Old Nov 04, 2012, 04:42 PM
Appie is offline
Find More Posts by Appie
Appie's Avatar
The Netherlands, DR, Emmen
Joined Aug 2002
Yeah, work allways gets in the way :-)
Just put it together and fly it.
Have fun,
Albert
Appie is offline Find More Posts by Appie
Old Nov 05, 2012, 10:08 PM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
which would be a better motor for this tri of these 2 motors http://www.hobbyking.com/hobbyking/s...arehouse_.html
or this one
same kv but what would be benefit of one over the other
abletowinginc is offline Find More Posts by abletowinginc
Old Nov 05, 2012, 10:35 PM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
or this one
I'm using the NTM 28 x 30 motors on my current tricopter. Im happy with them. Don't forget to order the accessory package for the motor as they come with nothing. The former is a bigger motor with a bit more torque but the wattage goes up with that so they're a bit hungrier.
You could use the good old DT 750. No prop adapters etc needed with GWS 11 x 47 props.
I used to use a standard size servo on my earlier tri's. Pretty hard to wreck in a crash compared to a 9 grammer.
You can mount it in the main frame and run a push rod to a crank at the end of the tail boom to keep the weight forward.
I think there's some pics on my blog here at RCG.
Have a look at "Tricopter builders"on Facebook there's a few examples of others builds there for some ideas.
Post some pics for us as you build so we can give you a hard time.......sorry I mean help you out lol
Good luck
Ian
BigJimNZ is offline Find More Posts by BigJimNZ
Old Nov 06, 2012, 09:47 AM
d_wheel is offline
Find More Posts by d_wheel
Old fart. VAAATSP
d_wheel's Avatar
Deep in the Heart of Texas
Joined Jun 2004
i read the startof this thread and i have some questions. i have built quads but noticed here he built his with seperate gyros. could you use a kk board to make this type of tri?if so where would the servo be plugged into?very interested considering build right now
My tri has never flown as well with the KK board as it did with gyros. I'll probably be switching back and chunk the KK into the trash.
Later;
D.W.
d_wheel is offline Find More Posts by d_wheel
Old Nov 06, 2012, 11:01 AM
Joined Jun 2009
Later;
D.W.
thats odd the kk boards work super on every quad i ve built? seems they would do fine on a tri
Old Nov 06, 2012, 12:02 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Later;
D.W.
Are you flying it with an acro or heli mix ?
Old Nov 06, 2012, 05:03 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
I agree Gyro was the best. I have one tri flying with KK now, its pretty good but still not perfect. I am also having problems with multiwii. Gyros were nice and simple. Lucky I kept them
jbalat is offline Find More Posts by jbalat
Old Nov 07, 2012, 12:22 AM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Blast from the past
Tricopter FFF.AVI (2 min 22 sec)
Old Nov 07, 2012, 03:49 AM
jbalat is offline
Joined Feb 2011
Hey Ian that thing flies like its on rails !!!
All i get now is lots of time tweaking, flashing and trying to eliminate wobbles
Bring Back the Gyros !!
Old Nov 07, 2012, 04:02 AM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
All i get now is lots of time tweaking, flashing and trying tomeliminate wobbles
I know what you mean John. Sometimes multiwii does my head in too.
Most of my struggles have been caused by resonance. I'm extremely happy with the way my tri is flying now but it took a
long time to crack it. That gyro tri was a dream but we gotta keep buggering about with stuff ......will never learn !!
Old Nov 07, 2012, 06:14 AM
Joined Jun 2009
Originally Posted by BigJimNZ View Post
nice tri looks good
Old Nov 07, 2012, 09:11 AM
d_wheel is offline
Old fart. VAAATSP
d_wheel's Avatar
Joined Jun 2004
Also tried it on a quad with the same results. There is no way to get rid of the constant rocking. Even when the pots are so low that the bird is very unstable it still rocks.
Later;
D.W.
Old Nov 07, 2012, 09:12 AM
d_wheel is offline
Old fart. VAAATSP
d_wheel's Avatar
Joined Jun 2004
Please explain.
Later;
D.W.
Old Nov 07, 2012, 12:17 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Please explain.
Later;
D.W.
Are you using a helicopter 1 servo swash mix in your radio or an acrobatic ( aeroplane mix )
Not that it makes much difference to the constant rocking.
I couldn't get my tri to fly well without using the heli mix. Even then the last one I made with an HK KK V3 board was still
rocking around. Still flying arduino with Nintendo bits.
Anyone using the KK2 with LCD ?
Old Nov 07, 2012, 06:25 PM
d_wheel is offline
Old fart. VAAATSP
d_wheel's Avatar
Joined Jun 2004
OK. I have it in acro mode, no mixing. How did the heli mix help you?
Later;
D.W.
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
