Old Feb 05, 2012, 03:38 PM
signguy is offline
Find More Posts by signguy
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Originally Posted by coolbudz223 View Post
I like that idea, looks pretty cool
could also use styrofoam........
Fun Copter (5 min 7 sec)
signguy is offline Find More Posts by signguy
Old Feb 05, 2012, 07:52 PM
mr.incredible is offline
Find More Posts by mr.incredible
An ordinary sort of incredible
mr.incredible's Avatar
United States, TN, Knoxville
Joined Dec 2004
http://vimeo.com/9182011
Yes, like that. Maybe a little bit more detail. I was thinking of maybe one of those foam hand launched gliders. That and a hot wire foam cutter.
mr.incredible is offline Find More Posts by mr.incredible
Old Feb 06, 2012, 10:12 PM
CoolBudz is offline
Find More Posts by CoolBudz
RCPlaye
United States, CT, East Hartford
Joined Aug 2009
you'll never lose your orientation with that
CoolBudz is offline Find More Posts by CoolBudz
Old Feb 07, 2012, 11:05 AM
jfcomg is offline
Find More Posts by jfcomg
jfcomg's Avatar
Mexico, JAL, Guadalajara
Joined Nov 2010
This is a short vid having fun with the tri.
having fun tricopter.avi (3 min 6 sec)
jfcomg is offline Find More Posts by jfcomg
Old Feb 08, 2012, 12:37 PM
flyerdiver is offline
Find More Posts by flyerdiver
flyerdiver's Avatar
Lafayette,CO
Joined Jan 2009
Originally Posted by opus View Post
GLB has some pretty cheap. Lot's of sizes. I also see they now carry black nylon. (About a week after I ordered mine)
Thanks, I'll check that out opus.
-Mike
flyerdiver is offline Find More Posts by flyerdiver
Old Feb 09, 2012, 03:44 AM
teccer1234 is offline
Find More Posts by teccer1234
safer on the ground
teccer1234's Avatar
wilts, United Kingdom
Joined Jul 2006
learning curve with my tri
thought somebody might be interested in my learning to fly a tri, I've never flown anything like this before so it might look silly but have a look at my you tube tri escapades I think I'm getting a bit better at it now but still a long way to go.
out here in Spain I've done all my learning in the villa garden which is very small with palm trees everywhere, only recently managed to get out onto the beach when the wind had dropped
go to you tube, search, teccer1234
thanks
Ray
teccer1234 is offline Find More Posts by teccer1234
Old Feb 09, 2012, 07:27 PM
Joined Dec 2004
Does anyone have a good source for 12mm CF booms? Or what are you using? I know wood is almost ideal, but I like hiding the motor wires inside the boom.
I tried the cheapo 450 booms from HK. They are too thin. One broke on the first minor crash. Then I tried the FG booms from GLB. They are thicker but there is no rotational strength. All of the strands are oriented length wise. First crash with that one. split down the length in numerous places.
Old Feb 10, 2012, 01:09 AM
jhsa is offline
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
aluminum tube? but that might be too heavy? For mr nothing beats wood. I'
m building a quad using wood for the frame like i did on the tricopter. but this time if I crash and break it I'll have to build a new frame as this one is all glued
jhsa is offline Find More Posts by jhsa
Old Feb 10, 2012, 01:10 AM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
Well I think you already know I use 16 x 1 ali. Takes the hits and bends back good.
Can you get that size tube ?
Oh yeah what about www.goodluckbuy.com they have some tube.
BigJimNZ is offline Find More Posts by BigJimNZ
Old Feb 10, 2012, 01:11 AM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
You'll get used to Ali booms soon lad ......
Old Feb 10, 2012, 01:58 AM
jhsa is offline
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Oh yeah, can't wait to try some
Old Feb 10, 2012, 06:00 AM
Joined Dec 2004
Yes, I have a source. I have some of the CF from GLB on order. I am afeared that it will be just as bad as the stuff from HK. I am thinking of going to 500 or even 600 size. In Align parts that is 21.5mm OD. But that means another rebuild.
Old Feb 10, 2012, 01:57 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
I have built my last 4 quad frames from wood - 1 normal and 1 lightweight + 1 of each as spares.... I always was a pessimist !
I am well on with a tricopter build - again the frame is all wood.
Some time back I hit on the idea of making the wooden arms T shaped. This gives great rigidity and at a lower weight than a big chunk of solid wood.
Some glue, 2 strips of wood and some clamps produce a T shaped arm that is light and resists flexing in any direction.
sparklet is offline Find More Posts by sparklet
Old Feb 10, 2012, 03:45 PM
Joined Dec 2004
That's actually not a bad idea.
Old Feb 10, 2012, 07:54 PM
Fubar 123 is offline
Find More Posts by Fubar 123
Fubar 123's Avatar
Whitchurch,Shropshire. UK
Joined Jul 2008
Hi Sparklet,
I am collecting the Bits together to build a Tri and I am wondering what size are the strips in your arms are ? It sounds a good idea to me.
Fubar 123 is offline Find More Posts by Fubar 123
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
