This thread is privately moderated by A.T., who may elect to delete unwanted replies.
Old Mar 17, 2012, 03:08 PM
frankswd's Avatar
Salem, OR
Joined Sep 2002
subscribe
frankswd is offline Find More Posts by frankswd
Old Mar 17, 2012, 10:24 PM
Joined Aug 2002
Once again, please do not post to this thread, in need start a new thread for every new question relating to the Aurora 9 or AFHSS system
under:
Hitec/Multiplex USA - Vendor Support forum
New questions submitted as separate posts under the Hitec/Multiplex USA support forum will stand out and thus be better answered by the wider Hitec Team knowledge base.
This FAQ thread is maintained to keep post #1 updated, usually daily, with information relating to Q & A on forums world wide, and Hitec information releases.
(We also do not wish those who watch for new posts of special note to lose interest and stop visiting which happens when extraneous posts are added).
Alan T.
A.T. is offline Find More Posts by A.T.
Old Apr 04, 2012, 03:47 PM
Joined Aug 2002
Aurora A9 - Tactic_AnyLink Setup
The AnyLink SLT 2.4GHz Radio Adapter is compatible when using the optional extra TACMOOO4 Adapter Cable.
. Remove Spectra Module from the Aurora, to expose pins.
To avoid removing/replacing A9 Antenne, suggest hold Auora module to one side using Velco (Magic) Tape.
. Plug the TACM0004 cable into the first 3 pins on the left with the tab on the cable pointing to the left.
(Metal Terminals Facing Upward) - connect cable to Anylink unit.
. Switch Aurora on and press "YES" to transmit
NB:
So as not to damage the A9 or pins, follow instructions carefully.
1. Check attitude of plug.
2. Check which three "module" pins the plug is connected to.
. TX-R_How it Works
. Tactic & AnyLink Support Forum
Hitec Transmitter - Tactic Anylink Setup All other Hitec Tx
09 Jan 2013:
TACM0008 recently produced for the Eclipse 7 Pro, Optic 6 Sport 2.4Ghz etc can also be used.
Permits user to plug in with own battery and not have to remove existing module.
Plug into Trainer port, turn on the A9 and select 'multi I/O option" then "T-Pupil ".
Anylink module will beep and SLT is operative.
Module can be velcroed to back of A9 or attached to handle.
When using AFHSS system in lieu of SLT, unplug both Trainer Port and the Anylink battery.
13 Apr 2013:
. Hitec Aurora 9 Buddy with TACM0004 module <>other Hitec Tx as Slave
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
Please do not post to this thread.
. Start a new thread for every new question relating to the Aurora 9 or AFHSS system
under: Hitec/Multiplex USA - Vendor Support forum
Last edited by A.T.; Apr 13, 2013 at 04:20 PM. Reason: add url for all other Hitec Tx - Anylink setup
Old Apr 04, 2012, 04:41 PM
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
Thanks Alan but (gack) I can't see this happening.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Discussion Parkzone Micro Mustang TX Setups, Tweaks, Mods Tips, and Upgrades (work in progress) Flying-Monkey Micro RTF 417 Mar 25, 2013 09:28 PM
Discussion mSR TX Setups, Tweaks, Mods Tips, and Upgrades (a work in progress) Flying-Monkey Micro Helis 1137 Feb 28, 2013 08:37 PM
Discussion Micro Wings 24" and under- Setups and Tips microkites Flying Wings 689 Feb 19, 2012 09:59 PM
Undocumented Features of the Optic 6 rutat Radios 6 Sep 30, 2004 07:54 PM
Orbit Charger - Undocumented Features rscamp Power Systems 8 Jul 10, 2001 07:12 PM
