Old Nov 08, 2009, 09:05 PM
cptsnoopy is offline
Find More Posts by cptsnoopy
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Offsetting constant spring pressure on servo with counter force spring?
I have heard and read some discussions involving using a cable/spring setup for elevator and rudder control. I understand that there is a constant force applied to the servo causing additional drain on the battery. Would another spring used in the opposite direction attached to the servo arm at the same distance out as the one used at the elevator/rudder (arm length) a plausible idea for reducing loads on the system? Maybe this is already done, I would not have a clue as I personally have not used this system or even seen one in person. Just curious.
Charlie
cptsnoopy is offline Find More Posts by cptsnoopy
Old Nov 08, 2009, 09:10 PM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
On further thought, the pivot distance at the servo would not be feasible as there is generally not much room where the servo is mounted. Perhaps a stronger spring would be required because of the shorter arm length at the servo.
Charlie
Old Nov 08, 2009, 10:19 PM
soarluck is offline
Find More Posts by soarluck
soarluck's Avatar
Canada .the great
I think the whole idea is to save weight which the additional spring would defeat .The real cure is push/pull but it weights more than pull/spring SL
soarluck is offline Find More Posts by soarluck
Old Nov 08, 2009, 10:55 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
What's wrong with good old stainless? It's low maintenance and it typically works.
tom43004 is offline Find More Posts by tom43004
Old Nov 08, 2009, 11:38 PM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Push/pull is what I use. And so far I have not needed to reduce the weight enough near the rudder/elevator to consider using pull/pull or pull/spring. But if tail weight was an issue and pull/spring is lighter then maybe this would help keep the CG more in line.
Perhaps the constant strain on the servo is not enough to worry about? I was under the impression it might be an issue.
Charlie
Old Nov 09, 2009, 12:09 AM
dbaya is offline
Find More Posts by dbaya
dbaya's Avatar
United States, CA, Union City
Joined Mar 2004
I have used the pull-spring method on my DLG for a few years now. At first I was skeptical. I did worry about the constant spring tension on the servo. I'm using it on a full flying stab, analog servo. No issues with draining the battery, servo's are not failing and seem to be centering just fine.
dbaya is offline Find More Posts by dbaya
Old Nov 09, 2009, 12:29 AM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Ok, sounds like it is a non-issue. Thanks
Charlie
Old Nov 09, 2009, 12:54 PM
jrerickson is offline
Find More Posts by jrerickson
jrerickson
jrerickson's Avatar
Valencia, CA
Joined Jan 2005
I'm using pull/spring on my new Predator. The spring part is a small rubber band. What's nice about the system is that you can take the rubber band off for storage; no tension.
John
jrerickson is offline Find More Posts by jrerickson
Old Nov 09, 2009, 03:22 PM
Richard S is offline
Find More Posts by Richard S
Stream Team Models - Pilot
Richard S's Avatar
Milton Keynes, UK
Joined Oct 2005
Normally the geometry means that the force on the servo at-rest, is taken up by the friction in the gear-train.
Richard S is offline Find More Posts by Richard S
Old Nov 09, 2009, 08:53 PM
John255 is offline
Find More Posts by John255
Pensacola, FL, USA
Joined Dec 2000
Charlie
Charlie,
I use SS wire which also doubles as the antenna.
However, increased battery load has been suspected, but I've not seen it measured.
With 1900+ post you've been around a while and you may just have a WattsUp power meter, or have a power flying buddy who has one.
The WattsUp measures peak amps and also amp/hours. You could hook it up in series with your Rx find out just how much load the spring is giving compared to swinging the servos with no load.
BTW, the Ah reading has to be divided by hours or parts of hours to get average current for the transient servo load.
I'd like to know too.
Good luck.
John255
John255 is offline Find More Posts by John255
Old Nov 11, 2009, 08:31 AM
John255 is offline
Pensacola, FL, USA
Joined Dec 2000
Whoa!!
Didn't mean to shut down the thread!!
It was just a suggestion to settle the guessing.
John255
Old Nov 11, 2009, 08:50 AM
Where is the lift?
cptsnoopy's Avatar
USA, AZ, Phoenix
Joined Nov 2005
Hi John,
I have been preoccupied with work this week which has left zero time for testing the concept. You have done nothing wrong.
Charlie
Old Nov 11, 2009, 09:31 AM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
kcaldwel is offline Find More Posts by kcaldwel
Discussion Problem with E-flite S75 servo on my Axe CPv3 airbagit13 Electric Heli Talk 1 Oct 21, 2009 06:16 PM
Question Help with installing an on/off switch into a motor/ESC/servo set-up arukum17 Power Systems 3 Oct 09, 2009 03:21 AM
Wanted quadra 50 spring,for spring starter wawapilot Aircraft - Fuel - Engines and Accessories (FS/W) 4 Aug 31, 2009 05:56 AM
constant fuel pressure? Michael Jackson Engines 2 Oct 30, 2003 10:48 PM
Force on Control Surfaces, Servo Torque Reqmts green66 Electric Sailplanes 2 Mar 10, 2002 05:29 PM
