Go Back   RC Groups > R/C Blogs > nsg's blog
This thread is privately moderated by nsg, who may elect to delete unwanted replies.
Old Nov 07, 2009, 08:49 AM   #1
nsg
Setting up Cularis & JR9303 - switch and channel assignments
The second of two posts on setting up JR9303 to control a Multiplex Cularis glider. Setting up the Tx.
Rx channel assignments (wire->Rx socket):
Left Aileron->Throttle
Right Aileron-> Aileron
Elevator, Rudder->Elevator, Rudder
Right flap ->Flap
Left Flap ->AUX1
ESC->AUX2
BEC->batt2
Setup, device selection
Flight modes enabled
Speed INH
LAUN L3P SW Rev
MOTO Spoiler stick
Flap flap lever
AUX2 INH
AUX3, AUX4 default
TRIM: FM
Wing type: dual flaps
FUNC LIST:
ELE->FLP: not set up
AIL->FLP: Pos. 1 30%, Pos0: 0%, activated in all three flight modes
Differential +40% for ailerons, all modes, flaps, cruise and launch.
Flaperon Mix +10% fprl, 0% elev
Aileron->rudder, 30% cruise only
Butterfly mix Spoiler->flaperon Pos0 -50%, spoiler->flap Pos0: +70% spoiler
offset +170
Flap rate 20%, cruise only, that affects camber adjustment
Motor hold: off for launch, on for other flight modes, on for Aux4 (throttle hold switch). The motor is controlled by throttle stick in launch mode, switching FM or hold switch will kill the motor.
Mixes:
MX1, spoiler->elevator mix curve. Reverse default from the manual.
MX2, MOTO->ELEV, Launch only, 0, 2%, 8%. This reduces the tendency to pitch up at full power
MX3, MOTO->AUX2, Pos0 0% to +100%, pos1 +100% to +100%, active in launch mode only. That lets throttle stick control throttle in launch mode.
All control surface deflections per MPX manual.
Maiden flight went ok, very minor trim adjustment was necessary. This was my first glider, so some things may seem ok to me which really aren't, but I saw nothing obviously wrong. Like a sailboat, you need to think ahead a bit, everything takes a second or two.
The power is adequate, it goes straight up at WOT. The built-in BEC may be enough - will measure in-flight current, may get rid of the external BEC based on the results.
nsg is online now Find More Posts by nsg   Reply With Quote
Discussion Setting up the flaps on my Cularis???? rvski Beginner Training Area (Aircraft-Electric) 7 Nov 07, 2009 06:18 PM
Discussion Setting up flaps on my Cularis? rvski Beginner Training Area (Heli-Electric) 1 Nov 04, 2009 01:18 PM
Discussion Setting up a Fullhouse + Spoiler sailplane with JR9303 Radio tiju000 Sailplane Talk 6 Feb 27, 2007 07:55 AM
Bored? Want to fight?
Join the RCGroups clan!
