Old Nov 14, 2009, 01:18 PM
GallopingGhost is offline
Find More Posts by GallopingGhost
Joined Sep 2005
2.4 GHz 11 dBi Dual Diversity Antenna
I'm not expert on Antennas but is this better than a standard patch? I know its not the same as two RXs but I don't understand the Dual Cross-Polarization Diversity.
http://www.l-com.com/item.aspx?id=20308
How about it Antenna Gurus?
GallopingGhost is offline Find More Posts by GallopingGhost
Old Nov 14, 2009, 01:27 PM
KristianS is offline
Find More Posts by KristianS
FPV addict
Giske, Norway
Joined Aug 2009
I have one of these and I'm only using the vertical output.
Dunno if that is recommended or not
But I get good range.
I have it connected to a duo diversity receiver together with a 5dBi rubber duck antenna.
KristianS is offline Find More Posts by KristianS
Old Nov 14, 2009, 05:13 PM
Joined Sep 2005
Thanks for the reply! At least we know its working for you. Perhaps we can get some Antenna experts to clue us in and get even better performance.
Old Nov 14, 2009, 05:20 PM
bracky72 is online now
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Each lead must be hooked to a seperate receiver and each receiver to a diversity device. The purpose of this is to give you the best signal when your plane is flying level with antenna verticle and also when you turn and your antenna stars going horizonal. You want the tx and rx to have their antenna polarized in the same way. This helps with that.
bracky72 is online now Find More Posts by bracky72
Old Nov 14, 2009, 06:12 PM
FPV addict
Giske, Norway
Joined Aug 2009
Hmm, maybe I will try to fly only by the 11dB with vert and horz connected next time.
How will the performance be a short range?
I have read that the higher the gain is, the more directional the antenna must be.
Anyone know what my angle will be, until I must have someone move the antenna?
Old Nov 14, 2009, 06:24 PM
bracky72's Avatar
Charles Town, WV
According to l-com it has a 60 degree horizontal beam width and 30 degree verticle beam width.
Old Nov 15, 2009, 08:59 AM
FPV addict
Giske, Norway
Joined Aug 2009
Cool, will try tomorrow
Thanx
Discussion Hitec 2.4 GHz Receiver Antenna? Charley38 Radios 11 Sep 03, 2010 12:11 PM
Discussion help.2,4 GHZ Video Transmitter Antenna Orientation fpvbird FPV Talk 17 Oct 04, 2009 12:48 PM
Discussion Anyone ever use 23 dBi 900 Mhz. antenna Faro69 FPV Talk 7 Sep 04, 2009 05:11 AM
Discussion 2.4 GHz 9 dBi Rubber Duck Antenna omnidirectional G-unit FPV Talk 14 Oct 14, 2008 04:45 PM
New Product Dual mode FM and 2.4 GHz SS transmitter EricSoar Radios 2 May 20, 2007 02:47 AM
