 12:44 PM
pcaffeldt is offline
Find More Posts by pcaffeldt
Arizona Rim Country
Joined Nov 2001
OK - here's a little tweek that might be of interest
http://www.gizmag.com/hytaq-rolling-...m_medium=email
pcaffeldt is offline Find More Posts by pcaffeldt
Old Nov 30, 2012, 06:57 PM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
Well it sure looks nice
BigJimNZ is offline Find More Posts by BigJimNZ
Old Dec 06, 2012, 01:45 AM
WonderKing is offline
Find More Posts by WonderKing
WonderKing's Avatar
Indonesia, Jakarta
Joined Sep 2012
how do you all find the CG of a tricopter ? does it like quads that just need to draw a straight line between motors and find the center
WonderKing is offline Find More Posts by WonderKing
Old Dec 06, 2012, 07:19 AM
Joined Jun 2009
i find that i make it tail hevy to add photo equip to front...... but depends on your needs..
Old Dec 06, 2012, 11:54 AM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
I believe it is. Equally important is the placement of the flight controller as close to the frame cg. Adding gear should be functional for visibility and clear radio transmission for FPV etc... But then use none location critical equipment to balance the tri, such as the battery, equally front or back and side to side. A flight controller can compensate to a degree but efficiency will drop if your frame is unbalanced. A tail heavy tri will fly but the rear motor will have to work harder to level off. A good cg and balanced multi will hover hands off without trimming to compensate and fly longer on the same charge.
H
shelterock is offline Find More Posts by shelterock
Old Dec 06, 2012, 11:59 AM
Joined May 2011
Another observation, tris like the weight to be more on the front motors because you get a drop in lift efficiency with a tilting rotor in the rear. So I find my tris are balanced better and fly better with a slightly forward cg of dead center to the 3 motors. I can't confirm that scientifically. Just an observation. In my talon tricopter the controller is further forward of the center of the 3 motors and it works well when the cg is on the flight controller than over the dead center of the 3 motors.
H
Old Dec 06, 2012, 04:48 PM
jbalat is online now
Find More Posts by jbalat
Joined Feb 2011
I have found a cg in the center or slightly back causes pitch up..
A forward cg is definitely better in my case.
Can anyone confim ?
jbalat is online now Find More Posts by jbalat
Old Dec 06, 2012, 08:30 PM
d_wheel is offline
Find More Posts by d_wheel
Old fart. VAAATSP
d_wheel's Avatar
Deep in the Heart of Texas
Joined Jun 2004
Can anyone confim ?
You may be correct. I have always balanced in the center and definitely get pitch up. I'll try moving it forward and see what happens. Do you have a formula for how for forward to go?
Later;
D.W.
d_wheel is offline Find More Posts by d_wheel
Old Dec 07, 2012, 01:54 AM
Joined Feb 2011
Later;
D.W.
Yep...Trial and error
I just replaced my 11x4.7's with 9x4.7's..
I can honestly say it flies much better both in fast flight and hover. I still have to try it in windier conditions and compare flight times, but there was more than enough lift at similar throttle position which makes me think that maybe the bigger props were not running at their most efficient load and speed.
Dont worry it wasnt my idea, I noticed David uses thes props on the rc explorer build. I assume they behave better in the wind and they are quicker to react to changes in engine speed since they dont carry as much inertia ?
Old Dec 07, 2012, 05:20 AM
WonderKing's Avatar
Indonesia, Jakarta
Joined Sep 2012
so how do i can find the center then? do i need some Pythagoras calculation
Old Dec 07, 2012, 12:18 PM
JNJO is offline
Find More Posts by JNJO
Done Posting, Gone Flying
JNJO's Avatar
Sweden, Uppsala County, Balsta
Joined Jun 2012
@Wonderking
I'm guessing this is your first Tri build, so forgive me if I'm bloating.
Keep it simple.
Make your booms equal in length (Motor shaft to inner end. You have to account for the yaw mechanism on the tail boom) and space them 120 degrees apart. If you can, use 10mm square pinewood for booms
The geometric center is where the booms meet, if you imagine a line continuing from the inner boom end.
Try to keep your CoG close to this point, and design your LiPo-holder so you can shift the CoG later with the battery.
I just drew a line on the frame at this point, and check the pitch balance by holding my fingers there. For roll balance, I put one finger under the front center of the frame, and another finger under the tail boom.
Small variations in CoG are not critical to get a Tri airborne and resonably flyable.
Far more important are good ESC:s, Motors, flight controller, balanced props of right size for your build, and preferably no vibrations.
Safe landings,
/J
JNJO is offline Find More Posts by JNJO
Old Dec 07, 2012, 07:17 PM
Joined Feb 2011
If you have a complex setup then i would create 3 points in space on a cad program.
Measure distances from motor to motor and feed these back into cad. Join the 3 points with a circle and then you can find the center of the circle !!
Use the radius from this circle to swing a string from each motor. Where they intersect is the cg..
Old Dec 07, 2012, 09:53 PM
Joined Feb 2011
Yep much better in the wind. Just tried it in 25 knots, had to keep the nose down about 45deg to hover in the one spot and it would only glitch a little when gusts came through.
Anyone else using smaller props with dt750's ?
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
