Old Nov 13, 2009, 11:52 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Tri-Gear FPV Maxie Swift
Pod is a fiberglass layup made over a positive foam mold and is attached using hard points that consist of bonded wood dowels with threaded brass inserts.
The wing is glassed in the center section, leading edge, spar area and elevons.
Using an E-Flite 25BL and APC 12 x 8E prop.
The pod is removeable for hand/bungee launching.
Gary Evans is offline Find More Posts by Gary Evans
Old Nov 13, 2009, 01:44 PM
jhoyda is offline
Find More Posts by jhoyda
Joined Jul 2008
Watching with interest.
How well does that elevon routing work?
It seems like it might bind, but it sure is a clean installation!
jhoyda is offline Find More Posts by jhoyda
Old Nov 13, 2009, 02:05 PM
Mesa, Arizona
Joined Nov 2006
No binding. Sullivan flexible nylon control rods. They will handle a 2 1/2 inch radius.
Old Nov 13, 2009, 03:24 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
In your pix You have no real torque on your cotroll linckage.
If you get it going fast your servos might pull but you have the wrong geometery to the horns to get them moving .
The flexible rod will bend down and touch the wing top and the controll will be mushy and non existant at medium speeds.
The maxi swift is famous for having these isuues already and your control rod install angles and clevis attached to the bottom hole makes for some possible problems.
What servos are you using?
klique is offline Find More Posts by klique
Old Nov 13, 2009, 03:52 PM
Mesa, Arizona
Joined Nov 2006
The Maxie Swift elevator control problem at speed is related to the extremely flexable elevons which bend under stress which is why I glassed mine and they are now very rigid. There is no problem with elevon control at the speeds mine flys. If I wanted something that flys fast this wouldn't have been the first choice. For FPV my goals is primarily slow flight.
The photos shown are of construction and my stuff constantly evolves. I'm not using the bottom control horn holes.
Old Nov 13, 2009, 03:58 PM
klique is offline
Mum is the word!
Joined Jun 2003
Good ,at the bottom it would be verry poor.
Done in a very stout way it will fly with a much better feel of controll .
I like your landing gear ,thats cool.
ck
http://www.rcgroups.com/forums/attac...2&d=1187462428
Old Nov 14, 2009, 12:05 PM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Love the pod idea, would be an interesting addition to my Zephyr.
I would be tempted to make the rear wheels individully attached to the airframe to get a bit more width (our field is grass and has a few lumps so width=good)
Love the idea, as a modifiction, could you use the steering servo to also pan the camera while flying ?
On the control rod issue, if you do find you have down flex (my zephyr had that as I forgot to brace the rods), what i have found is make the outer red tube longer so it goes almost all the way to the end of the yellow inner rod, get some PVC tape and tape on one side between the wing and the rod, then use a glue gun, to fill in the area, like building a bridge of glue under the rod, then use a second piece of tape on the otherside to finish the job, you end up with a Tape/glue/Tape sandwich that looks tidy and like you ment to do it from the start :-)
matwelli is offline Find More Posts by matwelli
Old Nov 15, 2009, 08:46 PM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Hey Gary,
Now that is cool!! i need one of those
G-unit is offline Find More Posts by G-unit
Discussion Small FPV gear jimbob00 FPV Talk 11 Nov 09, 2009 06:23 AM
Discussion FPV gear stolen! pajo1981 FPV Talk 14 Oct 25, 2009 07:51 PM
Sold 2.4Ghz FPV gear, price reduced! MinneFlyer Aircraft - General - Miscellaneous (FS/W) 4 Sep 10, 2009 09:46 PM
Sold FPV gear 2.4ghz - AV Tx/Rx, Antenna MinneFlyer Aircraft - General - Miscellaneous (FS/W) 0 Aug 30, 2009 08:44 PM
Converting tri gear into a tail dragger? JIMJAM Parkflyers 5 Aug 11, 2003 11:30 PM
