Old Nov 13, 2009, 12:53 PM
EDF Crazy is offline
Find More Posts by EDF Crazy
EDF Crazy's Avatar
UK
Joined Oct 2007
Video
Feibao L-39 maiden
i will try a few mods and see if i can get more air to the fan. at this stage im not sure if it was tail heavy or not, i balanced it on the main wing tube like the manual recommends and alot of turbine guys seem to be using the same cg.
Landing broke one main gear mount. i hope the mods make it perform alot better.
EDF Crazy is offline Find More Posts by EDF Crazy
Old Nov 13, 2009, 03:30 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
nice plane! looks tail heavy with nose pitched up in flight?
Good flying to get her down.
best of luck to your next flight!!!
stoneenforcer is offline Find More Posts by stoneenforcer
Old Nov 13, 2009, 04:35 PM
bladexz2 is offline
Find More Posts by bladexz2
BladeRunner
Indianapolis, indiana
Joined Dec 2007
Power to weight
EDF crazy,
Now I know how you got your call sign. You're on the high end of the power to weight ratio for the DynEMax scorpions fan. For good performance I usually specify only 15 pound aircraft for that fan unit. One alternative if you can go to 14 cells. The scorpion motor can handle that and give you about another 500 Watts. If that plane is about the same size and weight as Tam A4 that Pablo flew, he used the DynEMax beast 1527 3-D at about 19 to 20 pounds with good flight authority. I agree also that you may be a little tail heavy. When an airplane is in this kind of condition you need to literally fly it to the ground with power. Glad you got it back in one piece!
Mach .5, maximum efficiency
Fred / Dyn-E-Max.com
bladexz2 is offline Find More Posts by bladexz2
Old Nov 13, 2009, 05:00 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yes i think it was tail heavy and sounded like it was'nt putting out a lot of RPM.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Nov 13, 2009, 07:35 PM
Socomon is offline
Find More Posts by Socomon
Joined May 2006
Socomon is offline Find More Posts by Socomon
Old Nov 13, 2009, 08:45 PM
onio condor is online now
Find More Posts by onio condor
onio condor's Avatar
United States, OH, Cincinnati
Joined Jan 2006
Big time tail heavy....you are very lucky to get her down...
Remember what a good pilot friend to me once.......
"a nose heavy plane flies poorly----a tail heavy plane flies once"
onio condor is online now Find More Posts by onio condor
Old Nov 14, 2009, 11:29 AM
trondb is online now
Find More Posts by trondb
trondb's Avatar
Trondelag, Norway
Joined Mar 2003
Man that looked scary Tail heavy , no doubt. But good save !
trondb is online now Find More Posts by trondb
Old Nov 16, 2009, 07:55 AM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
Yup, takes a pilot with good skills to get a model with a CG like that down in one piece. At least you know it won't fly worse. Please post some more vid when you get it up in the air again. Appreciate what Mr Dyn-E-Max says about power from that system but it doesn't fly bad. Actually looks like it's got a good 'scale' turn of speed.
DominicM is offline Find More Posts by DominicM
Video Maiden of my Sapac L-39 Dadude Electric Plane Talk 0 Jun 20, 2009 08:10 PM
Video Sapac Composite L-39 Maiden EDF Crazy Electric Plane Talk 8 Jan 06, 2009 07:18 AM
Discussion Freewing L-39 Maiden mike__ Foamy EDFs 5 Jan 28, 2008 05:55 AM
Video 8'' L-39 Micro Jet Maiden Flight Chris T Electric Plane Talk 2 Apr 07, 2006 09:34 AM
Video 8'' L-39 Maiden Flight Chris T Electric Plane Talk 0 Mar 20, 2006 12:39 PM
