Old Jan 18, 2010, 06:44 PM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Originally Posted by bajas View Post
I just have some props to balance and some good weather!!!!..
This will be the most existing maiden EVER....hehehe..
I made it big, didnt cut the carbonrods from HC. 750mm long arms.
I just have one problem left.. The antenna. Where do i put it,????
THANX 1000000000 Signguy for inspirations and everybody else for all help... This is a fantastic thread...
Bajas, nice build there.
Just run the antenna along the edge of the top and bottom surface.
IMO that servo is not suitable. Use metal gear.
Your gyros are not really aligned with the arms. It is not straight.
Like Joshbb said, mounting gyro on the arm would subject it to more vibration.
No space to put on the center piece?
etman is offline Find More Posts by etman
Old Jan 18, 2010, 06:54 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
etman - I have used the same servo and it will work just fine as long as there are no really hard landings - Don't ask how I know.....
cdi3d is offline Find More Posts by cdi3d
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
you could also run the wires outside the arms, then go to home depot or a diy type store and pick up some florescent light lexan covers. These things are reasonably light, clear, strong, and when split length wise they curl up tightly like wire loom wrapping. I haven't tried it, but it should work. If I were going to hide wires I'd use aluminum, or woven carbon.
signguy is offline Find More Posts by signguy
Old Jan 18, 2010, 06:55 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Dihedral
Dihedral on short armed tricopter vs long armed tricopter.
I suppose a short armed tricopter would need dihedral more than a long armed one. It could make a small tricopter more stable.
Any comment on that one?
Old Jan 18, 2010, 07:00 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
As stated earlier in this thread, the dihedral would help in a hover but a hindrance in forward flight. IMHO.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jan 18, 2010, 07:15 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
The reason I asked was if you wanted to make a small tri for indoors flying, a faster acting "brain" would be needed. Something that these simple cheap gyros can't do fast enough. And wouldn't dihedral make it more self stable and require less input from the gyros.
Old Jan 18, 2010, 07:24 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
I just found a tricopter frame I made three years ago. It had a motor shaft to frame center length of 8.5". This had GWS pg-03 gyros on it !!
I remember it being a bear to fly, but it did. I've made telebee tri's down to 12"radius. It seems hard to find a small low kv motor, that would make a really small tricopter easier to tune.
Old Jan 18, 2010, 07:28 PM
Joined Aug 2009
May be the answer is a higher KV and a smaller pitch diameter on the blade?
Old Jan 18, 2010, 07:31 PM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Yes difficult to find a low kv motor that is light also.
How about GWS gear reduction drives?
One the other hand a 12" arm tri on cheap gyros may be small enough for large rooms.
This small 25g 1200 kv motor was used by one of the reviewers for a quadcopter on 2s lipos.
http://www.hobbycity.com/hobbycity/s...r_Motor_1200kv
7x3.5/3S or 9x4.7/2S
Another one, a 1450 kv, 19 g motor, for 3D planes.
http://www.hobbycity.com/hobbycity/s..._19g_Outrunner
8040/2S or 7035/3S
Ok so on this thread will we have a monster tri and a tiny tri?
Old Jan 18, 2010, 09:30 PM
Talontsi96 is offline
Find More Posts by Talontsi96
Talontsi96's Avatar
Edmonton, Alberta, Canada
Joined Jun 2004
Originally Posted by cdi3d View Post
I agree with Bob - I have been using wood plugs through my HK CF arms to reduce the amount of splitting that occurs where you drill it - I have been using it on my SS for a longtime and unless it has the wood dowel gorilla glued in will split very easily - I am working on a new tri that uses these CF arms and would love to run the wires inside I just can't risk the integrity of the arm to hide a few wires - Just my 2cents
I can be pretty inventive... ... I have also successfully drilled 8 mm diameter carbon fiber tubes before without splitting them...Tubes are a lot harder to drill than square channels.. but I have not worked with the HK stuff so maybe I'll have a nasty surprise. I use a drill press and take my time and it usually works... the edges can be covered with CA as CA sticks to CF like nothing else... I'm open to other ideas though.... I like the home depot solution...
Talontsi96 is offline Find More Posts by Talontsi96
Old Jan 18, 2010, 09:31 PM
signguy is offline
signguy's Avatar
Joined Dec 2004
here is an easy way to hide your wires and speed controls. Just wrap the arms in florescent safety light bulb covers. These are made of Lexan, just cut them down the length, then they tend to curve tightly to attach to the arms without any mounts needed. I have not flown these, but the only problem I could see is overheating the speed controls. You could very easily cut ventilation holes in the tubing over the speed controls.
I did wrap them with vinyl before cutting them. You could paint the inside or outside with krylon "fusion" plastic paint. Rustoleum also makes a plastic specific paint that works great too.
Only adds a couple ounces..
Old Jan 18, 2010, 10:51 PM
flyingdogfilms is offline
Find More Posts by flyingdogfilms
Joined Mar 2009
Awesome, I'm sold. And so is everything in my shopping cart. Whats the lagtime usually getting these to the US? Bought some stuff to start working on the frame while I wait.
DO IT!!
tricopter advantages
1 easier orientation
2 25% less likely to suffer motor failure
3 faster yaw rates
4 cheaper
5 looks COOL
quad advantages
1 more lift for the same motors
2 more options with MK or other boards
disadvantages
1 slow yaw rate ( from what I've seen )
2 have to have counter rotating props ( not many sizes available)
3 hard to see which way its going
4 $$$$$$$$$
5 in + config, you will see a motor in front of the camera
Tricopter disadvantages
1 Yaw servo ( not really a disadvantage, I've never had one fail in flight, and I use cheap servos)
2 slightly less efficient
3 less options for GPS, autopilot........ unless you are a real DIY'er
Thats how I see it. Some may blast me for it, so go ahead!
flyingdogfilms is offline Find More Posts by flyingdogfilms
Old Jan 18, 2010, 11:32 PM
Duck! is offline
Find More Posts by Duck!
It flew...nearly!
Norway
Joined Apr 2006
Question regarding the yaw servo. How much power/what size is sufficient? I have a standard Hitec HS425? but it really seems big and heavy for this purpose. Is the Hextronic 900 really sufficient? Suggestions, preferably available from HC?
Cheers,
matthew
Duck! is offline Find More Posts by Duck!
Old Jan 19, 2010, 12:16 AM
Talontsi96's Avatar
Joined Jun 2004
Cheers,
matthew
Good question, I'd like to know as well. What is the smallest metal gear servo that will work?
Old Jan 19, 2010, 08:07 AM
signguy is offline
signguy's Avatar
Joined Dec 2004
Cheers,
matthew
Depends on the motors used. If you are using the DT750 or something of the same size/power, a HXT 9g metal geared servo is not big enough. I use a full size futaba s-28 servo for my DT 750 machine. I do use a HXT 9g metal on my floater jet powered machine. 100 watts or less go with the HXT 9g any more you need a bigger servo. The full sized servo is not too large to put back there, you'll need it to balance out the camera!
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
