Go Back   RC Groups > Aircraft - Exotic and Special Interest > Free Flight
Old Nov 05, 2009, 03:54 PM   #1
BillHones's Avatar
Dope over foam (any and all types)
hello! so i have a question. has anyone every tried to put either butyrate or nitrate dope over foam? any type of foam... i have an alula slope glider coming and im thinking of trying to cover it with jap tissue or silk span. im no chemist nor do i have any foam to play with... er test
BillHones is offline Find More Posts by BillHones   Reply With Quote
Old Nov 05, 2009, 07:40 PM   #2
I've never yet seen any foam which is not instantly dissolved by dope (or at least its solvents). Of course some might exist that I just haven't met.
You could always try sticking the tissue on with WBPU (Water based polyurethane) instead of dope.
Steve
slipstick is offline Find More Posts by slipstick   Reply With Quote
Old Nov 05, 2009, 08:51 PM   #3
B for Bruce
BMatthews's Avatar
Bill, I'm thinking you posted this to the wrong forum?
BUt yeah, water based polyurethane for the win on this application.
I know there are some foams that are resistant to the solvents used in dopes but they can't be used for making airplanes.
BMatthews is offline Find More Posts by BMatthews   Reply With Quote
Old Nov 06, 2009, 06:42 AM   #4
John O'Sullivan's Avatar
Could not resist this one. Just checked out two EPP planes with acetone and they did not react. If they can take acetone, dope should not be a problem.
EPP(expanded polypropylene) is that stiff rubbery stuff which makes durable planes. However Depron just goes to mush as does regular styrofoam (EPS).
Can't say for Multiplex Elapor foam but I suspect this won't take dope.
Just looking out at our first snowfall of the season - cars off the road everywhere.
John
John O'Sullivan is offline Find More Posts by John O'Sullivan   Reply With Quote
Old Nov 06, 2009, 12:40 PM   #5
BillHones's Avatar
i thought i may have, but i figured that the free flight guys may know a bit more about dope. i may put a link to this thread in the scratch built foam section.
there actually is a thread on here somewhere about glassing with silkspan using wbpu over foam. that would be fun but then i dont get to use my colored dope... i cold make a nice chalked (pastels) theme like easy built site talks about, it has its plus's and minus's. thanks for the info!
Old Nov 06, 2009, 01:34 PM   #6
B for Bruce
BMatthews's Avatar
Once the foam is sealed behind the WBPU and tissue you may find that you can apply your color dope over the skin. But set up a little test panel. If the WBPU is affected by the dope thinner or is too pourous and allows the fumes to pass through to the foam things could get ugly in a hurry.
Making up quick and dirty test samples is a time honored way of trying out different paint and substrate combinations.
Old Nov 11, 2009, 02:02 PM   #7
BillHones's Avatar
seems like after thinking about all of the options, i may have come up with a solution. take a look here:
http://www.rcgroups.com/forums/showt...5#post13557175
thanks for the replies!
Old Nov 17, 2009, 10:51 PM   #8
faif2d's Avatar
Polyurethane foam can be doped. It is a brown color and is available in 2-3 lb/cuft weights. That is the good news the BAD news is you must not hot wire cut it EVER. It gives off phosgene gas (I have no idea how to spell it) that is one of the WW1 poison gases and it will damage your lungs / kill you. It does whittle and sand rather nicely. I have used it for wing tip blocks and it works quite well.
faif2d is offline Find More Posts by faif2d   Reply With Quote
Discussion Chain pitch.... (all scales, all types...) trf_414_m2 Motorcycles 15 Nov 10, 2009 02:25 PM
Discussion Glue Hinge For All Types Of Foam ampmaker Foamies (Scratchbuilt) 12 Sep 11, 2009 04:35 PM
Discussion Why do people like balsa/ply over foam construction? Naxos The Builders Workshop 15 Aug 26, 2009 05:04 PM
Discussion Will any kind of automotive paint work over nitrate dope ? cvint Painting and Finishing Tips 0 Aug 23, 2009 04:39 AM
Discussion Does CA glue damage all types of foam ? Hiram Beginner Training Area (Aircraft-Electric) 14 Jan 29, 2007 09:07 PM
Bored? Want to fight?
Join the RCGroups clan!
