Old Nov 05, 2009, 03:19 PM
fla_larry is offline
Find More Posts by fla_larry
Joined Oct 2009
what is a park flyer and what is a sport flyer
what are the differances or what actually defines the definition of a Park flyer
And what is or defines a sport flyer from say anyother types
fla_larry is offline Find More Posts by fla_larry
Old Nov 05, 2009, 03:35 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
As I understand it:
-- Park Flyer denotes a relatively small, light electric plane
-- Sport flyer denotes a plane that is relatively fast and acrobatic, without regard to its size, or how it's powered.
rafe_b is offline Find More Posts by rafe_b
Old Nov 05, 2009, 04:36 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
I think it's kind of ambiguous what a park flier is. What I take it to mean is any plane that can be flown safely in an average park - say the size of a couple of football fields. I've seen some 60" or so planes being flown in "Parkflyer Territory" and didn't think they were a problem.
philba is offline Find More Posts by philba
Old Nov 05, 2009, 05:33 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
ParkFlyer flys in the park.
SportsFlyer flys in the Sports field!!
Butch777 is offline Find More Posts by Butch777
Old Nov 05, 2009, 05:36 PM
Blue Solitare is offline
Find More Posts by Blue Solitare
Joined Aug 2004
I can fly a sport flying in a park.
Blue Solitare is offline Find More Posts by Blue Solitare
Old Nov 05, 2009, 09:24 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
The AMA gives a speed and weight definition of a Park Flyer. I think of Sport Flying as more of a style of flying as is 3D, pattern, combat and indoor. Many planes can be Park Flyers and can fly in various styles. To me a Sport Flyer would indicate more acrobatic capabilities than a trainer.
bartricky is offline Find More Posts by bartricky
Old Nov 05, 2009, 10:28 PM
Joined Oct 2009
Thanks for the replys, so essentially then when a radio mfg refers to their recvr as a park flyer compatable it is not so much an issue of range, as size and weight?
Old Nov 05, 2009, 10:33 PM
rafe_b is offline
Joined Jan 2009
Ah. Good question. I've wondered the same thing myself. Does it mean reduced range (compared to what??) or reduced size/weight or what? Or does it mean, "don't use this receiver on your 30 pound, 120 inch wingspan model?"
Old Nov 05, 2009, 10:46 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
It means don't use this receiver on any kind of plane with large metallic objects (or heavy use of carbon fiber, as in sail planes made of such) which can "shadow" a 2.4GHz receiver.
A gas/glow/fuel plane has enough of a metallic presence to shadow the signal, making it lose contact with the transmitter.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Nov 06, 2009, 12:34 AM
philba is offline
philba's Avatar
Seattle
Joined Aug 2009
Some of the receivers that say "park flier" do have reduced range. Though, I believe it's due to the antenna used which is why metal and carbon fiber are issues.
Old Nov 06, 2009, 01:11 AM
Ickarusmelt is offline
Find More Posts by Ickarusmelt
old pilot
Ickarusmelt's Avatar
Rapid City SD
Joined Dec 2007
Major question, Larry
A "sport flier" is usually a plane of whatever size that is reasonably easy to fly without extensive experience.
The official AMA definition of a "Park Flyer" is an electric plane 2lbs or less and speed less than 60mph. Generally manufacturers of this size plane assume the radio systems do not need the greater range needed for larger planes. A rule of thumb is that if it is too far away to see orientation and you bash it, you will still have radio control.
The popularity of smaller electric planes that can be flown in local parks or similar locations without bothering other people is increasing rapidly. The AMA Park Flyer division is working hard to develop standards and education to promote fun for RC pilots, maintaining places for everyone to fly and insuring the safety of everyone.
It's best to join the Academy of Model Aeronautics for a number of reasons including liability. The specific Park Flyer membership costs about half what full AMA membership costs, and is intended for guys who fly in ordinary city parks or other local areas not designated as AMA club fields.
Happy flying
Icky
Ickarusmelt is offline Find More Posts by Ickarusmelt
Old Nov 06, 2009, 01:51 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
^You should also mention some clubs do not allow PPP membership at their field,s and that PPP membership isn't accepted at a lot of events too
Xpress.. is offline Find More Posts by Xpress..
Old Nov 18, 2009, 11:09 PM
tedmo is offline
Find More Posts by tedmo
United States, FL, Ruskin
Joined Sep 2008
My interpretation: Park Flyers are usually small, light wt.;foamies, that can be flown safely in a more restricted location / such as a park. Being small etc. they do not safely fly at long range therefore, the park flyer restricted range RX's. Sport flyers generally refers to aircraft built up of lite ply/balsa and may be powered by electric or glow fuel. Far larger, faster and heavier than a park flyer therefore require much more space for safe operation. They are similar in construction to the more advanced pattern type and giant scale but without the more advanced necessitys of those type. Can be used as trainers, in some cases or overall fun fly aircraft. Many have reasonable aerobatic capabilities.
tedmo is offline Find More Posts by tedmo
Old Nov 19, 2009, 12:47 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Not true at all. Parkflyers can be made of balsa OR foam, not just foam. For example, the MUS, or a Mountain Models Switchback.
IMO, there is no difference between a parkflyer or a sport flyer- I can make both do both. I can take a 72" .40 glow plane look like a parkflyer, and comfortably fly it in a fairly large park. Now, that's not the brightest idea, however it can be done. I can make that same model sport fly.
Short range and long range receivers can be used in either type of model, although many micro receivers nowadays made for parkflyers do have full range, such as the Berg 4, or a Hitec Micro 05S. I myself use only full range receivers, because they don't cost a whole lot more than a short range receiver, nor do they weight much more either
Old Nov 19, 2009, 07:38 AM
John Sargent is offline
Find More Posts by John Sargent
John Sargent's Avatar
United States, IL, Aurora
Joined Sep 2007
Park Flyer receivers are a few dollars less than regular receivers. Spend the money on the better receivers.
John Sargent is offline Find More Posts by John Sargent
Sold NIB eSKA Sport Aerobatic Park Flyer Kit Twmaster Aircraft - Electric - Airplanes (FS/W) 2 Sep 13, 2009 05:36 PM
Question Airtronics RX60 6ch 2.4GHz FHSS-1 Park Flyer Receiver old_dude Radios 1 Sep 11, 2009 10:28 AM
Found Sport Flyers Wasp ARF Park Flyer 43" Span rcairplains Aircraft - Electric - Airplanes (FS/W) 0 Jul 08, 2008 10:11 AM
Build Log Sport Flyers Wasp ARF Park Flyer tallflyer Parkflyers 12 Oct 02, 2007 05:00 AM
Herr Mini-sport Park Flyer bs12 Parkflyers 2 Nov 26, 2002 07:08 AM
