Here is a vid after I pulled and cleaned the lens and set it as sharp as I could.
Joined Mar 2011
Japan
Joined Apr 2010
First stable flight yesterday. Most of the moving around is either the wind or my sticks for a change. Thanks for your help everybody.
I ran out of props with all the crashing, so 1047s on the front and an 1147 on the tail. I still notice weaker to recover from right slide than left. Is this a normal prop rotation issue? Also, roll gyro maxes at about 50%, even just for hover. While the pitch and yaw in this video are at 2/3, and can be at 100% for hovering. Is that disparity normal?
Question about my tri. I've been flying for quite some time now but the trim of it is driving me crazy. I have to keep the right stick trimmed 100% to the right. If if is, its just about perfect.. maybe a little tilt still to the left, but nothing that i can't correct when flying. Why would it do that?
Front right motor is CCW, esc's are calibrated perfect.. Could it be a difference in the motor maybe? maybe my right motor just isn't up to par with the other two? It would be nice to be able to give it that 1 extra click of trim! ;p |
Japan
Joined Apr 2010
CoG ok? Motors , Props, escs samebrand and free from binding etc? I'm using firmware 1.1 kk with all same rotation props. Gyro problems wouldnt cause a continual lean like that, you'd be getting jerking etc Maybe your model's yaw and roll are not trimmed properly? |
Do the same with your esc's. What esc are you using ? What motors ? Check you have no sue trims on your mix that you dont know about.is your radio calibrated at mid stick ? Just some things to think about |
| Thread Tools | |
| Discussion Yet another tricopter build. !!Updated parts list!! | SebastianJ | Multirotor Talk | 2669 | Dec 30, 2011 05:48 PM |
| Discussion What to do? Failed tricopter build! | Razor_Racer | Coaxial Helicopters | 9 | Mar 07, 2011 09:20 AM |
| Discussion Tricopter Build | Razor_Racer | Coaxial Helicopters | 21 | Feb 20, 2010 08:24 PM |
| Build Log Tricopter build | SebastianJ | VTOLs | 1 | Dec 22, 2008 04:34 PM |
| Discussion Trying to build a mechanically actuated tricopter, Help! | stefalo | Coaxial Helicopters | 3 | Jan 09, 2008 04:10 PM |
