Old Sep 18, 2001, 03:08 PM
jsc is offline
jsc
Find More Posts by jsc
jsc
Where does it all end?
Boise/Nampa Idaho
Joined May 2000
Transfer of prints to wood for cutout
Can someone please explain to me the method of transferring prints to wood for cutout. Thanks in advance.
Jeff
jsc is offline Find More Posts by jsc
Old Sep 18, 2001, 04:15 PM
Ron Cichowski is offline
Find More Posts by Ron Cichowski
Old Guy
Ron Cichowski's Avatar
Carver, MA USA
Joined Jun 2000
Some people photocopy the original plans (plain paper toner based system or laser printer). They lay the photocopy on the wood and wet out the paper with acetone. Acetone will dissolve the copy toner and leave an image on the wood.
Ron
Ron Cichowski is offline Find More Posts by Ron Cichowski
Old Sep 18, 2001, 04:43 PM
p471701
p471701
Guest
n/a Posts
jsc: i make a photocopy of the part, lay it on the wood and use a regular clothes iron on high heat. works pretty well.........gregg
Old Sep 18, 2001, 05:02 PM
Rotten Robbie is offline
Find More Posts by Rotten Robbie
Rotten Robbie's Avatar
Kent, Wa.
Joined Feb 2001
I use Tee Shirt transfer paper. It works just fine.
But don't screw up your wife's iorn. I messes up my daughters. I had to buy her a new one. Now she has a better iron, and I have my own.
Robbie
Rotten Robbie is offline Find More Posts by Rotten Robbie
Old Sep 19, 2001, 07:36 AM
Dsegal is offline
Find More Posts by Dsegal
Dave Segal
Philadelphia PA USA
Joined Jun 2001
For a discussion of various methods of making patterns see "Building From Plans" at www.krc.org/index_info.htm
Dave Segal
Keystone RC Club
Dsegal is offline Find More Posts by Dsegal
Old Sep 19, 2001, 08:09 AM
Slope Nut is offline
Find More Posts by Slope Nut
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Sheesh, that was in depth
I just photocopy the darned plan, cut out the part from the copy, 3M77 it to the wood, cut it out, and pull the copy paper off the wood. Works well for me!
Greg
Slope Nut is offline Find More Posts by Slope Nut
Old Sep 19, 2001, 08:10 AM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
I use a spray glue from Wal-Mart's craft section. Spray it on the back of the paper templates and let it dry a few min. Stick it on the wood and cut out, then peel the paper off.
You can scan the template into the computer and print out all the copys you want.
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old Sep 19, 2001, 08:12 AM
FANMAN is offline
Find More Posts by FANMAN
Always looking UP
FANMAN's Avatar
Lilburn, Georgia, USA
Joined Nov 2000
Easy remedy
I use 3m spray glue, lightly spray the back of each paper template, lay it on the wood, and cut following the lines, if you spray the paper just right, it normally peels right off the cut part!
FANMAN is offline Find More Posts by FANMAN
Foxtrot is offline
Find More Posts by Foxtrot
Foxtrot's Avatar
Kodiak AK USA
Joined Jun 2000
I do the same as Slope Nut. Print. Roughly cut out the part in
question. I use stick glue instead of 3m77 though. Works great
for me.
Foxtrot is offline Find More Posts by Foxtrot
Old Sep 19, 2001, 12:30 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
I use the photocopy and clothes iron method. Make your copies darker than you would sey for reading an article. The extra toner helps make the image on the wood darker.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Sep 19, 2001, 10:00 PM
David Pentland is offline
Find More Posts by David Pentland
Surrey B.C. Canada
Joined Nov 2000
I get my plans copyed by a "real" printing shop, so the plans don't get "streached" like a photocopier does. Then I use 3M Spraymount to stick the paper to the wood. It peels off a lot easier than 3M 77 contact spray.
David Pentland is offline Find More Posts by David Pentland
Old Sep 19, 2001, 10:13 PM
USA, NC, Greenville
Joined Dec 1999
David - I have used the photocopier at the local library, placed a scale next to the image of the part being copied. As others noted above. Streaching wes not realy an issue.
Old Sep 19, 2001, 11:24 PM
Quacker is offline
Find More Posts by Quacker
ClearView Rocks!
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
Burn, baby, burn!
Hey, forget those old-fashioned methods! I use a 3.5 KW excimer laser which I CA'd to a precision, high-speed XY flatbed plotter. I feed in the plans in a binary format derived from Autodesk's DXF format. The 20 megabyte on-board buffer in the plotter holds the entire file with room to spare. (I usually keep several menus form local Chinese takeout kitchens in there as well). I then place the balsa sheet on the plotter bed which has been enhanced by replacing the bed material with that from an air-hockey table with the air pump inlet and outlet swapped. Then I turn on what is now the vacuum pump. This holds the Balsa sheet flat and tight against the bed. I slip on my safety goggles and run up the laser onto a water-cooled graphite target until it comes up to full power, then I fire up the plotter. In about 2.5 seconds an entire piece of 1/16" x 3" x 36" wood is reduced to a highly accurate collection of ribs, gussets and other assorted parts. The entire setup only cost me about $175,000.00 to slap together! Since I've already built 3 planes this way, I figure it only cost me just over $58,000.00 each. (Seems reasonable). One last note: if you try this, don't forget to vent the vacuum pump outside or the smell of burning balsa might be overwhelming or even set off your smoke detectors. I also highly recommend that you keep your cat out of the room during the entire operation.
Quacker is offline Find More Posts by Quacker
Old Sep 19, 2001, 11:36 PM
USA, NC, Greenville
Joined Dec 1999
Pulling our leg, right ? Quacker.
Old Sep 20, 2001, 08:21 AM
Dsegal is offline
Dave Segal
Philadelphia PA USA
Joined Jun 2001
I can assure you that the rubber rollers in print machines can wear and age and the paper can slip producing quite distorted prints.
Dave Segal
STEP by STEP PARTS TRANSFER TO YOUR WOOD... Demon-Leather Scale Kit/Scratch Built 110 Dec 06, 2007 12:01 PM
How to transfer plans to wood? War Bird Radio The Builders Workshop 5 Jun 26, 2003 02:38 PM
Building parkflyers from plans: How to transfer plans to wood? War Bird Radio Parkflyers 13 Jun 20, 2003 09:58 PM
Cutting wood for a scratch build... alaric Beginner Training Area (Aircraft-Electric) 4 May 21, 2002 11:44 PM
