Old Nov 07, 2009, 11:51 PM
gravityKills is offline
Find More Posts by gravityKills
like a rock!
gravityKills's Avatar
Finland
Joined Oct 2007
T-Rex 600 flybarless conversion (Outrage): How low is too low?
Hello,
I'm converting a T-Rex 600 NSP with the Outrage .50 flybarless head. Now the blades sit at least 1 cm lower than with the stock head. Possibly even 2 cm, if I keep the default linkage lengths and use the upper hole for the jesus bolt.
The question is, when do I risk a boomstrike?
- The stock head is supposed to work with cheap 620 woodies and soft dampers.
- I use rather stiff 600 CF blades and hard dampers
gravityKills is offline Find More Posts by gravityKills
Old Nov 09, 2009, 05:18 AM
Gadget01 is offline
Find More Posts by Gadget01
mad heli scientist
Gadget01's Avatar
United States, OK, Oklahoma City
Joined Dec 2005
I converted my Swift 16 and 550 to flybarless with the 3DX head and Sk360 system. Before I had the 3DX head, I converted the stock head and drilled into the head block for extra main shaft clearance, which allowed me to use the the uppermost hole (previously used to capture the flybar bearings) for the J-bolt. This lowered the head about 2cm lower than stock and I had no problems.
Gadget01 is offline Find More Posts by Gadget01
Old Nov 09, 2009, 06:47 AM
like a rock!
Finland
Joined Oct 2007
Thanks. In the meantime, I decided to simply go for it and try.
Now I have flown two tanks, no boomstrike so far (knock on wood).
Wanted T-Rex 600 with Scale Body glmurphy Aircraft - Electric - Helis (FS/W) 0 Sep 20, 2009 09:00 PM
For Sale Flybarless Align T-rex 600 E CF with a PhotoshipOne front mount impreza54 Aircraft - Electric - Helis (FS/W) 0 Aug 25, 2009 10:10 AM
Discussion Flybarless T-Rex 600 V-Bar Neu 1515 2.5 FP evo 20 4900 t-rexn8 Electric Heli Talk 1 May 27, 2008 03:52 PM
Discussion Probar Stabalized Flybarless T-REX 600 Video Eco8gator Electric Heli Talk 8 Nov 29, 2007 06:51 PM
T-REX 450 - Flybarless conversion Azoa Mini Helis 1 Nov 01, 2004 02:22 PM
