Old Nov 10, 2009, 06:07 AM
flyboy320 is offline
Find More Posts by flyboy320
flyboy320's Avatar
Canada, ON, Burlington
Joined Sep 2004
Source for a 32mm spinner that takes a 6mm shaft?
Having a hard time trying to find the above spinner that will take a 6mm shaft. I have found one that uses a grub screw, but was hoping to find one that small that uses a clamp style.
Anyone have any good sources?
flyboy320 is offline Find More Posts by flyboy320
Old Nov 10, 2009, 06:38 AM
Michael Richards is offline
Find More Posts by Michael Richards
Sherbrooke Qc
Joined May 2006
Check out this page, near the bottom of the page in the aluminum precision spinners.
Its not 32 mm but it is pretty close (30mm) and with a 6mm shaft.
http://www.icare-rc.com/spinners.htm
Cheers Mike
Michael Richards is offline Find More Posts by Michael Richards
Old Nov 10, 2009, 07:23 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
iCare would be easy for you to deal with being 'up there'..
The RFM spinners work great, however..
..a
Old Nov 10, 2009, 08:17 AM
flyboy320's Avatar
Joined Sep 2004
I was actually going to a HM spinner from Puffin Models but the 32mm has only a grub screw, but starting from 35mm and up, it uses a clamp style to fix onto the shaft.
This setup will be using a kontronik fun 500/27 5.21GB, a 18x7 prop and a 3S lipo. Will a grub screw spinner be OK, or for that size setup should I be looking more for the clamp style?
I was hoping to get a black spinner so the search continues...
Old Nov 11, 2009, 05:40 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Grub screws work better than collett style as you go up in power. All the F5B guys are using them.
..a
Old Nov 11, 2009, 09:19 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
..a
Not really--collets are better for securing things at high power--there is much more surface area doing the work. Also you don't have to hack up the shaft to get the set screw to hold...
Steve
sneu is offline Find More Posts by sneu
Old Nov 11, 2009, 09:27 AM
flyboy320's Avatar
Joined Sep 2004
Mrs
Steve
That's what I actually ended up going with. A 35mm HM spinner with a clamp style. It was the smallest spinner that I could find with the collet style, any smaller and they were set screws. It will be slightly larger than I need, but it should at least be secure.
Old Nov 11, 2009, 10:47 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Steve
I stand corrected. I thought you guys still used RFM stuff..
..a
Question 30mm Spinner for 5mm shaft? Thekid3418 High Performance 19 Jun 03, 2015 03:58 PM
Sold Never used white RFM folding spinner - 38mm for 6mm shaft verticalflight Aircraft - Electric - Power Systems (FS/W) 1 Sep 15, 2008 02:57 PM
Wanted Folding spinner 40mm shaft 6mm yoke 8mm tiju000 Aircraft - Electric - Power Systems (FS/W) 0 May 15, 2008 09:40 AM
FS: RFM Carbon 32mm spinner for folding props (4mm shaft) kyril Aircraft - Electric - Airplanes (FS/W) 1 Jun 08, 2004 09:57 AM
Spinner for 6mm shaft old p47 Power Systems 1 May 04, 2004 12:24 AM
