Go Back   RC Groups > Boats > Submarines
Old Nov 07, 2009, 12:45 PM   #1
polarisdave
Send a message via MSN to POLARISDAVE
Tiny motors
im looking for small motors about the same diameter as a AA battery I want to try to make torps with motors but so far cant find motors small enough
POLARISDAVE is offline Find More Posts by POLARISDAVE   Reply With Quote
Old Nov 07, 2009, 12:57 PM   #2
jaguar75's Avatar
Small Motors
You can use small cell phone vibrator motors.
jaguar75 is offline Find More Posts by jaguar75   Reply With Quote
Old Nov 07, 2009, 03:27 PM   #3
MFR
Take a look at Conrad.com, i found there my minimotors for my electric torpedo's.
Available in 3,2 V and 1,5 V, diameter 10 mm, ordernumber 233965 (1,5 V)
MFR is offline Find More Posts by MFR   Reply With Quote
Old Nov 07, 2009, 03:36 PM   #4
Tygum Lagoon Terror
nick_75au's Avatar
GWS IPS motors are 12 mm diameter and 40 mm long, Hobby shop should be able to source them, I use 3 in my 1/72 Schnell boat on 1/2 inch props and Ive never got to full speed (too fast)
Nick
nick_75au is offline Find More Posts by nick_75au   Reply With Quote
Old Nov 07, 2009, 04:11 PM   #5
RC sub dude
CaptainNemo12's Avatar
Try ordering spare tail prop motors for RC helicopters, they are usually small enough.
CaptainNemo12 is offline Find More Posts by CaptainNemo12   Reply With Quote
Old Nov 07, 2009, 05:50 PM   #6
Yea. Tail motors from the mini helicopters are pretty small. I have some here that are 4mm diameter and I have made a prototype electric torpedo with one.
Finding a tiny prop is the next issue!
Steve2381 is offline Find More Posts by Steve2381   Reply With Quote
Old Nov 08, 2009, 10:11 AM   #7
polarisdave
motors
ok cool thanks for the ideas guys lol like most people i have like 6 old cell phones jsut laying around will try that and MFR i will look into that website as well i love your torp vids man those things rock. and i will go to my hobby store and see about tail motors. will keep you guys informed on my build if you want thanks again dave from saskatoon
Old Nov 09, 2009, 10:32 AM   #8
You can also pirate the motors from old servos. Some of them are pretty small.
Silver Streak is online now Find More Posts by Silver Streak   Reply With Quote
Old Nov 09, 2009, 10:44 AM   #9
Man from Atlantis
Sub culture's Avatar
http://www.indoorflyer.co.uk/pager-motors-91-c.asp
Sub culture is offline Find More Posts by Sub culture   Reply With Quote
Old Nov 09, 2009, 11:59 AM   #10
Nick
Where did you get the 1/2" props?
Yehya is online now Find More Posts by Yehya   Reply With Quote
Old Nov 10, 2009, 01:07 AM   #11
Tygum Lagoon Terror
nick_75au's Avatar
Hi Yehya
They were from Classic Warships or something like that, they were scale replacements for the Revell Schnell Boat in cast white metal, I had to drill out the hub and lock-tite them to my shafts. Tiny silicon fuel tube for couplers.
Nick
Old Nov 11, 2009, 04:56 PM   #12
You can use small square KS tubing for a hub and snip blades from shim brass. Solder the blades to the brass hub on an angle. They are so small that bending the blades into a pitch is not necessary. I have also used square plastic tube and very thin ABS sheet to make small props. The work fine.
Farm Flyer is offline Find More Posts by Farm Flyer   Reply With Quote
Old Nov 11, 2009, 09:09 PM   #13
You could also resin cast small props from different sub models to use. That way, when you do lose a torpedo or two, it's not as big of a deal.
Britt
BrittB is offline Find More Posts by BrittB   Reply With Quote
Old Nov 12, 2009, 08:10 AM   #14
the GWS IPS motors are available in different winds. There are ducted fan versions for speed, or geared versions replacements. Cost around $10 .
Frank
fgroza is offline Find More Posts by fgroza   Reply With Quote
Discussion Tiny motors using 14mm Stators from Colorado/Travan Tape Drives evdo Electric Motor Design and Construction 21 May 04, 2006 12:36 PM
Wanted GWS EDP50 XC motors and tiny controllers eatapogy Aircraft - Electric - Power Systems (FS/W) 1 Jan 04, 2006 09:28 PM
Tiny motors jfcgnv Indoor and Micro Models 5 Dec 05, 2005 07:15 PM
4 tiny motors for RFFS-100??? phuffstatler Indoor and Micro Models 1 Apr 24, 2003 04:39 PM
Know anything about tiny motors? Help! Monouk Indoor and Micro Models 1 Mar 07, 2003 09:08 PM
Bored? Want to fight?
Join the RCGroups clan!
