Old Nov 26, 2009, 02:43 AM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Wow, that's really cool, Dan! I envy guys like you, Kevin and Dan Savage who 1. can design and build models like this 2. actually have the time to design and build models like this.
BTW, why did the wax turn pink after the finishing cut?
Stu.
stumax is offline Find More Posts by stumax
Old Nov 26, 2009, 02:01 PM
EDF Phantom - Kryptonic is offline
Find More Posts by EDF Phantom - Kryptonic
EDF Phantom - Kryptonic's Avatar
Joined Aug 2009
The lex looks good.
EDF Phantom - Kryptonic is offline Find More Posts by EDF Phantom - Kryptonic
Old Nov 26, 2009, 09:53 PM
eatond is offline
Find More Posts by eatond
EDF Jet Jam 2016, June 16-19th
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Stu,
Thanks. I thought it was a little dark in my shop so I changed the lighting for that 2nd shot. The incandesant light I added brought some redder tints to the scene which is what you're seeing as pink. I brewed this batch of machinable wax up all by my lonesome so I know there's no magic in it.
Dan Eaton
eatond is offline Find More Posts by eatond
Old Nov 28, 2009, 11:48 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nice work Dan!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Nov 28, 2009, 07:55 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
signing on. Nice work
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Dec 03, 2009, 06:25 PM
eatond is offline
eatond's Avatar
Joined Nov 2002
Been doing plenty of work but don't have much to show for it. I've been working on the plugs for the nose cone and canopy. The nose cone plugs are almost done. I have the front halfs of the canopy plug put together and will probably get the rear halfs machined tomorrow. My mill just isn't big enough to do it all at once.
The front end section is sheeeted as much as I can get done. The bottom part below the longerons will stay bare until I get the nose gear installed and tested.
Speaking of the nose gear I have started working on the end of the strut that holds the axle for the two wheels. Basically take a chunk of aluminum and carve away anything that doesn't look like it belongs.
Dan Eaton
Old Dec 03, 2009, 09:18 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Originally Posted by eatond View Post
........Speaking of the nose gear I have started working on the end of the strut that holds the axle for the two wheels. Basically take a chunk of aluminum and carve away anything that doesn't look like it belongs.
Dan Eaton
She's looking great Dan! Going to be a real looker when done
BTW, I like your front gaer block. I did something similar for an F-4 nose and the mains on a BN Islander Twin prop.
The axle retaining is the the cleanest way to do it and not as tough as it looks.
GregG is offline Find More Posts by GregG
Old Dec 03, 2009, 09:36 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Nice work dan ...wish i had a mill...and your cad skills
AIR SALLY is offline Find More Posts by AIR SALLY
Old Dec 04, 2009, 05:52 PM
Kevin Cox's Avatar
Joined Jan 1997
Looking good!
Old Dec 09, 2009, 02:45 PM
eatond is offline
eatond's Avatar
Joined Nov 2002
Hi Greg,
Thanks. Yeah, I wish I had known about those clips a long time ago. It really saves a lot of weight compared to a couple of wheel collars. Somebody mentioned they got the clips at Lowes in another thread and sure enough, my Lowes had them too. To make the slot for the clip, I just chucked the axle in my drill press and used a fresh hack saw blade to cut the slot. That made it quick but you could do it by hand too.
I spent a lot of the weekend milling, turning, fileing and sawing on that little block. Took a lot longer than I expected but I finally got it done. Now I have to make the scissor links and the rest of the strut.
Dan Eaton
Old Dec 09, 2009, 03:01 PM
eatond is offline
eatond's Avatar
Joined Nov 2002
Hi Roger,
Thanks. I paid my dues on that mill for about five years after I got it. My wife grew up in a small town in upper Michigan and is pretty conservative when it comes to spending money. She gave me a lot of grief over the mill but I finally won her over by making sure any chance I had to do something on the mill or lath for her I took it. Might have been less work to build a Gingery mill and lath.
You wish you had my cad skills. I wish I had your fiberglass skills. Those ducts you made for Jeff were sweet. I'm working on it though. The other thing I spent the weekend doing was priming/sanding/repeat the nose cone plugs. No matter what I do I always seem to end up with something not quite right. Always a do over. I got them to the point now where at least there's nothing glaringly obvious wrong. I'm getting ready to pour some Hydrocal to make a pair of molds.
Dan Eaton
Old Dec 09, 2009, 04:51 PM
Joined Aug 2009
Dan,
you going to make a hydraulic system for that nose wheel steering
Old Dec 09, 2009, 04:59 PM
Kevin Cox's Avatar
Joined Jan 1997
Nice Dan,
How much does it weigh?
Old Dec 09, 2009, 07:57 PM
eatond is offline
eatond's Avatar
Joined Nov 2002
Hi Gene,
nope, I'm building it in the hopes I'll need a little extra nose weight to hit the CG. Other wise, it'll probably be replaced by a silver soldered 'T' shaped piece of music wire. But it's all good, if it doesn't get used here the knowledge gained will be used shortly on a bigger and better project. Besides, a guy's gotta have a little fun.
Dan Eaton
Old Dec 09, 2009, 08:02 PM
gjmjoe017 is offline
Find More Posts by gjmjoe017
My Lipo is Bigger than Yours!
gjmjoe017's Avatar
Chesterfield,Missouri
Joined Sep 2003
Great looking build Dan,hope to see if fly when you get it finished!!!Kevin got me hooked on F-18's a few years back!
Joe
gjmjoe017 is offline Find More Posts by gjmjoe017
Discussion Midi F-15C with bifurcated exhaust duct and retracts eatond Scratchbuilt EDFs 151 Sep 19, 2010 11:59 AM
Discussion Super 70mm F-35 with Vector Thrust, Super Scale Retracts flyingcircuits Banana Hobby 1 Jan 07, 2010 02:08 PM
Discussion Century F 18 with air retracts and twin EDF motors modfly Electric Ducted Fan Jet Talk 0 Nov 09, 2009 08:50 PM
Build Log mini fan F-15C with bifurcated exhaust eatond Electric Ducted Fan Jet Talk 161 May 06, 2008 12:12 PM
