Old Jan 17, 2012, 04:07 PM
jfcomg is offline
Find More Posts by jfcomg
jfcomg's Avatar
Mexico, JAL, Guadalajara
Joined Nov 2010
Originally Posted by k0mputer View Post
Is this all I need?
http://www.amazon.com/Eagle-Tree-Sys.../dp/B002JH3SQA
Or do I have to get the elogger too? and the GPS expander unit?
I have no clue on OSD but that eagle trees shows good information.
Hi k0mputer.
This is the page of eagle tree. http://www.eagletreesystems.com/MicroPower/micro.htm
and all you need to see all the info that i have in my tricopter is.
http://www.eagletreesystems.com/OSD/OSD-Pro.htm
http://www.eagletreesystems.com/MicroPower/3.htm
http://www.eagletreesystems.com/Pro/1.htm
http://www.eagletreesystems.com/MicroPower/6.htm
You can buy it at hobby king at better price , (the cheaper price appears when you add it to the shopping car) the problem is that they are out of stock almost all the time.
in my experience the customer service of eagle tree its really good they answer your questions really fast.
i use to have this system in a plane because the osdpro have the return to home function , but for a tricopter i don't think it can work properly.
if you want the osd only for the tricopter i know there are cheaper options.
i hope this can help you.
jfcomg is offline Find More Posts by jfcomg
Old Jan 17, 2012, 04:21 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
Id really like to have an OSD with home indicator arrow on my quad. At the moment im using the cheap HK E-OSD which shows me time elapsed, battery voltage and the dragon link rssi voltage. Before this was installed I was just relying on the radio timer which is not exactly the safest way to fly fpv. If you cant afford the eagle tree gear then the $13 HK E-OSD is a must IMO.
Stunt Double is offline Find More Posts by Stunt Double
Old Jan 17, 2012, 04:42 PM
k0mputer is offline
Find More Posts by k0mputer
Joined Jan 2011
Hi jfcomg. This will be for my tricopter so no RTH is ok. I basically will use your setup since you got what looks like a quadcopter, based on your video. Readymaderc has them in stock too. I know HK has good price but you're right, it is out of stock. Is the eagltree easy to configure? I don't mind if I have to solder stuff. What are the cheaper options? At least it should show AHI, speed, altitude, power left.
Originally Posted by jfcomg View Post
Hi k0mputer.
k0mputer is offline Find More Posts by k0mputer
Old Jan 17, 2012, 11:29 PM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
I have just bought the HK G-OSDII and will be flashing it with the CL-OSD.
This gives a bunch of goodies to the G-OSDII including a return home arrow.
At US$44 it's worth considering. I tried mine out the box and it performed well.
The stock item has 2 voltage readouts / gps coords / RSSI / Clock / speed
I will be flashing it in the next day or two and will update........
Ian
CL-OSD at the link below
http://www.rcgroups.com/forums/showthread.php?t=1490446
BigJimNZ is offline Find More Posts by BigJimNZ
Old Jan 17, 2012, 11:47 PM
pheonix3 is online now
Find More Posts by pheonix3
Perth, Western Australia
Joined Jun 2009
Thanks in advance for reporting on your progress with this option and re-flashed firmware. I'd be interested to seehow this goes. I bought the AEO GPS set from HK which promised lots but unfortunately has glitchy software and thus I'm searching for a replacement.
...I'll stay tuned!
cheers,
Matt
Ian
pheonix3 is online now Find More Posts by pheonix3
Old Jan 18, 2012, 08:59 PM
jfcomg is offline
jfcomg's Avatar
Joined Nov 2010
You have to read the manuals to know how to connect and configure with your computer the OSD and elogger. no soldering needed if you are going to measure a second battery you should have to buy an 15k resistance and solder it.
Old Jan 18, 2012, 09:02 PM
planerazy03 is offline
Find More Posts by planerazy03
Joined Jul 2011
I use a lathe to drill the bar out to 14mm then ream to 16mm. Then part them off at whatever length. Then drill the bolt holes in the press.
Have a quick look at my blog here at RCG. I have a very simple yaw mount made from the same Polethylene material and using a 9gram servo.
Everything is attached with the poly blocks
I made a flat G10 plate for the front of my tri with silicon tube slices to mount my GP. Nil gello but then im flying in more temporate environments.
I mount my VTX on the left boom. Well I did until I flew the whole lot into the never never on boxing day. Gopro and everything gone. Parts on the way from HK for a new weapon. Gives me a good excuse to get the GP2 I guess
I have ordered a GPS SMS tracking thingy to tape on there.
If you are using a 16mm boom I can send you some poly blocks to play with if you like. Including the yaw mount. Send me a PM with your address and I'll fire some up to you ( no charge ). But I want to see a picture of your boss's face when he sees your new tri
Ian
can i get in on that poly block action???
planerazy03 is offline Find More Posts by planerazy03
Old Jan 18, 2012, 09:55 PM
wbuttry is offline
Find More Posts by wbuttry
wbuttry
sikeston mo
Joined Apr 2009
here is the build i started man i hate waiting on hobby king still got parts coming and then the next thing is figureing out all the wiring maybe some one can kinda lead me in the rite direction but here is a vid i did kinda showing what i got and what i done but here it is http://www.youtube.com/watch?v=UxXqnA_OoYs ok also here is a pdf file from mulicopter for people using the black board any way it has all the different models listed and the direction of each prop but tell me what you think
wbuttry is offline Find More Posts by wbuttry
Old Jan 19, 2012, 10:33 AM
k0mputer is offline
Joined Jan 2011
Hi k0mputer.
The OSD Pro, Vlogger, and GPS were on sale from HK yesterday, I ordered them. Plus, it was shipping from their US warehouse.
Old Jan 19, 2012, 12:06 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Nice
Old Jan 19, 2012, 10:49 PM
GorillaBob is offline
Find More Posts by GorillaBob
Re-Kitting Expert :o
Bullhead City, Arizona
Joined Jan 2005
jbalat & cdi3d,
Are either of you willing to do some printing on the side? I have a motor mount for a contra rotating motor that I would like to have printed. I checked out Ponoko.com and it was going to cost almost $60 with $14.00 for shipping a small plastic part.That is nuts!! These are not some thing I can sell a million of, so I can't afford to have a mold made and parts built, especially since I'm not sure if it will work. Well thanks for the help.
GorillaBob is offline Find More Posts by GorillaBob
Old Jan 20, 2012, 01:57 AM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
...I'll stay tuned!
cheers,
Matt
I got around to flashing the thing today. Flashed easy with AVR Studio 4 and AvrispII.
Took it out on the drive and it got a 7 satellite fix. The OSD looks good in the Fatsharks. Have yet to get the thing on a flying machine.
Will keep you posted
Ian
Old Jan 20, 2012, 02:44 AM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
Originally Posted by GorillaBob View Post
jbalat & cdi3d,
Can you post a screen shot and some rough dimensions and qty required ? Can you produce an STL file or would you like me to model it for you.. As I said its not my printer but I can certainly send the details to my friend if you give me so more info.
JB
jbalat is offline Find More Posts by jbalat
Old Jan 20, 2012, 08:52 AM
Joined Jan 2005
I have it half finished in SketchUp. I can finish that and send it along, or I can send a picture once it is finished. Which would be better?
Old Jan 20, 2012, 07:09 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
PM - Sent - I have been doing more and more printing for motor mounts and such -
cdi3d is offline Find More Posts by cdi3d
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
