Old Nov 14, 2009, 07:45 PM
ebourlet is offline
Find More Posts by ebourlet
Tacoma, WA
Joined Nov 2001
How to use Brushless Sensor to measure RPM on Spark Ignition Gas motor?
Has anyone used the Brushless Motor RPM sensor to measure RPM on a Gas motor? I am looking for wiring suggestions to pick up off the Spark Plug wire like the on board tachometers that are available. If I just wind a coil of wire around the spark plug lead and hook both ends of the wire to the leads from the Brushless RPM sensor will it pick up the pulse from the spark plug wire through induction? I want to measure RPM on a Zenoaha G260 PUM motor in a boat. The boat has a cover over the engine so the optical sensor will not work as it is dark inside and I figured the spark plug fires every cycle so that would be the best way to get RPM. Has anyone done this.
ebourlet is offline Find More Posts by ebourlet
Old Nov 15, 2009, 01:58 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
The optical sensor actually works best in the dark, as it has it's own light source (IR) and seems to be jammed in daylight. The magnetic sensor would probably also be a better choice.
Fred
flarssen is online now Find More Posts by flarssen
Old Nov 17, 2009, 11:22 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
ebourlet, we have had reports that wrapping one (or both) of the brushless rpm sensor leads around the spark plug wire results in a usable reading. But, we've not tested that in house, so I have no idea how reliable this method is.
Most people do what Fred is suggesting, and use the magnetic sensor in conjunction with the magnet(s) that are most likely already mounted in your flywheel, that drive the magneto.
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Sold Eagle Tree V3 Data Logger, Power Panel, Brushless Motor RPM Sensor BoysToys Aircraft - General - Radio Equipment (FS/W) 0 Oct 24, 2009 01:23 PM
Discussion Brushless RPM Sensor Readings rjbsilva Eagle Tree Systems 7 Oct 17, 2009 12:08 AM
Discussion "noisy" Brushless RPM sensor Mau Eagle Tree Systems 3 Sep 20, 2009 12:36 AM
Discussion Brushless RPM Sensor not working Danal Estes Eagle Tree Systems 12 Sep 13, 2009 07:53 AM
Discussion Do you use both sensor wires for brushless motor rpm? Aussie Nut Eagle Tree Systems 5 Apr 25, 2009 03:26 AM
