Old Jan 18, 2010, 08:33 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by etman View Post
My first maiden outdoor flight!
Video uploading soon.
http://www.vimeo.com/8807891
Great Job and an Awesome build. I also love the bumper design, should be great for indoor flight too.
thank you so very much for sharing this video with us, it is greatly appreciated.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jan 18, 2010, 08:52 AM
etman is offline
Find More Posts by etman
Flying with the eagles
etman's Avatar
Eagle's nest
Joined Nov 2008
Originally Posted by AC5FF View Post
etman - great job!!! Looks like it's flying pretty darn good for ya! I love the look of your 'bumpers' around the edges! A hulahoop eh?? Awesome idea!!! You'll have to get it up in the air and then give it full rudder - see if you can the hula-hoop effect going on vid. LoL
Thx for your input on my gain question.... Will try to get out again tomorrow and give that a try
Thanks AC5FF and RR!
When I bought a red hulahoop my little boy liked it so much and played with it.
Haha...I had to sneakily cut it into three pieces when he was not around.
After that I bought another one for him.
etman is offline Find More Posts by etman
Old Jan 18, 2010, 08:57 AM
Joined Aug 2009
Bad ETMan, Bad. LOL
I hope you purchased the kid a new and better one.
Old Jan 18, 2010, 09:00 AM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
Originally Posted by reverendrichie View Post
Bad ETMan, Bad. LOL
Heheheh....(evil laugh)
Old Jan 18, 2010, 10:52 AM
TexasPete is offline
Find More Posts by TexasPete
TexasPete's Avatar
Houston, TX
Joined Aug 2004
Originally Posted by Pepelatz View Post
Pepelatz,
I stand corrected. Would you happen to know the model and Availability of the motor used? Bet it would make an exceptional tricopter motor!
Texas Pete
TexasPete is offline Find More Posts by TexasPete
Old Jan 18, 2010, 11:20 AM
etman is offline
etman's Avatar
Eagle's nest
Joined Nov 2008
My build blog here.
http://www.rcgroups.com/forums/showp...23&postcount=1
A total success, no damage sustained, not even a prop! This is attributed to the bumper, the foam landing gear and foam base. All this despite a windy day, leaves in the trees were swaying.
I had a lot of altitude excursions, suddenly up and down, due to the windy gusts and my inexperienced handling.
Thanks signguy and others for your help.
I experienced that near the end of a battery, before the Lipo alarm is even sounded, the tricopter motors are unstable and causes a twitching action.
This has nothing to do with gyro gain as it is stable throughout. This does not happen when the battery is fresh. I suspect the low voltage to the BEC causes the receiver, gyros, esc leads to be underpowered and glitchy.
1. Should I go with a separate battery for the BEC, maybe a 800 mah?
2. I can add a resistor to the lipo alarm to make it sound at a higher voltage by thinking it is at a lower voltage.
Old Jan 18, 2010, 11:23 AM
Dave Barrow is offline
Find More Posts by Dave Barrow
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
etman, congrats on the maiden. Those bumpers look great, I'll have to make a run to the toy store to get one.
Dave
Dave Barrow is offline Find More Posts by Dave Barrow
Old Jan 18, 2010, 11:57 AM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
Any one have an extra UBEC that they would part with? LHS is out and I need one for a new build - Thanks
cdi3d is offline Find More Posts by cdi3d
Old Jan 18, 2010, 11:59 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Sebastian,
Looks pretty stable for a very small sized tricopter compared to most other tricopter videos I believe you used the old Wolferl UAVP v3.15 tricopter firmware for the mini-tricopter setup in this video? http://www.rcgroups.com/forums/showt...3#post11709393 I would like to suggest that you use Prof Greg's latest UAVX v1.891 firmware. You would have to upgrade your PIC to the 18F2620 to use the UAVX firmware. If you can't source and burn your own PIC, the 18F2620 plugin replaceable PIC processor is available preloaded with UAVX firmware at www.quadroufo.com for $15. The parameters have been rescaled and are somewhat different from the old Wolf UAVP firmware. Also for smaller quads and tricopters with less than 20cm motor to motor on axis spacing, the I2c ESC's, which the UAVP board can also use, might be more appropriate for even smoother flight. The standard ESC's such as Turnigy Plus, HCSuperSimple and Towerpros do fine with motor spacings greater than 20cm motor to motor on axis.
Cheers,
Jim
Originally Posted by bas10an View Post
UAVP micro tricopter, very unstable due to the small size, 15cm center to axle.
http://www.youtube.com/watch?v=kz1jel6ssDc
Sebastian.
jesolins is offline Find More Posts by jesolins
Old Jan 18, 2010, 03:20 PM
Talontsi96 is offline
Find More Posts by Talontsi96
Talontsi96's Avatar
Edmonton, Alberta, Canada
Joined Jun 2004
Yessss.....My parts from Hobby King arrived today...Yippee!!! Now I just gotta wait for the frame components from Jimto show up and we're off to the races......
Talontsi96 is offline Find More Posts by Talontsi96
Old Jan 18, 2010, 03:49 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
I bet you could get a wooden or foam frame together before the other one arrives.
signguy is offline Find More Posts by signguy
Old Jan 18, 2010, 03:52 PM
Joined Aug 2009
Or even a Curtain Rod frame. LOL
Old Jan 18, 2010, 03:54 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
I agree with Bob - So easy to swap out frames once you have all your harness's made - I am almost done with another one dedicated to 2 gyros and FMA copilot - Decided it will be a good one to work on my forward flight with - I bought some of those RCtimer motors and while they are lacking the same power that the DT750's have they are working ok - Again trying to go as light as possible - I have removed most of the bullet connectors in hopes of saving a little weight - -
Old Jan 18, 2010, 04:02 PM
Joined Aug 2009
Which RCtimer Motors do you have?
Old Jan 18, 2010, 04:14 PM
cdi3d is offline
Brushless
cdi3d's Avatar
Joined Mar 2009
The 750kv's listed in the earlier post -
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 06:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 10:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 09:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 05:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 05:10 PM
