Old Apr 17, 2012, 09:01 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Was just bench testing with my airboss and throttled all the way up, then all the way back down. Nothing weird, but then she just re-armed... Now every time i push up on the throttle, it's very delayed, them sometimes it just shoots up to high rpm... very strange... Anybody have any idea what i'm describing here?
DaaBears is offline Find More Posts by DaaBears
Old Apr 17, 2012, 09:12 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Is it hesitating or is it going through all the beeping and all?
First thing I do whenever I have a question about an Airboss ESC is that I reprogram the ESC to default, It is at the very end of the programming beep sequence. Just let it run all the way through and then stop it at default. That usually fixes any problem I've ever had.
OK, and now I am gonna be cute....If it's just hesitating, try this..........................
Doc Austin is online now Find More Posts by Doc Austin
Old Apr 17, 2012, 10:02 AM
Space Bat is offline
Find More Posts by Space Bat
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Hey Doc....
Notice SFG's on your stab....not seen that - does it work or more to the point what has it helped with - worth doing??
Space Bat is offline Find More Posts by Space Bat
Old Apr 17, 2012, 10:12 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Originally Posted by Space Bat View Post
Hey Doc....
I'm not so sure either way. I believe it gave me a little more yaw stability, but the plane is certainly fine without them.
I originally made those up years ago for a plane that really needed some help, and it completely transformed it...... they helped that plane even more than the SFGs I put on the wing! That was one messed up looking airplane, but in the end I got it to fly reasonably ok.
On the MXS, though, I think it is already so stable that it's like putting SFGs on an Edge EXP and expecting the harrier to improve. It's already so good that you can't really help it much.
You can try it for yourself. SFGs are easy enough to make and they don't have to be sceintific. Just make sure they are the same on top and bottom, and the same on one side as the other. Cut out something that looks good and slap it on.
Old Apr 17, 2012, 10:22 AM
Team Hillbilly (UK)
Space Bat's Avatar
Joined Oct 2011
Cheers....possibly not worth doing on the edge as you say - but one to put in the mental locker for future builds....made some SFG's for my sons MX2 and it has helped hi plane no end and improved its hover and harrier...
Old Apr 17, 2012, 10:24 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
The ones on the tail were originally meant to appeal to my sense of symmetry, but then I grew to like they way they look......... and they always generate interest from anyone who sees them.
Old Apr 18, 2012, 12:07 AM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Second to last flight on recently dead Edge.
Pre death edge (5 min 38 sec)
Can't wait for the new one.
bigroger is offline Find More Posts by bigroger
Old Apr 18, 2012, 12:23 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Nice flying. Are you replacing the edge?
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Apr 18, 2012, 12:38 AM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
New one arrives tomorrow with the blue MXS as well.
I'm going to keep the edge on 3s and run the MXS on 4s probably with the DM2820-750.
What size lipo do you run in yours Bryan? I was thinking of 40C4s2200 and keep the flights around 6 minutes.
Old Apr 18, 2012, 12:51 AM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Roger, may I suggest the sunnysky 2820-800 if you have access to that brand? I'm flying one in my Edge with a 14x7 and love it. I'm using the new Zippy Compact 4s 2700mah 25c batteries, and everything is working well. The battery balances neutral about 1cm forward of the wing tube.
-Gary
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Apr 18, 2012, 01:00 AM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
Sweet Gary.
In the box I currently have unused the Dm2820-950 a DM2815-950 a torque 28xx-820 (came with edge #1) and the Dm2820-750 is in the HK slick currently.
I have looked at the sunnysky (I have a few of the 2204-1800) in small foamies and they seem pretty good performance to weight.
I'll have a look at the 2820-800, how many amps does she pull on 4s Gary with 14x7.
Old Apr 18, 2012, 01:05 AM
Joined Nov 2010
Sweet Gary.
I measured 49a the other day, but that wasn't with the zippy compact... but let me tell you she felt really strong and powerful! really happy
Old Apr 18, 2012, 01:30 AM
bigroger is offline
bigroger's Avatar
Joined Aug 2011
I wonder what kV that actually is running at?
49 amps on 14x7 and the Dm2820-750 pulls 57-60A depending on vox or apc 14x7 prop.
Still I think anything around 700+ watts is more then enough for the 48" EXP planes.
How do the Zippy compacts compare to the Turnigy blues or the std Zippy's?
Old Apr 18, 2012, 01:32 AM
Joined Nov 2010
I was running the turnigy nanotechs 25c previously, and I like these a little better. They weigh 20g less than the equivalent nano pack, and have 50mah more storage. Also, they had a nice strong output throughout the flight.
Honestly, there wasn't a big difference between this setup and the 2820-950 with a 13x6 on my MXS. Both motors are all around awesome.
Old Apr 18, 2012, 02:09 AM
Joined Oct 2011
Roger, I am running gens ace 2500 and sky lipo 2650's. I own/owned turnigy blues and nanos. The nanos are crap, IMO, power loss immediately and at 45 flights power really went down hill. The turnigy blues get weak too but not as bad as the Nano. I have a Sky 2650 30C (292g with deans) with about 100 flights on it with no noticeable power loss. I have one other Sky and Gens 2500 25C (291g with deans) both with around 50 flights also with no power loss. The Gens and Skys to me just had more go right from brand new. I set timer for 6 min and put back between 70-75%... definitely could go to 6.5 min but they have been working great for me with 6 min flights. Oh.... and all my batteries have been charged at 1C, and I fly enough were I don't mess with storage voltage unless I know I will not be using pack for a little while. I run a peak of 59 amps on a 2820-750 (measured 752kv with Castle logger)
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 9698 May 25, 2016 12:39 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
Discussion New Extreme Flight RC 48" Extra EXP mxcop 3D Flying 3 May 20, 2009 12:49 PM
Extreme Flight R/C Edge 540T profile MikeMayberry Sport Planes 21 Jun 17, 2004 11:08 PM
