Old Nov 12, 2009, 02:51 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Cool
Transmitter telemetry display
Years ago we made a poll about what people wanted for telemetry and at the time, people wanted a PC based version more than a transmitter mounted version. It is next to impossible to see a display while flying, and frankly a bit dangerous to take your eyes off the plane to look at the transmitter. But, considering that people look at timers and other things, we have decided to go ahead with our transmitter mounted telemetry display.
ALL of the transmitter modules we have produced have a telemetry display port built in. The port does not have a connector, so one much be soldered in place. We will offer a kit, and also offer the option to send in your existing transmitter module for the upgrade and new firmware required to use it.
The display is a very simple I2C COG LCD with adapter board. No price set yet, but it should be pretty inexpensive.
JimDrew is offline Find More Posts by JimDrew
Old Nov 12, 2009, 04:52 PM
pixler is offline
Find More Posts by pixler
Lucerne, Switzerland
Joined Nov 2009
Hi Jim,
very cool - can't wait :-)
- will this be possible with current MX-16 iFS ?
- any chance for an acoustic signal when arriving at a critical voltage ?
pixler is offline Find More Posts by pixler
Old Nov 12, 2009, 04:55 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
is that the eagletree powerpanel you are using?
cmulder is offline Find More Posts by cmulder
Old Nov 12, 2009, 05:55 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
No, this will not work with the MX-16. The built-in RF does not have the telemetry interface. We will have a handheld telemetry display with alarms and such. This is just a simple LCD interface.
No, that is not an Eagletree display. The Eagletree display is a 20x2, this one is a 16x2, so it is smaller.
Old Nov 12, 2009, 06:05 PM
lazer155 is offline
Find More Posts by lazer155
lazer155's Avatar
Phoenix, Arizona
Joined Jan 2009
Will it work with a dx7?
lazer155 is offline Find More Posts by lazer155
Old Nov 12, 2009, 06:33 PM
pixler is offline
Joined Nov 2009
Hi Jim,
- any chance to get another xps module into the mx-16 ? (with telemetry interface) ?
I guess there is no chance to use the telemetry station as standalone device and connect this forthcoming display/alarm device to it?
mounting such a small telemetry/warning device to the mx-16 would be of great help and security when soaring for hours somewhere in the mountains. carry a pc-laptop for 4h into the hills is not very practicable.
But - hey! what about connecting the telemetry station to the iPhone ???? = soaring for hours with cool music in my ears, and suddenly a nice ladys voice tells me to land because of critical rx voltage ? (ok - just kidding - but wouldn't that be cool? )
Old Nov 12, 2009, 07:35 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
It is possible to mod the MX-16 board (adding two wires to the CPU).
No, this won't work with the DX7.
Old Nov 12, 2009, 08:19 PM
rmteo is offline
Find More Posts by rmteo
User
Colorado
How about a graphic LCD so you can have large characters/numbers for emphasis as well the ability to display graphs, etc.
rmteo is offline Find More Posts by rmteo
Old Nov 12, 2009, 10:24 PM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
Why? I have been using thermal sensors in my cross country sailplanes since 1975 and wouldn't take my eyes off the model to look at a screen. Wouldn't take my eyes off the model for the pattern models or pylon racers I used to fly either so a display on the transmitter would be useless. I want to use telematery for performance measurements so I want to download the data for later analysis. Analysis of aerodynamic data was part of my job for the 32 years I worked as a wind tunnel test project engineer.
ChuckA is offline Find More Posts by ChuckA
Old Nov 13, 2009, 12:06 AM
pixler is offline
Joined Nov 2009
ok, thanks jim. I hope I can find someone who is able to do the mod for me, because I have no knowledge in doing so.
Old Nov 13, 2009, 08:23 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Our handlheld unit has a really nice graphical LCD display. It also has a SD media card slot, speaker, USB interface, external interface, and RGB LED. Powered by a single cell 400mAh Lipo (internal).
It can be telemetry monitor, spectrum analyzer, Rx/Tx settings changer, Rx/Tx diagnostics, osciiloscope, voltmeter, ampmeter (with external clamp on), servo pulse generator, receiver servo pulse display, Hitec and Hyperion servo programmer, and more! It also has the capability to upload your own applications and run them on the box.
Old Nov 13, 2009, 09:50 AM
TopShelf is offline
Find More Posts by TopShelf
Joined Jul 2008
Very exciting stuff!
1) will the transmitter display be able to display whatever sensors you have installed or just voltage & signal?
2) When can we expect the handheld unit? I know you don't like to publish times but generalties is good enough like within 3 months, 6 months, 1 year?
3) will the handheld unit be small enough to attach to the transmitter or clip to my pocket?
Kent
TopShelf is offline Find More Posts by TopShelf
Old Nov 14, 2009, 09:03 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The display shows 2 sensors and the Rx voltage/Tx RSSI. It could be programmed to alternate display pages based on the number of sensors you have. So, we could have 4 sensors (Rx voltage/Tx RSSI would be considered 2 sensors) per display page.
Handheld unit is 4.5" x 3.25" x .9"
It can be placed on top of the transmitter (using our radio tool that plugs into the original antenna hole). You could also use a belt clip. No release date, but this a product that has been basically finished for a year. It uses our new RF hardware which is the hold up right now (FCC testing and tweaking), so I can't give you an actual release date.
Old Nov 14, 2009, 12:02 PM
jcyr1 is offline
Find More Posts by jcyr1
United States, AZ, Surprise
Joined Jul 2002
Jim,
Are we talking about a"VARIO" connection? Could this be done?
John
jcyr1 is offline Find More Posts by jcyr1
Old Nov 14, 2009, 01:42 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
It is not possible to get an audio variable with a simple telemetry display as discussed here, although it is possible ot make a more complex box that could do that.
Discussion transmitter display light/backlight ideas? spinup DIY Electronics 22 Feb 18, 2010 10:47 AM
Discussion XDP or telemtry station Richard65 Xtreme Power Systems 5 May 06, 2009 10:14 AM
For Sale RCATS Telemtry System NIB FAA Aircraft - General - Miscellaneous (FS/W) 0 Sep 22, 2007 06:46 PM
Discussion RealFlight: display transmitter in "mode 1" ? marckossa Simulators 4 Sep 19, 2007 02:36 AM
Discussion Need help with telemtry and ground station 1stCAVgrunt UAV - Unmanned Aerial Vehicles 0 Mar 09, 2007 07:43 AM
