| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Glowing orange electronics sux
Rudder needed to takeoff?
This is probably a rhetorical question but.... I ran into a little problem here, designed a multipurpose ship but I forgot that I needed a rudder! It just so happened that I only had 2 servos to use and a nice power-plant and I wanted a plane which could 1) slope soar 2) be acrobatic and 3) land on snow and water and take off. Found a great place on the beech to fly, need to clear the dead birds though
. But yeah.The design is original basically its a single float with wings but just a flat hulled rectangular hull. Very basic. With a single overhead mounted engine and rubber banded on wings. Should be a very robust all foam design. So as long as I point it away from land I should be able to gun it and take off right?... What If I mixed the rudder and elevator together(would kinda suck nice turns but no barrel rolls(well axis rolls)) I'm going to try for a relatively thin airfoil that way my ailerons don't have to be too big and can make the bird do some nice maneuvers. Will really need to strap the motor down and other outer extremity parts. Anyhow what do you guys think? Will she get on step fine? The attached image is just a scanned sketch, this will be made out of blue FFF material. Nothing fancy but I hope its rugged and will work. The main goal was for simplicity and multipurpose as well as most fun too. |
#2 |
Seaplane Nerd
Non-rudder airplanes tend to be hand-launched. Lotsa times you need to correct direction on takeoff, and taxiing back without a rudder is likely to be monumentally unsuccessful.
Mixing rudder with elevator is kinda scary, but you could mix rudder with aileron and fly quite nicely. You can get by without a water rudder. I have had many floatplanes that did so. But you will find it hard to live without an air rudder. Rudder and elevator work well with some dihedral. Plenty of 3-channel planes fly this way. |
#3 |
My PZ Spit on floats has a water rudder but no air rudder . I have not had any problems taking off or landing .
#4 |
Relax, have a Cub
If it were me, I would spend another ten bucks and buy a servo for rudder.
#5 |
Yeah I'm sticking with the 3ch for now, trying to get a servo to come to life. Got a big list to buy around Christmas of parts lol so I can have more than one plane at all times.
| Thread Tools | |
| Discussion Ail to Rud Mixes on landing/ takeoff | Billymac | Scale Sailplanes | 40 | Nov 03, 2009 08:45 PM |
| Discussion Rudder needed | LJH | Hand Launch | 10 | Oct 31, 2009 10:52 PM |
| New Pilot need Help? Is Rudder really needed? | PrasadL | Electric Plane Talk | 26 | Apr 13, 2005 11:10 AM |
| Gerasis Fox Rudder Setup - Help Needed | surfimp | Slope | 15 | Mar 18, 2004 11:41 AM |
| V-tail rudder needed? | KeithK | Electric Sailplanes | 8 | Mar 07, 2002 08:43 PM |
