Old Jan 04, 2012, 06:49 PM
mr.incredible is offline
Find More Posts by mr.incredible
An ordinary sort of incredible
mr.incredible's Avatar
United States, TN, Knoxville
Joined Dec 2004
Originally Posted by thebgrian View Post
Hi, Opus
this is a great looking tricopter. Is it going to be Ok if I follow your build? I have a quad, but want to build a tri and I realy like the design with the rotating boom. I have the glass fiber booms http://www.goodluckbuy.com/glass-fib...lticoptor.html from glb on my quad and I like them, they feel pretty strong and were tested in few crashes For motor mounts I'm planning to use this parts from glb http://www.goodluckbuy.com/al-cnc-me...-dual-tri.html . I already received them and they look good, tight fit and light.
Of course you can follow it, copy it, steal it, sell it... One big happy family here. I'm happy to see when someone takes interest in my sh*t.
I just ordered those booms. I do like those motor mounts. I just tried to make the aluminum "U" bolts. I think the aluminum I used was too soft. It stripped out too easily. I am going to look for some harder alloy aluminum and try with actual 3mm stock. Using the 1/8 th inch, the die has to remove too much material. The threads aren't that great.
mr.incredible is offline Find More Posts by mr.incredible
Old Jan 04, 2012, 09:30 PM
thiliban is offline
Find More Posts by thiliban
Joined Oct 2011
Hi there...my name is dhilib..im from malaysia..currently im doing my final semester project which is tricopter...i hope you could help me on few things..im still unsure to use what type of arm to build my tricopter..wood or aluminium..which one do you suggest??
thiliban is offline Find More Posts by thiliban
Old Jan 04, 2012, 09:38 PM
Stunt Double is offline
Find More Posts by Stunt Double
Multi Rotor Maniac
Stunt Double's Avatar
Australia, VIC, Melbourne
Joined Oct 2007
Start with wood and prepare a few extra arms for crash repairs. Wood absorbs the vibrations better so its more forgiving if you havent balanced your props and motors correctly.
Stunt Double is offline Find More Posts by Stunt Double
Old Jan 04, 2012, 10:50 PM
CoolBudz is offline
Find More Posts by CoolBudz
RCPlaye
United States, CT, East Hartford
Joined Aug 2009
Wood is much better, especially for a beginner, like me
CoolBudz is offline Find More Posts by CoolBudz
Old Jan 05, 2012, 02:51 AM
st99 is offline
Find More Posts by st99
st99's Avatar
United States, PA, Uniontown
Joined Jan 2005
Wood
Hi dhilib. Wood is real easy to work with. I covered mine with florescent Yellow covering I got at the Hobby Shop. Looks nice and I should be able to see it in the air pretty good. I used 1/2 x 1/2 inch wood from Home Depot. My next one that I build will use 5/8 x 5/8 inch wood, just to make it a little stronger. Probably not necessary but I will try it.
Good luck,
st99
st99 is offline Find More Posts by st99
Old Jan 05, 2012, 05:52 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Originally Posted by Reflex1 View Post
Jeff. I had a look through the attachments on the Multiwii thread
This looks like yours
http://static.rcgroups.net/forums/at...-wiiclone1.jpg
I'd assume
Green is 0V
Red is +ve (pin 12 on the Arduino)
Yellow SDA
Orange SCL
it's safe to swap SDA and SCL if it doesn't work
and test again.
I haven't used this board, so I can't be certain
Have a look through the other pics. maybe you can get a clue for the other connections
http://www.rcgroups.com/forums/thumb...gallery&page=2
Hi Paul thanks for that The board shown is not quite the same but I bet the pinout are correct (got to risk it)
Green is ground
Red is positive
The others are take your pick
I have been through the attachments on the multiwii thread and found some that show my NK and WM+ boards and sent two pm and posted several times Have had one guy try to help.
Could you have a look at the attachments on post 7402 on page 494 Multiwii thread
http://www.rcgroups.com/forums/showt...61382&page=494
This guy (Schorschi) is using the same NK and WM+ board as mine. I sent a pm several days ago but no response would be grateful if you could cast your knowledgeable eyes over it, they can make better sense of it than mine
Regards and happy new year Jeff
Upup is offline Find More Posts by Upup
Old Jan 05, 2012, 06:07 AM
Reflex1 is offline
Find More Posts by Reflex1
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
Your best bet imo is to wire it with the WM+ board first
Once you have that working then add the NK using the NK connections
in your quoted post.
http://static.rcgroups.net/forums/at...443-188-NC.jpg
Paul
Reflex1 is offline Find More Posts by Reflex1
Old Jan 05, 2012, 07:39 AM
Upup is offline
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Paul
Yes I think that is the way to go one skittle at a time, but I still need to find the configuration from the WM+ board to NK
Can you tell me which sketch should I load?
Thanks for your help
Old Jan 05, 2012, 07:45 AM
Reflex1 is offline
X-Ikarus
Reflex1's Avatar
Joined Feb 2003
Try 1.8 first
and let us know, how it goes.
Gyro's first
then we can look at the NK
Old Jan 05, 2012, 09:06 AM
Upup is offline
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Try 1.8 first
Gyro's first
Roger that!
Jeff
Old Jan 05, 2012, 09:25 AM
thebgrian is offline
Find More Posts by thebgrian
United States, TX, Dallas
Joined Dec 2010
Sounds good, Opus. I ordered the bearings from ebay and trying to decide on the material for the central platform. I'm thinking of using either plywood or FR4 PCB. I see you've used G10, how hard is to work with that material?
Update: Did some reading and it looks like FR4 is the fire-retardant version of G-10.
thebgrian is offline Find More Posts by thebgrian
Old Jan 05, 2012, 02:20 PM
flyerdiver is offline
Find More Posts by flyerdiver
flyerdiver's Avatar
Lafayette,CO
Joined Jan 2009
Well the cold issue on the tricopter wasn't insulation at all. Although insulating it does keep my osd from flickering during flight. David over at rcexplorer.se said to let the board get down to temperature then do a throttle end-point calibration. Well that sure did it. Now it starts right up and no drift in -30.
flyerdiver is offline Find More Posts by flyerdiver
Old Jan 05, 2012, 04:18 PM
dramida is offline
Find More Posts by dramida
Urban Aerial Photography
Bucharest, Romania
Joined Sep 2009
Thank you all who made this possible:
Airborne New Year's Eve fireworks show- Bucharest-Romania (3 min 33 sec)
dramida is offline Find More Posts by dramida
Old Jan 05, 2012, 07:03 PM
CoolBudz is offline
RCPlaye
Joined Aug 2009
looks like someone tried to shoot you down 38 seconds in
Old Jan 05, 2012, 07:25 PM
Joined Dec 2004
Exactly, same thing. PCB is just a different color. A whole 12" x 24" sheet of 1/16th inch G10/FR4 from McMaster Carr is only $20. I generally use a diamond blade (tile blade) on a table saw to do the rough cuts. Then I use various sanding devices to finely shape. Make sure you use a good dust mask. You don't want the fiberglass and epoxy dust in your sinus/lungs. I attach a shop vac to catch a lot of the dust.
For the arms you may want to start with wood. Like was just previously said, it is a lot more forgiving in crashes. You will crash alot. You can get 1/8th or 1/4 inch plywood from most hobby shops for the frame. Lowes and Home Depot sells Poplar 1/2" square sticks. Poplar is a good hard but light weight wood.
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 06:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 10:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 09:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 05:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 05:10 PM
