Old Apr 29, 2012, 04:24 AM
Fubar 123 is online now
Find More Posts by Fubar 123
Fubar 123's Avatar
Whitchurch,Shropshire. UK
Joined Jul 2008
Originally Posted by faheja View Post
So put the trim in the middle and shoot it straight up as fast as i can? So you're saying regardless of the trim it should go straight up right?
I have a set of new motors, diff. ones though. This weekend i'll put those on and see if it makes any difference. I think you're right..It HAS to be one motor not being able to withstand the other two.
Just ordered 3 new motors for spare anyway. Will try all new motors and see if it still does it
Just guessing, is it anything to do with the lowpass filter setting ?
Fubar 123 is online now Find More Posts by Fubar 123
Old Apr 29, 2012, 07:47 AM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
I had similar issue that was resolved with the transmitter stick centering. I fly a flysky ER9X and with everything balance on the CG I was getting a forward and left drift. Stick centering showed that with neutral trims my sticks were forward and left. Once I centered them in the software in the transmitter, I was golden, no more drifts.
If there was something wrong with the motor or ESC it would be much more dodgy. If the ESC throttle range was wrong you would get a more drastic effect.
My Thoughts,H
shelterock is offline Find More Posts by shelterock
Old Apr 29, 2012, 11:20 AM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
Some of the KK board trim or stick centre problems may be due to the KK board's AVR processor clock. This is a simple internal oscillator that has fairly loose tolerance and the clock frequency can be off by several percent, leading to incorrect stick position measurement. On my HK KK 2.1 board with KK v1.6 firmware, the firmware thinks my sticks are centred (1500us) when my TX/RX actually put out 1465us pulses.
I've got the mechanical CoG about right, but to make it hover nicely I need about 24 ticks of subtrim forward elev, left aile and left rudd (70% travel, 100% rate, 20% expo) on my DX6i, only because the board is "misinterpreting" the stick positions.
This is a fair bit of permanent correction, and requires subtrim (not trim) to shift the entire stick output to match what the KK board expects. I use a couple of clicks of trim to compensate for small amounts of drift.
The "correct" solution is to tweak the processor's clock oscillator frequency in software, which requires a couple of extra lines of code and a bit of trial and error. The oscillator is actually calibrated to within a few percent during manufacture, but this is at 3V supply. At 5V supply (like the KK board uses) the oscillator actually runs a bit fast, but it also varies a bit with temperature.
mattcro is offline Find More Posts by mattcro
Old Apr 29, 2012, 01:33 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Hadn't flown a tri for quite some time as I normally use a couple of quads.
Decided it was time I built another tri for old times sake.
This is a video of the maiden flight which took place some time ago.
Flying with just a basic wii motion plus setup. It also has accelerometer and magnetometer but these were switched off for the first flights.
Flew the tri several times and then......... took it apart and decided to make a folding quad !
It was very stable, especially with auto level and heading hold but...... I just like quads more.
I guess it's an age thing !
http://vimeo.com/41210412
sparklet is offline Find More Posts by sparklet
Old Apr 30, 2012, 01:36 AM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
Search of down plane
Chipped a prop on the first flight...sorry for the jello
I have flown slope for many years in a small town of Fults Illinois. The hill is a Bluff, and as you can see every hill in the Mid West is covered with trees. Two weeks ago my buddy and I were racing our slopers on the hill. We collided on a turn. I was able to fly it out down to the farm land. My buddy flew off back into the hill. We spent several hours looking for his plane. I went back with the FPV Tricopter for a search of it, and had some fun.
If your interested in slope soaring check out my video #64 "Nose into the wind"
FPV FULTS (4 min 11 sec)
Eternalflight is offline Find More Posts by Eternalflight
Old Apr 30, 2012, 06:46 AM
jbalat is online now
Find More Posts by jbalat
Joined Feb 2011
Nice videos. I just bought a speedo from r2hobbies looking forward to some sloping soon. Some really high flying with the Tricopter, you must have nerves of steel !
jbalat is online now Find More Posts by jbalat
Old Apr 30, 2012, 08:33 PM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
http://vimeo.com/41267081
That video looks good. Did you get that focus issue sorted or is this pre issue time
BigJimNZ is offline Find More Posts by BigJimNZ
Old May 01, 2012, 01:08 AM
Joined May 2008
LOL!
