Old Apr 25, 2012, 11:58 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Originally Posted by Fubar 123 View Post
Looking good
Cheers
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Apr 26, 2012, 12:09 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Just a not on Balance. A really good idea is to get your copter flight ready, batteries and all and do a balance test. This can be done pretty easily.
If you have electronics on the top, then spin the copter over and put a screw right on the centre that is strong enough to hold the weight. Then tie some string to the screw and hang the copter from something. This will give you an exact indication of where the weight is being distributed. Keep making changes to where things sit until you get it as close to the centre as possible.
If you haven't got electronics on top, then put the screw in the top. If you can't screw into your frame, or don't want to, then try balancing the copter on something right in the middle.
Its quick, cheap and easy.
Just make sure you have your battery and camera gear etc onboard, or you will throw it out later when you add them.
The_Mongrel is offline Find More Posts by The_Mongrel
Old Apr 26, 2012, 03:17 PM
faheja is offline
Find More Posts by faheja
faheja's Avatar
United States, CA, Laguna Hills
Joined Sep 2011
Originally Posted by BigJimNZ View Post
Probably not the cable dude. Swap your motors around from arm to arm and see if it follows.
Do the same with your esc's. What esc are you using ? What motors ?
Check you have no sue trims on your mix that you dont know about.is your radio calibrated at mid stick ?
Just some things to think about
using sunnysky 980kv motors, 10x4.5 props, 18 turnigy plush esc's. Radio is rds8000, and i have mixing turned off, set and set to 0. Just always has that tiny bit of tilt. I bought a new set up motors that i will try tonight on it to see if it makes a difference. Don't know why it would but anything can be possible.
faheja is offline Find More Posts by faheja
Old Apr 26, 2012, 03:19 PM
faheja is offline
faheja's Avatar
Joined Sep 2011
Originally Posted by TheNiceGuy View Post
CoG ok? Motors , Props, escs samebrand and free from binding etc? I'm using firmware 1.1 kk with all same rotation props. Gyro problems wouldnt cause a continual lean like that, you'd be getting jerking etc
Maybe your model's yaw and roll are not trimmed properly?
CoG is perfect. I have to keep it trimmed all the way to the right to make it JUST about perfect. Still a dot of drift to the left though. Just don't understand why i'd need to have it set up like that.
Old Apr 26, 2012, 04:47 PM
faheja is offline
faheja's Avatar
Joined Sep 2011
right now on my blackboard 5.5 i have version 1.5. Is v1.6 a lot better?
Old Apr 26, 2012, 08:24 PM
Joined Dec 2007
Have you calibrated the ESCs?
Old Apr 26, 2012, 08:44 PM
Expat
Japan
Joined Apr 2010
Both CoG perfect both for pitch and roll?
Picture? Flight video?
Old Apr 26, 2012, 10:48 PM
faheja is offline
faheja's Avatar
Joined Sep 2011
Yep, Esc's are calibrated
Old Apr 26, 2012, 10:55 PM
faheja is offline
faheja's Avatar
Joined Sep 2011
Picture and flight video coming!
Old Apr 26, 2012, 11:41 PM
faheja is offline
faheja's Avatar
Joined Sep 2011
http://www.youtube.com/watch?v=Bstpa...ature=youtu.be
At 30 seconds i let go of the sticks. Hovers pretty good in one spot. Would like that extra click of trim
http://www.youtube.com/watch?v=PBjzY...ature=youtu.be
at 16 seconds i let go and you can see it shoots to the left and forward. I have the trim on this video set to the middle on my TX.
Pictures
http://i9.photobucket.com/albums/a63...g?t=1335495801
http://i9.photobucket.com/albums/a63...g?t=1335495792
Any ideas?
Old Apr 27, 2012, 11:26 AM
flyerdiver is offline
Find More Posts by flyerdiver
flyerdiver's Avatar
Lafayette,CO
Joined Jan 2009
Have you switched the motors and escs around to see if the problem follows the change. I have had bad motors before that just wont stand up to he other two. Take it outside and goose the power. If it shoots up strait the motors should be good. If it wants to roll hard to that side then the motor may be bad.
flyerdiver is offline Find More Posts by flyerdiver
Old Apr 27, 2012, 12:13 PM
faheja is offline
faheja's Avatar
Joined Sep 2011
So put the trim in the middle and shoot it straight up as fast as i can? So you're saying regardless of the trim it should go straight up right?
I have a set of new motors, diff. ones though. This weekend i'll put those on and see if it makes any difference. I think you're right..It HAS to be one motor not being able to withstand the other two.
Just ordered 3 new motors for spare anyway. Will try all new motors and see if it still does it
Old Apr 27, 2012, 03:54 PM
flyerdiver's Avatar
Lafayette,CO
Joined Jan 2009
Well get it trimmed up so it is flying as level as possible. If its wanting to roll to the left without trimming it I would think it would want to roll really hard left at high power. Try switching to motors around though, and then try switching the esc around. Isolate the problem component and replace it.
Old Apr 27, 2012, 07:34 PM
Joined Dec 2007
My only other advice is to fly outside. There is going to be a hello of a lot of backwash in that room. Get it out in the open air - see if that makes a difference.
Old Apr 28, 2012, 05:11 PM
mr.incredible is offline
Find More Posts by mr.incredible
An ordinary sort of incredible
mr.incredible's Avatar
United States, TN, Knoxville
Joined Dec 2004
I wouldn't do that. I often have to give it a little test lift to make sure everything is lifting squarely. Some times the first lift-off is a little skewed. One arm lifts a little harder than the others. I just give it a little bit of stick to correct it and and land. Then I can lift-off straight up. I don't use ACCs, just multiwii with original WMP.
mr.incredible is offline Find More Posts by mr.incredible
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 06:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 10:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 09:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 05:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 05:10 PM
