Build A Tricopter
Hi All
First build thread for me here. Seems lots of you want to build a tricopter for AP. I have been using my copter for some time now, and it has proven very reliable. The frame is very basic. I will include close up pictures to help you build a frame. This is by far, not the cleanest looking machine. There are many more refined ways to do this. This build is for a basic AP tricopter. It will fold, and take lots of abuse. It will also carry a 6-8 oz camera with ease. here is a video of the final project...
Picture of tri using hk401's with instructions picture 2 has bad info. Set delay all the way ccw, and limit to half way. The line should point straight up http://www.rcgroups.com/forums/showp...postcount=5509 Here is the go pro soft cam mount. NO JELLO AT ALL! http://www.rcgroups.com/forums/showp...postcount=6655 Here are more details on the new cam mount http://www.rcgroups.com/forums/showp...postcount=8582 Corona receiver arming http://www.rcgroups.com/forums/showp...postcount=1121 Another way to do the yaw motor mount, Thanks Tom! http://www.rcgroups.com/forums/showp...postcount=1672 Arming with eurgle/turnigy/imax 9ch 2.4 radios http://www.rcgroups.com/forums/showp...postcount=1880 An easy way to make your copter more visible post from page 160, there is a video near the page middle too. http://www.rcgroups.com/forums/showp...postcount=2386 A simple fuselage to make a predator copter http://www.rcgroups.com/forums/showp...postcount=2603 Balancing motors with CA http://www.rcgroups.com/forums/showp...postcount=8839 A youtube video of the correct way to balance motors, YES, you should balance motors too!!!!
signguy |
parts you will need...
A transmitter capable of CCPM mixing, dual rates, and expo. I use an OPTIC 6 from Hitec, and an EURGLE ( imax 9, turnigy 9 ) radio available from R2hobbies $104 The list DT 750 motor X3 http://hobbycity.com/hobbycity/store...utrunner_750kv $12 total $36These are now $8.99 each, if you can get them! Get a 4mm drill bit, 4mm washers, and some 4mm nuts to hold on your props, they won't hold on by themselves.. New Better motor http://www.rctimer.com/index.php?gOo...3&productname= Same power as dt750. but much smoother and only $9.99 Other PROVEN motors with DT750 power http://www.hobbypartz.com/alpha-400-...ess-motor.html http://www.hobbypartz.com/75m16-opti...215-740kv.html Speed controls for DT750 X3 http://hobbyking.com/hobbyking/store...ies_25-30A_ESC I don't use these, but they are said to be better than the card programmable speed controls, because they work well with the HK401 gyros. You could also use tower pro 2410-09 motors with 10x4.7 props http://www.hobbycity.com/hobbycity/s...-09_13A_/_104W $6.39 each You can use any motor in the 600-1000kv range. The lower the Kv, the more resolution each step of the speed control will give you. Motors over 1000 Kv are more difficult to make stable. That said, some have used ducted fans and made it work. Speed controls X3 Use 10 amp versions for 2410-09 motors http://hobbycity.com/hobbycity/store...d_programmable) $10 total $30 BEC X1 http://hobbycity.com/hobbycity/store...oise_Reduction $9 speed control programmer X1 http://hobbycity.com/hobbycity/store...ogramming_Card $7 This just makes things easy, its worth $7 Battery X? this battery works great. http://hobbycity.com/hobbycity/store...00mAh_3S1P_20C $14Now only $9.99 3.5mm connectors X2 http://hobbycity.com/hobbycity/store...idproduct=4136 $4 Total $8 Gyro X3 http://hobbycity.com/hobbycity/store...Digital/Analog) $34 total $102 A better gyro HK401b http://www.hobbycity.com/hobbycity/s...ead_Lock_Gyro_ Get 4, they work great on the tail too. You will need a separate gain channel for the tail gyro $13.99 each Yaw gyro X1 http://hobbycity.com/hobbycity/store...zo_Gyro/Futaba $24 Or use a HK401b listed above Volt warning A must have!!!! http://hobbycity.com/hobbycity/store...ery_Monitor_3S $4 This is $230, you still need wire, battery plugs, a servo. The yaw gyro listed will work fine, but the E-SKY EK2-0704 is a great gyro, available from R2hobbies around $15 Almost forgot You will need three ( get lots of extras.) 11X4.7 gws slow flier props. Or reduction drive props as Hobby City list them. These are the best I've used, they are light, cheap, and reasonably durable. FOR AP!!!! Get apc 11X4.7 slowflier props. The gws are not durable enough for carrying weight. |
| Thread Tools | |
| Discussion Yet another tricopter build. !!Updated parts list!! | SebastianJ | Multirotor Talk | 2669 | Dec 30, 2011 05:48 PM |
| Discussion What to do? Failed tricopter build! | Razor_Racer | Coaxial Helicopters | 9 | Mar 07, 2011 09:20 AM |
| Discussion Tricopter Build | Razor_Racer | Coaxial Helicopters | 21 | Feb 20, 2010 08:24 PM |
| Build Log Tricopter build | SebastianJ | VTOLs | 1 | Dec 22, 2008 04:34 PM |
| Discussion Trying to build a mechanically actuated tricopter, Help! | stefalo | Coaxial Helicopters | 3 | Jan 09, 2008 04:10 PM |
