Old Jan 28, 2012, 01:20 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Hi Stunt Double,
You are sowing doubts in my mind
I played around with a couple of tricopters before switching to quads.
I need a folding tri for easy transport. I like the ideas behind the T shape. I seem to remember, quite some time ago, that a couple of experienced fliers went back to Y frames after using T frames.
I reckon it will be easy (and cheap enough) to build both a T and a Y frame. I could try the T first and swap the gear onto the Y if Necessary.
That's it then... cunning plan now formulated.... I will build both and test the T first
sparklet is offline Find More Posts by sparklet
Old Jan 28, 2012, 01:37 PM
sparklet is offline
Cumbria in the U.K
Just ordered some silicon tube off Ebay. Got to try Big Jim's latest anti-vibe idea.
Old Jan 28, 2012, 05:14 PM
mr.incredible is offline
Find More Posts by mr.incredible
An ordinary sort of incredible
mr.incredible's Avatar
United States, TN, Knoxville
Joined Dec 2004
Anti-vibe on the FC is not a good idea. It usually multiplies the vibes. It does help however with camera mounts. I guess the FC just isn't heavy enough.
mr.incredible is offline Find More Posts by mr.incredible
Old Jan 28, 2012, 07:15 PM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
The tri in this flight has silicon tube for the FC board. There was a reasonable breeze blowing as you can hear.
You are right Opus. The lack of mass in the FC was an issue.
I have found this solution way better than the fuel tube which had a propensity to wave around and resonate. The slices of a bigger heavier wall tube are now on the side.
It's quite rigid so there is less instance for res. They are placed at 45 to the corners to make the setup more resilient.
I do balance motors and props though as every good boy should.
Though I fitted a prop with about 10mm tracking issues and it never blinked
Tricopter At Kiwi Esplanade Mangere Bridge (2 min 2 sec)
BigJimNZ is offline Find More Posts by BigJimNZ
Old Jan 29, 2012, 12:00 AM
Frans Cubitt is offline
Find More Posts by Frans Cubitt
Near Cape Town South africa
Joined Mar 2006
Thanks Kaycee I really appreciate it as I enjoy flying my Tri almost more than my FPV plane but am fed up with gryo hassles and want to build mk 2
cheers Frans
Frans Cubitt is offline Find More Posts by Frans Cubitt
Old Jan 29, 2012, 10:20 AM
sparklet is offline
Cumbria in the U.K
I usually mount the Arduino amd WM+ onto velcro. One piece stuck to the back of each board and the other pieces stuck onto the plywood centre piece. I haven't had any problems with this method, it's quick.easy and the velcro seems to provide enough vibration damping.
I was going to try out the silicone tube for camera mounting.
Old Jan 29, 2012, 04:42 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
Hey guys after 3 hrs of dredging the lake I finally hooked my tricopter !!
As you can see from the picture it was a failed rear prop that caused the crash. Rear motor is stuffed and servo has a stripped gear.
Everything was placed in distilled water and sprayed with electrical contact cleaner spray.. Still drying in the garage so hopefully most of the gear still works (pls??)
Assuming the GoPro works I will need to somehow clean the inside of the lens or replace it. and a new battery of course.. Any tips/links welcome here...
I did manage the get the sd card going and downloaded the footage from the ill fated flight. It was very windy but as you can see I was having a great time out there enjoying the scenery..
Tricopter recovered from crash into lake Bullen Merri Camperdown Raw onboard footage (3 min 46 sec)
(it is un-edited so you will need to go to 43 seconds for takeoff)
jbalat is offline Find More Posts by jbalat
Old Jan 29, 2012, 05:03 PM
jhsa is offline
Find More Posts by jhsa
Flying a Chipmunk in Portugal
jhsa's Avatar
NRW, Germany
Joined Sep 2010
Good that you found it.. I hope that the electronics can be saved
jhsa is offline Find More Posts by jhsa
Old Jan 29, 2012, 06:04 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
http://www.youtube.com/watch?v=GrCYjO6jzf0
Oh good work man I hope some of it is salvageable
Old Jan 29, 2012, 06:40 PM
flyerdiver is offline
Find More Posts by flyerdiver
flyerdiver's Avatar
Lafayette,CO
Joined Jan 2009
Way to not give up! Water is Murphy's favorite, of that I'm sure.
flyerdiver is offline Find More Posts by flyerdiver
Old Jan 29, 2012, 06:58 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
I cant believe you got the tri back!! To get the lens off the gopro you need to put a bit of heat onto the thread (hair dryer works) to loosen up the thread locker otherwise you'll break it.
Stunt Double is offline Find More Posts by Stunt Double
Old Jan 29, 2012, 08:38 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Couple of pics of the anti vibe camera mount for you Sparklet
Might give you some ideas for yours
Description: Name: Cameravibedetail.JPG
Description:
Description:
Old Jan 29, 2012, 09:32 PM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
Here's my Tricopter build plus videos - tons of fun !
http://www.ilovefpv.com/
ilovefpv is offline Find More Posts by ilovefpv
Old Jan 29, 2012, 11:57 PM
Joined Mar 2006
Wow amazing the Go Pro even took some underwater shots.
If your battery came off in the crash the electronics should be ok but if it was still giving juice then you can have problems.
Luckily it wasnt Sea water, a guy by us who does pro Filming lost his whole chopper cameras everyting about 35G in the Sea... bummer
Old Jan 30, 2012, 02:14 AM
secretspy711 is online now
Find More Posts by secretspy711
Assault the sky
secretspy711's Avatar
United States, CO, Denver
Joined Aug 2004
For everyone's enjoyment... Here's a video of my tricopter with an onboard camera getting hit midair by my friend's Bixler airplane. The tricopter didn't even care, while the Bixler flat-spins and hits the ground off-camera.
The collision is at exactly 0:50.
Bixler hits Tricopter (1 min 22 sec)
Tricopter: 1
Bixler: 0
Tricopter Specs:
DT750 motors
APC 10x4.7 props
Turnigy Plush 18A ESC's
Hobbyking Quadcopter Board V2, flashed to Tri configuration
Zippy 3000mAh 3S LiPo
HD Wing Camera from HobbyKing
Turnigy 390DMH tail servo
secretspy711 is online now Find More Posts by secretspy711
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
