United States, CT, East Hartford
Joined Aug 2009
Joined Feb 2011
I use the same battery.. The only issue I get is when the battery starts going the video also goes down shortly afterwards.. If you keep an eye on your voltage and land before you get to 10v then you should be ok !!
i'm thinking to install a voltage regulator for the video. here is the video> in the video the battery starts at 11.93v. that is because in the first flight i forgot to turn on the recorder. ![]()
any comments are welcome. Thank you. |
Joined Jan 2011
Cool video jfcomg. Is that rvosd you're using?
Check ultimachine.com for ABS plastic |
Joined Jan 2011
Is this all I need?
http://www.amazon.com/Eagle-Tree-Sys.../dp/B002JH3SQA Or do I have to get the elogger too? and the GPS expander unit? I have no clue on OSD but that eagle trees shows good information. |
Can you estimate your cost in materials for a single motor mount? I would like to compare to what they usually cost me (Laser SLS), which is around $10. |
| Thread Tools | |
| Discussion Yet another tricopter build. !!Updated parts list!! | SebastianJ | Multirotor Talk | 2669 | Dec 30, 2011 05:48 PM |
| Discussion What to do? Failed tricopter build! | Razor_Racer | Coaxial Helicopters | 9 | Mar 07, 2011 09:20 AM |
| Discussion Tricopter Build | Razor_Racer | Coaxial Helicopters | 21 | Feb 20, 2010 08:24 PM |
| Build Log Tricopter build | SebastianJ | VTOLs | 1 | Dec 22, 2008 04:34 PM |
| Discussion Trying to build a mechanically actuated tricopter, Help! | stefalo | Coaxial Helicopters | 3 | Jan 09, 2008 04:10 PM |
