Go Back   RC Groups > Aircraft - Sailplanes > Scale Sailplanes
Old Nov 06, 2009, 02:14 AM   #1
10mm carbon fiber wing rod
Anyone know of a good source for carbon rod? Trying to save 12oz on my 2.2 meter Fox by replacing the heavy steel rod.
Slope P is online now Find More Posts by Slope P   Reply With Quote
Old Nov 06, 2009, 04:01 AM   #2
It's in the UK, but these guys are good...
http://www.gliders.uk.com/prodinfo.a...er=G5220%2E105
Rog
Sutton Bank is offline Find More Posts by Sutton Bank   Reply With Quote
Old Nov 06, 2009, 09:22 AM   #3
If you decide to use carbon, metal wing rod tube will cause a failure eventually! A small nick in the carbon at the seam between wing and fuse will allow the carbon to break beautifully. IMHO
Jim
PS: try (google) CST and ACP for carbon rods
vintagesailplnr is offline Find More Posts by vintagesailplnr   Reply With Quote
Old Nov 06, 2009, 12:19 PM   #4
RC since 1968
birdofplay's Avatar
RCFoam.com has Carbon now.
I get mine from there as well as
http://www.goodwinds.com/merch/list....olidfiberglass
birdofplay is offline Find More Posts by birdofplay   Reply With Quote
Old Nov 06, 2009, 02:23 PM   #5
Thanks Gents.....
Old Nov 07, 2009, 11:59 AM   #6
You can also use 7075 T6 aluminum rod. I have it bulk and can cut either .375" or .5" diameter rod to length. You can calculate the weight of various dimensional metals for comparison here: http://www.bostoncenterless.com/weightcalc.htm
.375" x 12" 7075 T6 = 0.1341 lbs. x 16 = 2.15 oz.
.375" x 12" steel = 0.376 lbs. x 16 = 6.016 oz.
.375" x 12" carbon = 0.073 lbs. x 16 = 1.164 oz.
You will avoid the real problem that Jim mentions, save some money vs. carbon and you will not be able to bend the 7075 T6 at that dimension unless you hit a tree at full speed.
Tom
mmartin55 is offline Find More Posts by mmartin55   Reply With Quote
Old Nov 07, 2009, 04:55 PM   #7
Gudmund
We picked some of this up at Icare a couple of weeks ago.
He doesn't show any on his website (http://www.icare-rc.com/index.htm), but you may want to try contacting him.
Gudmund
GudmundT is offline Find More Posts by GudmundT   Reply With Quote
Old Nov 09, 2009, 03:52 PM   #8
Electric Airplane Junkie
bhchan's Avatar
Which manufacturer put a 12 oz steel rod in a 2.2m plane? According to Tom's info , the 10mm rod must be at least 60 cm long!!
Brian, an EAJ
bhchan is offline Find More Posts by bhchan   Reply With Quote
Old Nov 09, 2009, 05:10 PM   #9
The MDM-1 Fox by Royal-model which was purchased from Sal at NESAIL. The rod is about 14" and weighs 9oz and not 12. Still a lot nonetheless.
Old Nov 09, 2009, 05:15 PM   #10
bhchan's Avatar
Fox is an aerobatic sailplane, so a little extra weight should not hurt it. Weight = energy.
Brian, an EAJ
Discussion Replace steel wing joiner with carbon rod? edfardos Electric Sailplanes 7 Oct 31, 2009 08:02 AM
Wanted FVK K2: Carbon wing rod Marcelz Aircraft - Sailplanes (FS/W) 7 Sep 02, 2009 12:46 PM
Question Where to buy a 10mm carbon joiner rod? AndreyT Electric Sailplanes 9 May 05, 2007 05:21 PM
How to place carbon fiber rod in A-10 wing? Bonez Electric Ducted Fan Jet Talk 0 Mar 22, 2005 11:41 PM
9mm & 10mm carbon fiber tubing? allesg The Builders Workshop 7 Oct 28, 2003 01:27 PM
Bored? Want to fight?
Join the RCGroups clan!