I love flying that high, I wish sometimes I would slow down some and take in the view a little longer. I was a little over a mile out at times, and 600' - 800'. I use the Skylark AAT tracker with Trace OSD. There was a group buy, and I was able to get it for 100.00 discount and free shipping. It's been nice to work with so far.
http://www.skylarkfpv.com/store/inde...&product_id=71
The one that is giving me issue's is my oldest Go Pro with sunnex lens. My wife gave me the Go Pro 2 as my Birthday, Valentines, and Anniversary gift. She works at Target and was able to get her discount. The Go Pro 2 sure has some nice clarity to it. Easier to work with, with the extra features.
Old May 04, 2012, 06:56 PM
babanan is offline
Find More Posts by babanan
Joined Mar 2011
I have started to build a tricopter now and I received my Hobbyking v2 board today.
When about to flash the firmware there were a lot of options and I wonder which one to pick. Is it v1.6 or v2.5? or maybe another version?
Here is a screenshot showing some of the options:
babanan is offline Find More Posts by babanan
Old May 04, 2012, 08:31 PM
Joined May 2011
I used KapteinKuk 1.6 and had gyro reversing issues with 2.5 Kr-XX. 1.6 is easy to set up and configure. flies great.
Old May 04, 2012, 08:55 PM
Joined Feb 2011
While we are at it which one do you recommend for xcopter hkss25 esc's ?
I had issues with kk4.7, I have loaded minsoo 2.5 but haven't fired it up yet
Old May 05, 2012, 09:35 AM
Joined Feb 2011
Just as I thought I finished my tricopter I broke the servo arm. I decided to rip the servo out which was really struggling in there and add another motor.
Hopefully it will work as a Y4
UPDATED Sunday 6-May...........
Guys if you can have a look and recommend what I have done wrong here. The Y4 did not want to fly
Like I said I lowered my P values down to 3 because I was getting some oscillations at 4.2. Not sure if I went to low or whether there are other factors at work here?. Maybe arms are too short (about 29cm) BTW I really hate to rear prop being so close to the ground.
Failed attempt at MultiWii Y4, P Value too low (0 min 45 sec)
Old May 06, 2012, 08:26 AM
GallopingGhost is offline
Find More Posts by GallopingGhost
Joined Sep 2005
There has been a lot of time since this thread was started. Does anyone have a updated list of Hobby King parts that are most current and proven?
GallopingGhost is offline Find More Posts by GallopingGhost
Old May 06, 2012, 05:29 PM
tarheal63 is offline
Find More Posts by tarheal63
tarheal63's Avatar
United States, TN, Murfreesboro
Joined Mar 2010
Well, I have gathered all of my parts almost, waiting on some to be shipped, and here is my list of things, I hope I chose wisely
3x 30A ESC's
http://www.dealextreme.com/p/mystery...s-34338?item=6
3x 2830-8 motors
http://rctimer.com/index.php?gOo=goo...0&productname=
5.5 KK Blackboard with usb programmer,
3x 1/2" basswood square rods from hobby lobby
1x 12g TP metal gear servo
10x 8/32 bolts with lock nuts from home depot
rcexplorer cnc cut body from rcgroups.
tarheal63 is offline Find More Posts by tarheal63
Old May 06, 2012, 11:27 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Did everyone find the best esc placement was on the arms near the hub? Was FPV EMI any challenge. Any alternate designs that work well?
Also, what color schemes did you find optimal for orientation?
I imagine 3 colors each for arms, plus maybe top/bottom differentiation, such as black bars on the bottom.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 06:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 10:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 09:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 05:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 05:10 PM
