Old Dec 05, 2011, 03:10 PM
IMEIV is offline
Find More Posts by IMEIV
The way of being is doing.
IMEIV's Avatar
Italia, Emilia Romagna, Ravenna
Joined Apr 2009
Originally Posted by opus View Post
Best place to start is the MultiWii Copter thread. It is a huge thread but just about everything related has been discussed there. If you have no experience with helis, you might want to get the autoleveling components. It will help quite a bit in learning to fly. Other than FF, flight it is not the same as a plank.
Thanks Opus. I will check MultiWii thread and MultiWii site http://www.multiwii.com/ I think that learn to fly multicopters without automatic function make stronger for the future...
IMEIV is offline Find More Posts by IMEIV
Old Dec 05, 2011, 05:31 PM
st99 is offline
Find More Posts by st99
st99's Avatar
United States, PA, Uniontown
Joined Jan 2005
If you wanted to get a feel for it, the PHOENIX simulator has a quad copter you could play around with. Its listed under "other"
st
st99 is offline Find More Posts by st99
Old Dec 08, 2011, 05:44 PM
TheTrashMan is offline
Find More Posts by TheTrashMan
TheTrashMan's Avatar
Joined Jul 2009
What is the best way to protect my kk board???
TheTrashMan is offline Find More Posts by TheTrashMan
Old Dec 08, 2011, 06:26 PM
atckirk is offline
Find More Posts by atckirk
atckirk's Avatar
United States, CA, Mission Viejo
Joined May 2001
Leave it in the box in your house!
I like the blueskyrc tri frame for the built in roll cage. Other things that work are a KK board sized piece above the board on spacers to help protect it.
Kirk.
atckirk is offline Find More Posts by atckirk
Old Dec 09, 2011, 12:53 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
I am considering, however, to mount on my first tricopter a board that allows Automatic Hovering as FH-X46 Pro http://www.foxtechfpv.com/fhx46-prot...ler-p-286.html
I would like to know if this board is compatible with engines whose inclination is adjusted directly by servos as in this case http://www.rcexplorer.se/projects/tr...copterv25.html ?
Old Dec 09, 2011, 08:24 AM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
It does not appear so in the manual, they support what they call Y4 which looks like a tricopter but uses top and bottom motors on the tail.
Build a multiwii and join us here!
capt is offline Find More Posts by capt
Old Dec 09, 2011, 08:41 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Thanks Capt. Mutilwii is a possibility I'm thinking. If I buy this just assembled MutiWii SE board http://www.ebay.com/itm/MWC-MultiWii...item1c219dadcd
Is ok ? And it support motor configuration of Tricopter 2.5 http://www.rcexplorer.se/projects/tr...copterv25.html ?
Old Dec 09, 2011, 08:46 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Many are now jumping on the the MultiWii Bandwagon, as a suggestion, if they don't support Alex by making a donation to encourage future developments, I would not support them. Ask the seller questions about their support for Alex.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Dec 09, 2011, 09:13 AM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
Yes that should work, it does not have a history record as they are new on the market but I have read some builders have ordered them and will start testing.
Alex's site
Old Dec 09, 2011, 02:55 PM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Alex's site
Thanks..
Old Dec 09, 2011, 03:36 PM
phillip1992 is offline
Find More Posts by phillip1992
Joined Oct 2011
I recently built a tri with 4 hk401b gyro's (yes i should have gone with a controller board...) After a lot of tuning and trimming I got it flying reasonably stable. The problem is when I move the throttle stick to the max the right motor does not nearly spin as fast as the other 2 motors and the tri banks right very sharply. Before every flight I calibrate the esc's by giving max throttle, switching the esc's on, waiting for the 2 beeps and then move to min throttle. The gyro's limits are all the same. What can I do to fix the banking?
phillip1992 is offline Find More Posts by phillip1992
Old Dec 09, 2011, 05:04 PM
johnorama is offline
Find More Posts by johnorama
UAV Dude KF7HYV
johnorama's Avatar
United States, NV, Silver Springs
Joined Mar 2007
You need to limit the max throttle in your radio or just never go to full throttle. The gyros are stabilizing the aircraft by automatically adding or reducing throttle to each motor as needed. If you are applying max throttle, then how can a sagging arm be raised to level if there is no more room to add throttle.
Also, the motors and ESCs you are using are likely not electronically matched. Therefore, each will react slight different. I have a tricopter with a Wii setup that I have to command a bunch of roll when I start to lift off and then smartly take out the roll command as it gets to hovering/flying RPM. This could also be contributing to the roll at max throttle problem you are having.
johnorama is offline Find More Posts by johnorama
Site Sponsor
Old Dec 09, 2011, 05:49 PM
juanmagil is offline
Find More Posts by juanmagil
SPAIN
Joined Jan 2011
Hi everyone.
I have learned very much in this web page and I'd like to show you one of my first videos with my tricopter in fpv mode.
In this fly I have a gopro 2 camera for video. Sorry, but It isn't edited and I recommend watching it from minute one.
Tricopter FPV Club Saeta (6 min 21 sec)
Regards.
juanmagil is offline Find More Posts by juanmagil
Old Dec 09, 2011, 07:22 PM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
Originally Posted by juanmagil View Post
Hi everyone.
http://www.youtube.com/watch?v=EDwqW...layer_embedded
Regards.
Nice, mind sharing your setup?
Old Dec 10, 2011, 12:41 AM
IMEIV is offline
IMEIV's Avatar
Joined Apr 2009
Alex's site
I note, however, one thing ... About the FH-X46 Pro Program Board there is a manual .. as regards the MultiWii SE RTF I'm not not able to find something similar as a real manual in http://www.multiwii.com/ .. In practice, if I order the MultiWii where I can find correct information and instructions for this card?
Discussion Yet another tricopter build. !!Updated parts list!! SebastianJ Multirotor Talk 2669 Dec 30, 2011 05:48 PM
Discussion What to do? Failed tricopter build! Razor_Racer Coaxial Helicopters 9 Mar 07, 2011 09:20 AM
Discussion Tricopter Build Razor_Racer Coaxial Helicopters 21 Feb 20, 2010 08:24 PM
Build Log Tricopter build SebastianJ VTOLs 1 Dec 22, 2008 04:34 PM
Discussion Trying to build a mechanically actuated tricopter, Help! stefalo Coaxial Helicopters 3 Jan 09, 2008 04:10 PM
