Old Nov 10, 2009, 06:31 AM
justy g is offline
Find More Posts by justy g
Burning & Turning
justy g's Avatar
Hong Kong
Joined Jan 2007
Turnigy motor smoked first run!
Hi
I have this motor by Turnigy http://www.hobbycity.com/hobbycity/s...r_Eq:_AXi_2826. I ran it on a plush 40 a esc today and the motor smoked after about 30 secs at half throttle pulling about 18 amps on 11*7 prop.
Are all electric motors this unreliable?Or is just Turnigy? Any recommendations for a reliable electric motor/esc combination?Is it a case you get what you pay for!
Jus
justy g is offline Find More Posts by justy g
Old Nov 10, 2009, 06:36 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
That shouldn't have happened. If it really was only pulling 18A.
or was that 18A at half throttle? that's a different kettle.
You don't say what pack..
Old Nov 10, 2009, 06:42 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Prop recommendations from these guys are rarely safe and you chose one that was even worse.
rich smith is offline Find More Posts by rich smith
Old Nov 10, 2009, 07:03 AM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
OH.. I am the only one this happened to TWICE..
Crap motors.. Big and Small.. the Magnet can came loose from the bell housing on mine. Started Grinding .. Then Bigg fire ball came out of the ESC..
Thanks TURDugy!!!!
OH. Yea.. Don't even think about emailing them.. NO Help at all.. I will keep my $ in the USA!!
Motrolfly, Reaper, Scorpion!!!! They ROCK!!
powerlines is offline Find More Posts by powerlines
Old Nov 10, 2009, 07:50 AM
rich smith's Avatar
Joined Dec 2006
MY COUNTRY 'Tis of Thee.... sweet land of.... (fades off)
BTW those motors are from china. And will burn out if you put too big a prop on them too.
Old Nov 10, 2009, 08:36 AM
justy g is offline
Burning & Turning
justy g's Avatar
Hong Kong
Joined Jan 2007
Ok Guys...Its Scorpion time!! Turdigy.... ROTFL
Old Nov 10, 2009, 09:07 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
we've supplied dozens of turnigy's no problem. But then we do test them first,, and supply our own ratings based on actual experience, rather than random numbers from the Chinese national lottery draw.
You cant bash the manufacturer if the distributor indulges in fantasy, and you cant bash the manufacturer if you overload their motors, either.
If that was pulling 18A at half throttle, it would have been likley to be around 54A at full, which is total overload. Even by hobbycity's standards. It might well have been pulling peak currents of over 60A at half throttle, too.
You still didn't say what pack you had it connected too, either.
Old Nov 10, 2009, 12:41 PM
Subsonic Ken is offline
Find More Posts by Subsonic Ken
Omaha Nebraska
Joined Apr 2008
What cell count was the battery, if you were using a 11x7 I think 4s 14.8V would be the max and probably would pull 60 plus amps on 5s 18.5V
Subsonic Ken is offline Find More Posts by Subsonic Ken
Old Nov 10, 2009, 03:07 PM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Originally Posted by justy g View Post
Hi
Jus
Hi Jus
Your Turnigy is in the class "Kv 900 rpm/V wght 163g"
On 4S with an APC 11x7E it is overpropped
But I don't know if you are 3S or 4S (?)
You could compare using Scorpion Calc freeware
SII 3020-890 (I measured Kv 865 rpm/V on my sample), wght 166 g
On APC 11x7E that Scorpion consumed 42A on 4S = 623 W
The ratio is 3.75 W/g very high for Kv 865
Suppose your Turnigy is 920 rpm/V (generally HC is announcing lower Kv than real) it's normal to smoke it or to smoke your 40A ESC or both
Louis.
Fourdan is offline Find More Posts by Fourdan
Old Nov 10, 2009, 03:47 PM
justy g is offline
Burning & Turning
justy g's Avatar
Hong Kong
Joined Jan 2007
Running a 4s1p 20c 3000mah battery, 11x7 folding prop, 40 a esc.
Old Nov 10, 2009, 04:09 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
What brand and type of prop?
hoppy is offline Find More Posts by hoppy
Old Nov 10, 2009, 04:10 PM
RobC(UK) is offline
Find More Posts by RobC(UK)
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
FYI
Turnigy 3548 900kV with 11 X 7 APC E.
That's 920W for 61A.
RobC(UK) is offline Find More Posts by RobC(UK)
Old Nov 10, 2009, 06:24 PM
miche is offline
Find More Posts by miche
miche's Avatar
Joined Oct 2008
I have same motor TR35-48-B-900kv, Aeronaut prop 11x8, , Hyperion g3 4S lipo batt.35/65C, ave. 50amp, power between 700 and 800 watt, max. burst 7 sec., no problem yet.
miche is offline Find More Posts by miche
Old Nov 10, 2009, 07:13 PM
skyking1231 is offline
Find More Posts by skyking1231
uhhh....this thing on?
skyking1231's Avatar
Long Island, NY USA
Joined May 2005
could have just been a 'bad' motor.
skyking1231 is offline Find More Posts by skyking1231
Old Nov 11, 2009, 12:07 AM
justy g is offline
Burning & Turning
justy g's Avatar
Hong Kong
Joined Jan 2007
So by going by this set up i was not using too big a prop.. or was I?
I just want a reliable setup using an Aeronaut 11x7 folding prop and Flightmax Zippy 4s1p 3000 mah battery...any recommendations of a proven design would be welcome.
Its to go in a ASW 28 glider 2.5m auw approx 2400g
Jus
Discussion Chris Craft First Run! xraycajun Scale Boats 25 Aug 26, 2010 08:12 AM
Discussion Run brushless motor at full speed constantly solarblue Racing Boats - Electric 10 Oct 31, 2009 07:04 AM
Discussion how do i run a mega motor 400/7/16 faster zjoe555 Power Systems 1 Oct 29, 2009 04:59 PM
Discussion Buying The Futaba 8FG First Run? zero2444 Radios 12 Oct 19, 2009 08:07 PM
Discussion Brand New CC Phoenix 25 smoked during first run A.T.A.C. Castle Creations 4 Feb 11, 2009 09:19 PM
