Well it is obvious that something is wrong here and that the test needs to be conducted over and over until the results match the popular consensus which your's does not.
I have read post after post about the ones you tested the Crimped APP is the best by far. Some have even stated that even a soldered APP is better that a Dean's Ultra. Upon closer inspection I note two problems with you testing. Having the array laying on carpet ,which by the way look just like mine, is possibly inducing some additional random electrical paths and that you connected them all in series to make it simpler and only tested at one level.. Mark I conduct connector tests with every battery test discharge I run and their have been more than a few. I know which connectors get hot and at which power levels. I have tried to point out that APPs are not as great as most seem to think but most do not want to hear it. Good luck with the masses. Charles |
Space Coast
Joined Oct 2000
Nice job Mark,
If you do it again I'd be real interested in how a mini Deans performs in relation to the others. I've been using them in all planes with less than a max 20A draw and have not noticed them getting warm. It would logically seem that they shouldn't be performing that well. |
So. Cal.
Appreciate the comments guys.
I did this test to placate my own curiosity for the most part and while a larger sample size is required to provide statistical significance to the numbers, this test told me that the above connectors are effectively identical in terms of real world performance for 99.9% of us whose planes draw less than 100 amps and a few 1000 watts. It's also my firm belief that any results that deviate significantly from the above would be attributable to either defective connector or improper termination be it bad solder joint or bum crimp. Note that after the resistance of the bus wire is tared out, the real Deans has the effective resistance of an equivalent length of 13 gauge wire, which is pretty impressive. APP is roughly equivalent to 14 gauge wire. The remaining two are just slightly worse than an equivalent length of 16 gauge wire. Once again, none of these are going to be readily discernible from one another in a typical application. Now if I only had a machine that could do a few thousand mates and demates, we could see how each of these perform over time. Maybe I'll see if the neighbor kid needs to earn a buck... MrMel, Would be curious to see the results of your 150 amp test. A burst test with periods of lower current draw would probably be most telling as I know of precious few who draw that kind of current for an extended period of time. Charles, Test was actually performed with the whole mess hanging in free air above the dielectric surface of my charge 'bench'. My lovely carpet was merely the backdrop for the photo before testing. As mentioned above, I agree that more samples are required to lend more weight to the numbers but I felt that testing half of the connector would tell me all I wanted to know and that I could simply double the voltage drop number since both halves within each connector are physically identical with one another. Hoppy, Will fish out a Deans micro and slap it on the end and repeat and post results after I've had my coffee. ![]() Mark |
So. Cal.
Nope, probe contact resistance is zeroed out as I'm merely measuring voltage and thus no current is flowing through the meter. That said, I did hit the bus wire with 240 grit to remove surface oxides to facilitate solder flow and allow for easy meter readings.
![]() Thanks! Mark |
So. Cal.
Here you go Hoppy.
Resistance across Deans Micro was 1.52mOhms. Pretty tidy for such a little bugger. One guy I know uses these for everything. Have seen him use them on a 4 cell EDF pulling upwards of 50 amps. Not something I'd do mind you but it sure put a grin on his face. Photo below of added Deans Micro for anyone who may not trust my integrity. ![]() Mark |
So. Cal.
I do have the battery end that I chopped off some HC lipolys but unfortunately do not have the mating end. I would expect them to be in the same ballpark as the above.
Also have some HXT 4mm's that I'll throw in the mix if I can figure out how to extract the contacts from the housing without destroying them. May dig into my bins full of 3.5mm and 4mm gold bullets as well. Right now I'm going to head out and discharge my 'loads' since I'm taking the day off. ![]() Mark |
| Thread Tools | |
| Video Justin Jee - Trex 700N Flight - New Rotor Blade Test - Oct 11, 2009 | red_z06 | Fuel Heli Talk | 6 | Mar 30, 2010 03:58 PM |
| Discussion Tight dean's connector | ccowboyearl | Beginner Training Area (Heli-Electric) | 11 | Oct 02, 2009 10:45 PM |
| Discussion Mark's Models Sensor 117 2009! | glidin'n'slidin' | Sailplane Talk | 13 | Sep 11, 2009 09:06 PM |
| Wanted I need (5) HXT 3.5mm Gold Connector's Anybody have some to spare? | HyperHelis | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Aug 24, 2009 02:27 PM |
