Old Jan 10, 2012, 09:34 PM
jbalat is offline
Find More Posts by jbalat
Joined Feb 2011
Originally Posted by BigJimNZ View Post
Ok here's a little mind numbing tricopter fly about
If this your New one ??
jbalat is offline Find More Posts by jbalat
Old Jan 10, 2012, 09:36 PM
CoolBudz is offline
Find More Posts by CoolBudz
RCPlaye
United States, CT, East Hartford
Joined Aug 2009
http://www.youtube.com/watch?v=SyEhg...e_gdata_player
way cool, what props are you using and how heavy is your tri
CoolBudz is offline Find More Posts by CoolBudz
Old Jan 10, 2012, 09:45 PM
CoolBudz is offline
RCPlaye
Joined Aug 2009
Originally Posted by Frans Cubitt View Post
Thanks very much guys.
Signguy I will look at the multiwii
Is there a specific supplier for the Multiwii
cheers Frans
i dont know if anyone has tried this but it looks like it can make your life a lot more easier
http://www.goodluckbuy.com/mwc-multi...ard-quadx.html
Old Jan 10, 2012, 10:13 PM
BigJimNZ is offline
Find More Posts by BigJimNZ
BigJimNZ's Avatar
Auckland New Zealand
Joined Sep 2010
Props are just GWS 11 x 47
Weighs in at 1KG with the 2200 3s
BigJimNZ is offline Find More Posts by BigJimNZ
Old Jan 10, 2012, 10:20 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Sort of. I had this one with an HK board on so I jammed an Arduino and WMP on it so I would have something to fly. Pretty happy with it
I have an order of stuff on the way from HK to replace my lost FPV craft.
The missus felt sorry for me and told me to go get a new GP so I guess I'll have to do as she says........not sure if she ment GP2 or not woop woop
Scored some wild silicon tube from an install the other day. It's got like 3mm wall.
You never know I might send you a sample for testing
Old Jan 10, 2012, 10:25 PM
CoolBudz is offline
RCPlaye
Joined Aug 2009
what type of flight times are you getting
Old Jan 10, 2012, 10:27 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
Originally Posted by Stunt Double View Post
I like the fluoro arms
The fluro arms are made by spraying masking tape with a fluro paint then sticking it on the tri.
In this case I used a dulux product called dazzle. It's used for road marking and that sort of thing. Dries quick too.
You would be able to get it at Bunnings
Old Jan 10, 2012, 10:29 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
On a fresher battery 10 - 12 mins nice flying .......but that never happens
Old Jan 10, 2012, 10:35 PM
CoolBudz is offline
RCPlaye
Joined Aug 2009
how much does your prop size affect your tri's stability because
ive got a 10x6, and 12x8 coming and ima little worried these props aren't gonna be any good stability wise
Old Jan 10, 2012, 10:43 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
There will be comment but In my experience with the 750 motors the smaller the craft the smaller the prop was better. I build mine with arms that get the motor out 455mm to centre.
If you have a look on my blog you will see a couple of videos of the same smallish tri with different prop selections. The difference is quite noticeable.
It's going to depend on your motors, arm length etc etc.
Fly them and see how it goes is about the best way
Old Jan 11, 2012, 06:15 AM
mr.incredible is offline
Find More Posts by mr.incredible
An ordinary sort of incredible
mr.incredible's Avatar
United States, TN, Knoxville
Joined Dec 2004
BigJimNZ is correct, of course. Prop size is going to be subjective to the weight, arm length, motor speed and your preferences. Unless you have a really slow KV motor or lifting a lot of weight the 12x8 is going to be way overkill. It will greatly increase your amp draw and greatly reduce your flight times. Tell us a little more about your craft and we can suggest some closer sizes. Most people find a much smaller pitch works best. I use mostly APC 10x4.7. Whatever size you pick, you want a good stiff but lightweight blade. The motors rapidly and constantly change speed, so too much weight on the blade will resist that change with inertia.
mr.incredible is offline Find More Posts by mr.incredible
Old Jan 11, 2012, 12:12 PM
Frans Cubitt is offline
Find More Posts by Frans Cubitt
Near Cape Town South africa
Joined Mar 2006
I dont know if it helps but I fly with cut down 10*4.5 with the Tower pro motors.
I must admit my Tri is very light and I fly with a 1250 or 1800 battery.
Remember whatever props you use, ballance them as it makes a massive difference
Frans Cubitt is offline Find More Posts by Frans Cubitt
Old Jan 11, 2012, 01:43 PM
flyerdiver is offline
Find More Posts by flyerdiver
flyerdiver's Avatar
Lafayette,CO
Joined Jan 2009
I use a lathe to drill the bar out to 14mm then ream to 16mm. Then part them off at whatever length. Then drill the bolt holes in the press.
Have a quick look at my blog here at RCG. I have a very simple yaw mount made from the same Polethylene material and using a 9gram servo.
Everything is attached with the poly blocks
I made a flat G10 plate for the front of my tri with silicon tube slices to mount my GP. Nil gello but then im flying in more temporate environments.
I mount my VTX on the left boom. Well I did until I flew the whole lot into the never never on boxing day. Gopro and everything gone. Parts on the way from HK for a new weapon. Gives me a good excuse to get the GP2 I guess
I have ordered a GPS SMS tracking thingy to tape on there.
If you are using a 16mm boom I can send you some poly blocks to play with if you like. Including the yaw mount. Send me a PM with your address and I'll fire some up to you ( no charge ). But I want to see a picture of your boss's face when he sees your new tri
Ian
Hey, thanks for the offer but I don't have any 16 mm booms at the moment. Also shipping anything up here costs and arm and a leg and takes forever and a day to get here. But I appreciate it none the less. I might have to take you up on your offer though once i get back to the lower 48
flyerdiver is offline Find More Posts by flyerdiver
Old Jan 11, 2012, 06:37 PM
Hakobyan2012 is offline
Find More Posts by Hakobyan2012
Joined Jan 2012
Different Gyros
Could we use different gyros on each motor or would they interfere with each other?
Hakobyan2012 is offline Find More Posts by Hakobyan2012
Old Jan 11, 2012, 10:26 PM
BigJimNZ is offline
BigJimNZ's Avatar
Joined Sep 2010
They wouldn't necessarily interfere with each other but you would be best to use the same gyros for the pitch and roll as the gain for these all comes from the same signal and some gyros will work differently from others perhaps making you tri very unstable . But you can use something different for the yaw.
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
