This thread is privately moderated by A.T., who may elect to delete unwanted replies.
Old Feb 08, 2010, 02:13 AM
most exalted one
BC Canada
Joined Aug 2002
Aurora A9 - Simulator function Set-up
Later observations:
a). Aerofly ProDeluxe Flight Sim: Remove module from Aurora. Aurora also does not then require to be setup in Trainer mode, simply select Transmit "No" when switched on. [This may also apply to other Simulators with dedicated "Dongles".]
I think there should still be a note indicating trainer mode works with module inserted. I would rather use the AFPD simulator without removing the module all the time. Others might also.
4*60 is offline Find More Posts by 4*60
Old Feb 22, 2010, 07:40 AM
mode1's Avatar
Southwest Missouri
Joined Oct 2002
interested
mode1 is offline Find More Posts by mode1
Old Feb 26, 2010, 06:04 AM
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by A.T. View Post
... Aurora A9 - Firmware Update V1.08 further detail.
V1.08? I am pretty sure this should read V1.06.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Feb 26, 2010, 12:04 PM
Joined Aug 2002
Originally Posted by Jurgen Heilig View Post
V1.08? I am pretty sure this should read V1.06. Jürgen
Typo corrected, tks.
Alan T.
A.T. is offline Find More Posts by A.T.
Old Apr 21, 2010, 11:02 AM
Night flier
United Kingdom, England, Bromyard
Joined Mar 2008
Anyone know the range of the Aurora 9? Im getting about 300 feet lol.
austin.laws is offline Find More Posts by austin.laws
Old Apr 21, 2010, 02:35 PM
Joined Aug 2002
Something not quite right, please refer to:
Today I did a car ground range test. Full power, not range check dedicated mode. Very impressed ! 2.2km ground level !!!
And must stop the test because of the field iregularities, even if we choosed a very flat area, the car passed behind a small (2-3m) hill that blocked the signal completelly. I guess that this system can do more than 4km in the air ! I wrote system and not Aurora, because was a module mounted on a T9C.
Did I mentioned that the Rx was inside the car, placed in the back, having direct vision to the transmitter via the rear window? - Renatoa"
AFHSS - Power Down - Procedure for Normal Mode & Scan Mode for Range Check.
Power Down for Range Check is 1mw - tested to at least 1/4 mile.
AFHSS - How To Select Optimum Channels - For Your Field.
AFHSS - ID-Setup A.K.A, binding or linking & Range Testing Spectra Pro Module <> Optima Receiver
Aurora A9 Telemetry - Flying Range
Aurora A9 Telemetry - Range test Using Segway & GPS - Video - Demonstrates remarkable 2100+ft not only through large obstacles but also with Heli sitting in ground effect.
at
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated}
and in need, contact Hitec Warranty & Service direct. Service Form
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old Apr 21, 2010, 04:25 PM
Night flier
Joined Mar 2008
Yeah im goin to have to send a them back to Hitec. Here in the UK its amarang. But its been like it since i bought it. just not tested it far till today. i was flying a SSX and it just kept goin out of range. I was flying my Swift at short range so didnt know it ws outa range within 200ft.
Old Apr 23, 2010, 12:06 AM
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
Try rebinding.
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Apr 28, 2010, 11:03 AM
TheMadEngineer's Avatar
Joined May 2009
Has anyone cracked any of the Optima Rx's open and taken pics of the internals? I can only ever find pics of one side of the PCB, and I'm dying to know what the components are before I commit to buy.
TheMadEngineer is offline Find More Posts by TheMadEngineer
Old Apr 28, 2010, 10:32 PM
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
TheMadEngineer, odd request... but why not!?!? Here is a 6 channel (sorry for the glare from the heat shrink)
I just remembered where to get photos of all of Hitec's stuff, the FCC!!!
Spectra 2.4 (pdf)
Optima 6 (pdf)
Optima 7 (pdf)
Optima 9 (pdf)
Guz is offline Find More Posts by Guz
Old Apr 29, 2010, 07:59 AM
United States, NJ, Flanders
Joined Dec 2001
I know there is a hack of the Spectra Module to work in the Multiplex Evo. Has anyone done a hack to work in a JR 9303?
Chuck
crobinett is offline Find More Posts by crobinett
Old Apr 29, 2010, 02:10 PM
Joined Aug 2002
Thanks Chuck
No need to hack as a Hitec Spectra Pro 2.4GHz JR Module, as pictured, should be available in store June/July. "The Spectra Pro JR Module will add 20ms latency similar to other add on systems. this one will most likely be sold as combo like the current systems. Figure about $154.99 with an Optima 9 RX. - Mike"
Regards
Alan T.
Old Apr 29, 2010, 02:17 PM
Joined Dec 2001
The reason I asked about a hack is because I talked with Hitec support yesterday and they did not have a date (thought possibly next year) for the Spectra Module.
I have no problem waiting till June/July, just let me know where I can get in line to purchase.
Really like my Aurora, just want to use the 9303 for the contest planes while I transition and wait for the firmware updates (functions I am looking for are not on the list for 1.07).
Chuck
Old May 22, 2010, 07:58 AM
Joined Mar 2010
Range test with Eagletree OSD
Today I can almost achieve 3km range with optima9 receiver (altitude 600 m)
after Fail-safe active , Eagletree system bring it back to home safely .
I wonder how to extend the range such as changing rx or tx antenna???
Thanks.
menglovekai is offline Find More Posts by menglovekai
Old May 22, 2010, 08:01 AM
Romania, Dolj, Craiova
Joined Sep 2007
First try to build a $0 parabolic reflector for Tx antenna.
Assuming you are able to know what direction is the plane and point the reflector in the right direction, you will be amazed to see a jump to over 5km in range.
renatoa is offline Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Discussion Parkzone Micro Mustang TX Setups, Tweaks, Mods Tips, and Upgrades (work in progress) Flying-Monkey Micro RTF 417 Mar 25, 2013 09:28 PM
Discussion mSR TX Setups, Tweaks, Mods Tips, and Upgrades (a work in progress) Flying-Monkey Micro Helis 1137 Feb 28, 2013 08:37 PM
Discussion Micro Wings 24" and under- Setups and Tips microkites Flying Wings 689 Feb 19, 2012 09:59 PM
Undocumented Features of the Optic 6 rutat Radios 6 Sep 30, 2004 07:54 PM
Orbit Charger - Undocumented Features rscamp Power Systems 8 Jul 10, 2001 07:12 PM
